Question about Dell OptiPlex GX260 PC Desktop
I have changed a disk drive on my GX260. When I power the system the message "the disk configuration has changed, Press F2". I have a USB keyboard with a PS2 converter but I can not get into the BIOS. Any ideas?
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 5 Answers
What you can do is open your Dell GX260 you will see little light on the inside of you PCU unplug your power cord and pull your battery out, untell all the lights on the inside go's out about one min. put the battery back in close your case pluge in your power cord turn your computer on this will reset your computer now you can do what you need to.
Posted on Aug 26, 2009
    President:
  • 2,653 Answers
Just use the usb by itself.
Posted on Jun 15, 2009
I have an Optiplex GX 620 Mini Tower that displays a NIC failure error at boot. The error message reads "NIC failure. Press F1 to reboot or F2 to go in to setup." The PC did not boots
it means your hard disk is not detected by system, check all connections of hard disk, if problem remains check with another working hard disk
Jul 29, 2012 | Dell OptiPlex GX260 PC Desktop
What function key gives entry to cmos
BIOS is fixed program that starts up the computer. BIOS is initialized during start up of HP Compaq-6715B which sets the computer settings to be uploaded. BIOS enables the creation of a bootable diskette, CD, or USB key that can be used to locally restore or upgrade the System BIOS in the supported notebook models with a 68YTT Family ROM. Only insert the USB drive that will be used to format and create bootable BIOS upgraded USB media. However, you should remove all unused USB drives and flash drives from the notebook before. In order to ROM family and ROM date, press F10 on the target notebook during startup to run the setup utility.
The tips to get into the BIOS of HP Compaq-6715b are:
  • Press F2 for setup
  • Shows logo
  • Independent of OS
Press F2 for setup
BIOS often has a blue background, and uses the arrow keys, PageUp, PageDown and enter keys to change the settings. After you have got into or accessed the BIOS, you can change the boot order settings so that the floppy disk is checked first to see if it contains a bootable program. Usually a message will appear telling you how to enter the BIOS setup program as the computer starts up, such as Press F2 for Setup.
Shows logo
Your HP Compaq-6715b might be configured to show your computer's logo instead of important BIOS messages. In this case, you can press Esc or Tab while the logo screen is visible. If you are facing problems pressing the pause button in time, turn on your computer with your keyboard unplugged. In this situation you will receive a keyboard error, which helps you in pausing the startup process long enough for you to see the keys necessary to enter BIOS.
Independent of OS
The PCs with both PS/2 and USB connections are configured to only allow USB input after the POST. If you are using a USB keyboard, it could be impossible to access BIOS. You would need to connect an older PS/2 keyboard to your PC to access BIOS. The BIOS accessing is independent of any Operating System on your computer because the BIOS is part of your motherboard hardware.
http://www.bostonrecycling.net/
Jun 25, 2012 | HP Compaq 6715b Notebook PC
I've changed the CMOS battery of my GX260 series desktop as it was prompting an alert as "System battery voltage low" & after that Systems IDE configuration failed performing an automatic...
Press f2 to enter the BIOS while you see the Dell start up screen. Once in there you shoudl see an option to load BIOS defaults. Load defaults. This should take care of the issue. Are you sure that you replaced it with an approved CMOS batter, You cannot use a watch battery, even though they are the same size it won't work.
Aug 01, 2011 | Dell OptiPlex GX260 PC Desktop
Irql not less or equal blue sreen cf-51
reformatting the disk / restore computer back to company settings...is only the resolution for this...
To reinstall your operating system, you must have a CD drive in your multimedia pocket.
Note: CF-51 (Mk2) and CF-51 (Mk3) can also boot to an external Panasonic USB CD drive.
When the laptop is first powered on, the Panasonic name appears in white lettering with the phrase 'Press F2 to enter Setup' directly below it. When this phrase appears on the screen, immediately press F2 on your keyboard. Put the Panasonic recovery CD in your drive and use the arrow keys to move to the boot tab. Change the order of boot so the CD drive boots first. To do this, highlight the CD drive and press F6 until CD drive is the No. 1 listing. Press F10 to save your changes, exit and follow the instructions when your CD starts running.
Jun 14, 2011 | Panasonic Toughbook CF-51 Notebook
While booting system gives message of 0 drive error also can not find disk drive
you need to press f2 from your keyboard to enter Standard CMOS Features, then highlight drive A. change it to none. May sure that you must not have anything in there unless you have floppy drive......Then configure the boot sequence, have the bios start up first ,second the cd,third the floppy disk and last the main hard drive( primary drive).If you have secondary drive than it should after the primary drive.
Hope this will help you.
Regards,
Apr 30, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Windows XP CD cannot be detected in Dell Optiplex gx260
Your optical drive might be dirty or bad. Try an official Dell disk to see if it will read it, especially a Dell drivers and Utilities disk. Also try a boot flash drive or boot floppy(since your system is a older) to get the system up. If your system comes up any of those ways, I would try a disk cleaner. If that doesn't help, then you probably have a bad cd drive. You could also look in bios setup to make sure the bios is showing your cd drive. It should list it there somewhere. Probably on the first page.
Feb 08, 2010 | Dell OptiPlex GX260 PC Desktop
Can't enter BIOS
Hi there.
  • Boot the system. Press F2 to enter the BIOS setup.
  • Press ALT-F
  • Press ALT-B
  • Computer will restart and display a message indicating it is re-detecting IDE drives. After a minute or so, Windows will start. Test the device that wasn't working before.
  • If you want to restore other BIOS settings you have set, such as the boot sequence, you will have to restart the computer and enter BIOS setup again.
If this does not work try another usb keyboard in the same port.
Good luck and thanks for using FixYa!!
Apr 22, 2009 | Dell OptiPlex GX280 PC Desktop
Inspiron 530S Power Save Mode Loop
First you need to make sure that there are no other removable devices plug on the system, like usb, external hard drives, then if that will work try to go to the bios, press f2 when you see the dell logo, and go to the system setup, go to the boot device configuration and make sure that removable device is not the first boot device, if it is the first one choose hard disk and then second boot device ad cd rom/dvd rom and then disable the 3rd boot and the fourth boot device. Make sure to save the changes. And restart the system again. Once the computer is back and running try to go to support.dell.com and check the bios, download if there is a bios update for the system.
Oct 30, 2008 | Computers & Internet
Dell OptiPlex GX260 PC Desktop Logo
65 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
