Question about Webroot Computers & Internet
Where can I enter my key code I just purchased a 2 year
The cd did not run automaticaly where can I enter my key code
  • 98 Answers
If you open up your "My Computer" window (you can do this by pressing the Start button and the letter E at the same time), you will see an icon that resembles a CD or something similar. Double clicking it will open up an installation window where you must follow the instructions given to install it and insert your credentials.
Posted on Mar 31, 2014
I NEED A KEY CODE FOR THE BUILT IN RADIO IN A FORD FIGO 1.4 AMBIENTE 2012 MODEL
Try this, found it on another answer board.
Press and hold the Auto button. While holding the Auto button, push and hold the Track Up button. The “_ _ _ _” will disappear after about 5 sec. Enter KCAR using the remote control from a higher end CD Receiver or any Excelon CD Receiver. Enter "KCAR” with the remote controller as described below. “K”: Press TRACK UP key (>>|) after pressing 5 key twice. “C”: Press TRACK UP key (>>|) after pressing 2 key once. “A”: Press TRACK UP key (>>|) after pressing 2 key three times. “R”: Press TRACK UP key (>>|) after pressing 7 key twice. * If you commit a mistake in the code entry, the unit enters the code request mode again. Press the Track Advance button on the remote to enter the override code. The unit will enter the All Off or Standby mode if done properly. Video Unlock: Use a remote from a higher end CD Receiver or any Excelon CD Receiver. Some Video remotes will work, switch on remote must be set to AUD. Press 55222277 on the remote. There will be NO visual verification when entering the override code. Head units with a Up / Down Volume control buttons: Press and hold the Volume Up button. While holding the Volume Up button, push and hold the Disp button. The “_ _ _ _” will disappear after about 5 sec. Enter KCAR using the remote control from a higher end CD Receiver or any Excelon CD Receiver. Enter "KCAR” with the remote controller as described below. “K”: Press TRACK UP key (>>|) after pressing 5 key twice. “C”: Press TRACK UP key (>>|) after pressing 2 key once. “A”: Press TRACK UP key (>>|) after pressing 2 key three times. “R”: Press TRACK UP key (>>|) after pressing 7 key twice. * If you commit a mistake in the code entry, the unit enters the code request mode again. Press the Track Advance button on the remote to enter the override code. The unit will enter the All Off or Standby mode if done properly.
Read more: How can I get the key code for ford figo radio systems? - Radio system key code ford figo :: Ask Me Fast at http://www.askmefast.com/How_can_I_get_the_key_code_for_ford_figo_radio_systems-qna4609185.html#q2909005
Dec 09, 2015 | Ford Cars & Trucks
My system was restsrt automaticaly again agian
Follow my instructions.
Step 1. Check the system is working in safe mode or not. For safe mode start your system and keep tabing F8 key on the key board. You will get black window on your screen. Choose safe mode by using down arrow key and press Enter. Your computer will start with limited program.
Step 2. Go to Start menu--- Run--- msconfig --- Select Services tab---- Disable all the program and restart your computer with normal mode.
Step 3. Repair your Anti virus and restart your system again.
Then check problem has been fixed or not.
Try it I'm sure it works.
Aug 30, 2011 | Computers & Internet
Our car stereo will automaticaly off in a few minuete and it will ask a code, but when we switch off and on again then it would be ok, but in a few minuete again it will automaticaly off angd ask for a...
By entering the correct code
If you do not have it , then remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
Aug 11, 2010 | Car Audio & Video
I have nokia E63 when i tried to activate the security code when i enter the pin code the mobile is automaticaly lock.
Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device:
Soft reset code *#7370#
Hard reset code *#7780#
If the hard format code mentioned aboive does not work, try the following manual method to hard reset/format Nokia N95:
+ Turn off the mobile device.
+ Press and Hold the following three buttons: the green Call Answer button, the “*” button, and the number “3′ button.
+ While holding these buttons, turn on the phone and keep holding the keys untill the mobile phone restarts and prompts you to enter details.
Jun 24, 2010 | Lands Phones
Service code p88, what does that mean?
this means the automatic exposure needs to be adjusted and there is a special chart you have to put on the glass andd enter 47 mode and run code 98 to automaticaly run the adjustment repeatedly when the adjustment is complete the center copy density indicator will light up yopu cabn try it with a blank peice of paper but you are supposed to use the aes chart for the adjustment
Aug 24, 2009 | Konica Minolta Office Equipment & Supplies
KDC-716S sometimes plays CD, other times just tray drop
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Jun 01, 2009 | Kenwood KDC-716S CD Player
Kenwood ddx512
The unlock code usually only goes on if you previously put one on there. I would suggest calling Kenwood but there is a guy that claims he can fix this i have never tried this but you can. http://mike-unlockcodes.blogspot.com/
Apr 24, 2009 | Kenwood DDX-512 Car DVD Player
Just purchase nero * and downloaded but cant get it run always ref to trial version i purchase a full version help
you should have a key code/serial number if you purchase it... look in the help menu for an option that will let you enter the key code. (look in the white envelope where the cd came in as it may be printed there.
key code and serial number is the same...you need to enter that for you to be able to use the full program.
Sep 28, 2008 | Computers & Internet
Car cd player
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Dec 13, 2007 | Car Audio & Video
Kenwood MP4029 4 code reset
Type 1
Type 2
Type 3
Oct 13, 2007 | Kenwood KDC-MP228 CD Player
Computers & Internet Logo
48 people viewed this question
Top Webroot Computers & Internet Experts
Mike
Jerry
Jerry
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
