2001mercury gandarque wont cran
Batt.is good lights radi works turn ignition nothing
    Sergeant:
  • 258 Answers
9 times out of 10, it's the ignition coil. Wait, motor doesn't turn over? Jiggle the transmission handle a few times while turning the ignition key. Sometimes the micro switch is not set right.
Posted on Apr 17, 2014
When key is turned nothing happens
IT'S MOST LIKELY THE IGNITION SWITCH AT THE BOTTOM OF THE STEERING COLUMN UNDER THE DASH. BUT:
Make sure of the following:
Batt fully charged
terminals clean and tight at batt and starter solenoid
Starter solenoid is working properly
Hope this helps Mike
Jan 29, 2016 | 2002 Lincoln LS
Harley repair
Need more info? Are you saying the batt. Is dead like no.lights? Or its not dead but wont turn motor over? Or motor turns over but no spark? More info
Apr 24, 2014 | 2000 Harley Davidson XL 1200 C Sportster...
1993 dodge durango V8 It wont turn over, it does nothing when you turn the key,we charged the battery and it is good lights go on and everything else works
neutral safety switch or ignition switch...if dashlites, etc come on when u turn ignition on, prob neutral safety switch...chek brightness of headlights for good all around connections...
Nov 27, 2013 | 1993 Dodge Dakota
No power and batt is good
My first guess would be a dead cell inside the battery, or a blown fuseable link between the battery and the fuse box.
Someone would need to check the battery connections and fuse box with a meter.
Jun 01, 2013 | 1996 Ford Taurus
Ignition wont crank ford F 150
Make sure your getting 12V at the starter (fm batt) & have a good, clean ground from the batt. Good luck
Jun 10, 2017 | 2005 Ford F-150
I have a 2002 heritage softtail, I replaced the batt friday. the batt is fully charge. When i turn the ignition on all the lights work the horn works all turn signals work and fuel pump comes on, however...
Fob bat good ..or anti theft device no longer maried to ECM check here 2..http://harleytalking.com/login.php?do=logout&logouthash=1313501436-eb7a83064e08c13f62cc323a7bbce4a8d217cd8d
Aug 14, 2011 | Harley Davidson FLSTC Heritage Softail...
Car wont even turn over batt is good 12.45v
The Water light? you may have over heated the car, also you may have caused a crack in the engine block by driving the car after the Temp light came on, Check the Thermostat, This may have caused the Light to come on and can cause some major problems if not replaced. Good luck!
Mar 19, 2010 | 1997 Volkswagen Jetta
Car started and ran fine turned it off and when I tried to start
You have a bad battery connection at a cable or your batt is kaput. remove, clean and reinstall batt cables. Good Luck
Jun 08, 2009 | 1991 Cadillac DeVille
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
