Question about Samsung Televison & Video
My unit flashes "fan check" and keeps shutting itself off
My unit keeps flashing "fan check" & shuts itself off
  • kakima Mar 30, 2014
    What model Samsung unit?
  • Teah Kish
    Teah Kish Mar 30, 2014
    HT-BD2E
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
Try to plug it off then look at back and try to blow to your fun or try to spin it with something a bit and plug in it back it should work and do not keep your fun to close to wall or cables
Posted on Mar 31, 2014
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Mr slim indoor fan shuts off
Might change the battery on your control. I wish these had a hard wire thermostat not a big fan of the remote can be confusing.
Mar 19, 2013 | LG LS-L1210CL Mini Split Air Conditioner
The fan motor is on all the time with the controls shut off. I have to shut the unit off with the main breaker. The ac works but again the fan never shuts off. On the circuit board the LED flashes 8 times,...
The indoor fan or the outdoor fan? If it is the indoor fan the thermostat may be wired incorrectly or shorted. If the red wire and green wire in your thermostat maintain contact, the indoor fan will run all the time.
Aug 03, 2011 | Heating & Cooling
Ps3 starts up, fan is very loud, red light flashes and shuts off
Your most likely cause is the CPU or GPU is damaged due to over heating. This is usually not repairable. Red flashing lights are usually a bad hard ware warning. Try looking up flashing or fault codes for PS3 light patterns and check if any match up to the flashes you get. Another thing to indicate hardware failure is if it boots up at all. I'd like to give you better news but this is more then likely more an autopsy report then anything helpful.
Mar 30, 2010 | Sony Playstation 3 (PS3) Console
Why does my Sony 57" Hi-Scan 1080i? 16:9 Projection Television keep turning itself off. I turn it on and after 10 min it shuts itself off I can turn it back on but the longer it is on the quicker it shuts...
Sounds like a heat problem. Check to make sure that if it has a internal fan that it is working, and clean any dust build up, most projection tv's have fans, usually the number of flashes indicate a code that repeats.
Mar 16, 2010 | Sony KV-28FX60 28" TV
Fan check flashes, then the unit shuts off. I found a replacement fan, will changing it solve the problem?
I am unsure if replacing the fan will work, but to test it, put a vaccum cleaner near to the fan, the rush of air should keep the fan spinning and fool the sensor, see if the unit then powers on, if it does then you know the fan is the faulty item.
Mar 02, 2010 | Samsung HT-WX70 Theater System
TV comes on and then shuts off,and a small red l keeps flashing.
If its flashing red repeating groups of three then the lamp door is not detected .
If its flashing in groups of four then a fan is not starting.Look in the vent in the back and spray some canned air into then big fan on the left(looking at it from the back) .That fan may be failing and has gotten to a place where it can't quite start again and just moving it a little with some air will make it work for a while.
If its not one of those two things let me know.
Oct 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Error code of 6 flashing light on circuit board,
There appears to be a short in the unit. Not sure where. The power to the fan is not interrupted completly when the fan shuts down, still feeding voltage to the fan, keeping it running slow. Before checking the wiring, please turn off power first.
Nov 19, 2008 | Heating & Cooling
Plasma won't stay on red light flashes and shuts unit off
The fans are visible in the back and they can be cleaned with compressed air with no moisture built up in the hose line,We don't want to spray water in the fans.Is the only thing you can try and the unit's back does not have to be removed.If this does not solve your problem you might need the help of a servicer.Let Us know how it goes or if you need more information.
Nov 02, 2006 | Philips 42FD9932 42 in. Plasma Television
Televison & Video Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
