This is a electronic clutch actuator, for engaging the blades if you look closely you will see 2 wires with a plug on the end its probably loose or needs crimped with a pair of pliers a little to make better contact. it like the AC clutch on your vehicle Thanks in advance but remember to leave rating and testimonial after we fix it ok testimonial if for after how well we do for you also we are volunteers and have jobs too so be patient thanks.
Nothing will make it easier for him to learn. He will have to learn ... If he can ride a bicycle, he should be able to move right into this small motorcyce. If he CAN NOT ride a bicycle, that is the place to start, not fixing the automatic clutch that isnt broken.
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
