Question about Electrical Supplies
Two way light switgh
In house
  • 3,368 Answers
I would assume you have several but there is not enough information to even guess an answer.
Posted on Apr 29, 2014
2004 nisan titan shiftre gets stuck in park at times
Start by checking if your brake lights work since the shift interlock and the brakes use the same fuse. If they don't you have a bad fuse. If the do then you might have either a bad shift interlock or a bad break switch.
Aug 18, 2014 | 2004 Nissan Titan
On my 1989 chevy the switgh tha goes from hi beam to low beam dosent work
check down the column to see if the rod is still attached to the switch if it is the the high low switch is bad
Apr 17, 2014 | 2003 Chevrolet Suburban 1500
What is the function of the neutral safety switgh
The neutral safety switch is to prevent starting of the vehicle when in gear. It allows power to the starter motor when in Park or Neutral.
Feb 02, 2013 | 1994 Mercedes-Benz E-Class
2004 trailblazer fan switgh stop working
its either the fan switch or the blower motor resistor
Jun 12, 2012 | 2004 Chevrolet Blazer
I have a 200 heritage softail classic the brake light stays on and i dissconnected the pressure switgh for the foot brake and the light stays on. So I guess it's the hand brake switch that is shot. If...
If you disconnected the pressure switch for the rear brake and the light is still on, your deduction of a bad front brake light switch is right on. There is nothing else on the bike that would make the rear brake light come on. If you've moved handlebar switch housing or the master cylinder, make sure that they are positioned snugl against each other. Additonally, I've been reading where wear in the lever and pivot pin combine to make the switch not work. Replacing the lever and pivot pin may resolve the problem. To test, move the front master cylinder away from the switch housing and manually operate the switch to see if the switch is or is not working correctly.
Good Luck
Steve
Jul 06, 2011 | 2000 Harley Davidson FLSTC Heritage...
Had to pull fuse # 23 brake switch to get the back lights to shut
If it's the brake lights, you may need to adjust your stoplight switch under the brake pedal bracket. If it's the taillights, then you will need to trace and diagnose it. Which lights are staying on and which circuit does fuse #23 operate?
Thanks,
Kevin
Sep 17, 2009 | 1998 Jeep Grand Cherokee
My mobile is not switching on
i have nok 3110c and i flashed the mobile but he is not getting swith on.mobile is taking full flashing but not takin ui setting.
Jul 10, 2009 | Nokia 3110 Cellular Phone
Need to hook back up to power
wiring problem need professional
Apr 02, 2009 | Heating & Cooling
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
