Question about Apple iPhone Smartphone
Water on my iphone
I dropped my i-phone in water and put in a box of rice what are my chances of survival
  • Apple Master
  • 4,338 Answers
  1. Get it out of the water as soon as possible. The plastic covers on cell phones are fairly tight, but water can enter the phone in a short period of time, perhaps only 20 seconds or less. So grab your phone quickly! If you can't get to it in time, your best bet is to remove the battery while it is still under water. Water helps dissipate heat from shorts that can damage the phone, so most damage occurs when the inside of the phone is merely wet and there is a power source. This can go both ways. Being under water is more likely to short the battery to even more sensitive contacts, so be careful.
  2. Don't Panic. Your phone will probably not be too damaged if you right away take it out of the water. While it's in the water, immediately take it out.
  3. Remove the battery. This is one of the most important steps. Don't take time to think about it; electricity and water do not mix. Cutting power to your phone is a crucial first step in saving it. Many circuits inside the phone will survive immersion in water provided they are not attached to a power source when wet.
  4. If you have a GSM carrier, remove your SIM card. Some or all of your valuable contacts (along with other data) could be stored on your SIM. To some people this could be more worth saving than the phone itself. SIM cards survive water damage well, but some of the following steps are unnecessary i.e. don't heat it. Just pat it dry and leave it aside until you need to connect your phone to your cellular network. (This step does not apply to CDMA carriers such as Verizon, Alltel, US Cellular, Sprint, etc.)
  5. Dry your phone. Obviously you need to remove as much of the water as soon as possible, so you can save it from getting into the phone. Shake it out without dropping it, then use a towel or paper towel (ideally trying not to clog the wet paper in the gaps and grooves of the phone) to gently remove as much of the remaining water as possible. Dry the excess moisture by hand.
  6. Remove any covers and external connectors to open up as many gaps, slots, and crevices in the phone as possible.
  7. Use a vacuum cleaner if possible. Do not use a hair dryer (even on a "cold" mode) to dry out the phone, as this may force moisture further into the small components, deep inside the phone. If moisture is driven deeper inside, corrosion and oxidation may result when minerals from liquids are deposited on the circuitry. Using a hairdryer might be a temporary fix, but this will eventually cause component failure inside the phone. Instead, remove all residual moisture by drawing it away with a vacuum cleaner held over the affected areas for up to 20 minutes in each accessible area. This is the fastest method and can completely dry out your phone and get it working in thirty minutes. Be careful not to hold the vacuum too close to the phone, as a vacuum can create static electricity, which is even worse.
  8. Use a substance with a high affinity for water to help draw out moisture. Leave the phone in a bowl or bag of uncooked rice overnight. The rice would absorb any remaining moisture. If available, it is preferable to use desiccant instead. Desiccant will absorb moisture better than rice. It may be found under a brand name such as the "BHEESTIE Bag™" "DRY-ALL" "Damp Rid" or "Dry Right".
  9. Let the phone sit on absorbent towels, napkin, or other paper. Remember that the goal is to evacuate all the moisture and humidity, not to trap it or add even more. Check the absorbent material every hour for 4 to 6 hours. If moisture is evident, repeat the vacuuming step and desiccant steps.
  10. Test your phone. After you have waited a day or so, make sure everything is clean and dry looking and re-attach the battery to the phone and see if it works. If your phone does not work, try plugging it into its charger without the battery, if this works, you need a new battery. If not, try taking your cell phone to an authorized dealer. Sometimes they can fix it. Don't try to hide the fact that it has been wet. There are internal indicators that prove moisture.
  11. Take the phone apart If your phone doesn't turn on at all. Try taking it apart. First, make sure that you have ALL the right parts and know exactly where they go. Be sure to put everything back in its proper place once finished. As you're disassembling it, pat each individual part dry with a small towel and use the vacuum cleaner once more on the crevices. If this doesn't work go to the professionals.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jun 15, 2009
Does putting your phone in rice work after it fell in water?
Yes, it does! If you have dropped your phone in water, completely submerging your SIM Card and Phone in rice will cause the rice to absorb the water in your phone. Your phone will work after a couple of hours of being in rice.
Jul 19, 2014 | Apple iPhone 5
My phone drob in water what can i do
try putting it in a bag of dry rice for a few days. it will take the water out of phone. remove the battery if u can. my son dropped my new iphone in water and this fixed it
Apr 06, 2014 | Nokia C203
I drop my iphone 4 in the sink
First of all: Don't try to charge it or turn it on unless you're sure all the water has come out. You write it's gotten hot. That means the battery discharged very rapidly du to the water inside the iPhone. It might be the battery or surrounding circuits have been damaged by this, but first let's get the water out.
Put your iPhone in a closed container filled with rice (uncooked! fresh from the store). Rice is (like salt) pulling all water from it's surrounding. Don't use salt as salt can lead to heavy corrosion.
It's a good idea to open the SIM tray.
If you keep this jar/box in a warm place for several days all water will evaporate from the iPhone case into the rice. After that you shouldn't see any traces of humidity left on the iPhone. If unsure leave the iPhone with the rice for a few days more.
Plug the charger in and wait a few minutes to see if the charging indicator shows up or the iPhone starts. Be prepared to pull the plug in case the iPhone gets host very fast. Good Luck.
Mar 11, 2014 | Apple iPhone4 4G iPhone 4
Dropped phone down the toilet
Always open a wet phone up, take out the battery and submerge both in rice. it will absorb the moisture and give you the best chance of survival of your phone.
Apr 29, 2012 | RIM BlackBerry? Curve 8330 Cellular Phone
My CHAD remote was dropped in water. What are the chances that it will it still work if I dry it out?
if it is fresh water it has a very good chance of working again
remove batteries and leave it to dry for a few days before trying to put batteries back in and using
good luck!!
Mar 29, 2011 | Onkyo CHAD LCD Touchscreen Remote Control
Dropped iphone in water apple wont go away
1) Immediately turn phone off by holding down power button and sliding to off.
2) Use canned air duster to blow water out of all holed in the phone such as headphone port, sim tray hole and the bottom port
3) Place phone in sealed baggie containing silica packs (come with shoes/coats, etc) or uncooked rice for at least 24 hrs.
4) In this time, DO NOT try to power the phone on, this can easily cause a short and ruin a phone that may have otherwise survived.
5) Wait 1 or 2 days and remove from the rice/silica which should have drawn out the water. Now try and power on the phone. I have seen these steps save a soaked iphone more than once.
Good Luck
Feb 24, 2011 | Apple iPhone 3G Black Smartphone
Iphine dropped down the toilet. put it in bag of rice home key and internet not working
Sounds like they got fried by the water. You just can't expect rice to heal the electronic components (although it will take away the water). It would probably be cheaper just to buy an new iPhone than to get it repaired.
Feb 24, 2011 | Apple iPhone (16 GB) Smartphone
I dropped my iPhone in water. What should I do?
useually unrepairable but take the back off then remove battery and sim then use a hair dryer to try and dry out the moisture sometimes it works depends on how much water damage is in the main board
Sep 01, 2010 | Apple iPhone (16 GB) Smartphone
Apple iPhone Smartphone Logo
320 people viewed this question
Top Apple Cell Phones Experts
David
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
