Question about Cameras
Traveler dc 12
How do I download photo's to my laptop
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
    An expert that gotĀ 20 achievements.
  • Cameras Master
  • 102,366 Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Posted on Mar 30, 2014
My traveler DC-12 screen is cracked can it be fixed.
A replacement screen can be purchased via ebay.
Feb 21, 2016 | Computers & Internet
Where can I source an new a.c. adapter for my craftwell e bosser
Search for a Travel Laptop Adapter or Universal Laptop Adapter. Targus makes one with several different tips. Targus Laptop AC DC Travel Charger with USB Fast Charging Port USB...
Aug 27, 2014 | Computers & Internet
Kodak dc-12 travaler digital camera user manual
Visit this link to download the file and other details: traveler-dc-12
Check in DOWNLOADS section.
Hope helps (reemmeber to rate this answer).
Apr 16, 2011 | Kodak Cameras
No power to refrigerator unless it is hooked up direct. Think it is 12 volt dc supply connection. Could this be the problem only able to get partial # on part c1c 5122 is all we can read.
there is an inverter built in to the power supply that converts dc to ac to run the compressor if the fuse is ok. you will have to replace the supply . or for traveling you could hook up a small inverter to opperate the fridge while traveling this could be connected to the 12 vlt line for fridge power as it will not take much more power than the the fridge needs.
Feb 21, 2011 | Thetford NorcoldĀ® Model DE0061
Wish to take laptop travelling for an extended period and wish to know if it can be operated off the 12 volt car circuit, the battery dosent hold charge for more than 15 minutes.
Yes you can - purchase a 12 Volt DC to 110 Volt AC converter (you can get at Staples or Home Depot). This will allow you to plug your adapter into the converter while it's plugged into the cigarette lighter jack in the car.
Nov 10, 2010 | Optima Centrino Notebook 680009100170
Slide out will not slide it is out but will not slide in, Battery is fully charge & electric is on. Any suggestions? 1998 Fleetwood Mallard 26' travel trailer
GO TO THE ELECTRICAL PANEL WHERE THE CIRCUIT BREAKERS ARE,ON MOST MODELS, THE DC INVERTER (12VOLT) IS BUILT TO THE AC (120 VOLT)BREAKER BOX.CHECK THE FUSES ON THE DC INVERTER SIDE(SHOULD LOOK LIKE AUTOMOTIVE FUSES) IF FUSES ARE GOOD,CHECK FOR PROBLEMS AT THE TRAVEL LIMIT SWITCH LOCATED SOMEWHERE AROUND THE TRACKS THAT THE SLIDE TRAVELS ON.SOMETIMES AFTER SITTING FOR A WHILE THE LIMIT SWITCH DO NOT MAKE PROPER CONTACT FROM AGE,USAGE, CORROSION,ECT.,EASY THING TO TRY IS MANUALLY MOVE THE ACTUATOR ON THE LIMIT SWITCH SEVERAL TIMES WITH YOUR HAND ,YOU SHOULD FEEL OR HEAR IT CLICK. THOUGH IT IS SELDOM THAT THE LIMIT SWITCH IS A PROBLEM,IF THE FUSES ARE ALL GOOD,THE ONLY THING LEFT IS THE SLIDE MOTOR WHICH CAN BE LOCATED UNDER THE TRAILER AROUND THE SLIDE TRACKS,UNPLUG THE WIRES,HAVE SOMEONE PUSH THE SWITCH WHILE SOMEONE CHECKS FOR VOLTAGE AT THE MOTOR,YOU SHOULD USE A TEST METER ABLE TO READ AND VERIFY 12 VOLTS DC.IF YOU HAVE 12 VOLTS DC WHEN BUTTON IS PUSHED,MOTOR MAY BE BAD,PLUG WIRES BACK TOGETHER,MOVE TO A SAFE PLACE AWAY FROM POTENTIAL PINCH POINTS AND PUSH THE BUTTON AGAIN.
THERE MAY BE A CHANCE OF BAD CONNECTION AT THE MOTOR PLUG.
I HOPE THIS IS NOT TOO CONFUSING,AND THE PROBLEM IS ONLY A FUSE BECAUSE A FUSE IS A MUCH SIMPLER,CHEAPER FIX.
BEST OF LUCK.
Oct 30, 2010 | Electronics - Others
Je veux changer le dc jack sur mon pc taga traveler 826 sw
Je ne parler vous Francais. Je Regrette.
1) http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
2) http://www.notebookrepairguide.com/laptop-notebook-repair-service-manuals/
Jan 09, 2010 | Computers & Internet
Cameras Logo
21 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
