Question about GE Dryers
Not drying efficiently. Air moving ok, heat appears to be ok. Would like to open it up to visually inspect it. With event off slight burning smell. Would like to verify clean of lint.
How to open up for cleaning and inspection?
    Problem Solver:
  • 18 Answers
If it tumbles and it heats up but your clothes don' t dry disconnect the vent tube from the the wall and run a load of wet clothes if they dry then your homes venting is clogged and if it still does not dry then it could be your thermal fuse.
Posted on Apr 28, 2014
5 Suggested Answers
  • 207 Answers
SOURCE: Hi, smelled burning from dryer,
Its sounds good is the smell gone,if so you did just fine........
Posted on Apr 10, 2011
Testimonial: "Thank You for your expert advice and opinion. Dave"
bonedivers
  • 1140 Answers
SOURCE: My dryer smells like it is burning. I took it
scary, is it like rubber or plastic?
rubber would be belt or drum rollers
plastic would be wiring (possible fire hazard)!!!
Posted on May 18, 2011
emissionwiz
  • 79186 Answers
SOURCE: clothes smell after drying
I don't think the problem lies with the dryer, I would suspect the washer has mold, this is especially true on front load washer, they make products designed just for this problem, check with a large retailer, not sure who makes the mold and mildew remover, I think Home Depot or Lowes may have the product or know about it..
Posted on Jan 29, 2012
richroth
  • 9472 Answers
SOURCE: my amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
Posted on May 23, 2012
Limit switch is open
An abnormal high temperature will cause a limit switch to open on a furnace. I would inspect/clean filter, clean blower compartment, clean blower motor wheel and make sure the motor is running at the proper speed.
Nov 03, 2015 | Heating & Cooling
Dryer heats but clothes wont dry and have checked lint screens front and back. How much "air flow" should be coming out the back of the dryer?
Do not use this dryer until you fix it. You need to check the pipe or flexible tube that comes out of your dryer (where the hot air comes out). Even though you clean your dryer lint trap some lint gets by. If you can get to it, go outside and find the opening where the dryer air comes out of your house. Then open the little door and look inside but not when the dryer is running. If there is any lint inside clean it out. Then disconnect the air outlet from the back of the dryer and inspect. It should be free of lint. If it is full of lint clean it all out. You can also call a pro to perform the inspection and cleaning. Good luck.
Jan 16, 2014 | Dryers
De leaks into pool
one or more of the grids may be damaged. you will have to open the filter and inspect the grids (yes, they will have to be cleaned for the inspection)
Sep 22, 2013 | Hayward EC-40 DE Pool Filter with pump
Oki c5650 toner showing empty but it is full
first open the cartridge access door and look inside the printer is there any toner dust or not? then manually inspect the optical white fiber hole is clean or not.and finally inspect is there any cartridge detection chip if yes then replace the chip your problem will be solved.
Jun 15, 2012 | OKI Office Equipment & Supplies
I have a Whirlpool fridge that is not cooling. I have done the following 1. Turned the thermostat to zero and then started it again after 30 min wirks for some time and then stops again 2. Opened the...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 23, 2011 | Refrigerators
Bottom of my Bosch dishwasher not cleaning dishes, top tray OK have cleaned / taken apart
Carefully inspect the lower spray arm for a crack or separation.
Also inspect the holes in the spray arm that may be stopped up with debris.
Remove and clean the filter in the front center of the tub.
Set the spray arm at the 12 o'clock position and start the washer. After 30 seconds open the door and check the position of the spray arm. Do thi several times to confirm the spray arm is rotating.
Feb 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
PAPER JAM ON LEFT SIDE, PAPER DOES NOT COME OUT
Open the left cover and inspect the paper tray and the fuser unit.90% paper jam in the fuser/exit unit.Inspect and clean the rollers and the fingers.
Oct 02, 2009 | Canon imageCLASS MF6590 Copier
1/4 black line going down back of paper when I print
The black line going down the back is from toner coming off of the cartridge
open the printer (I am assuming it is **** shell design remove the developer/toner section
open the plastic shutter that goes all teh way across the drum area and inspect you may find a piece of paper in there or there is suppose to be a wiper assembly that may be bad
while you have the machine open clean the charger wires( they pull out on a rod and clean with a pencil erasure
also inspect the fuser rollers(be careful they are hot to make sure no toner has built up on them if so let the macne cool and clean with silicone lubricant do not scrae with any sharp object
Dec 30, 2008 | Brother HL 1440 Laser Printer
Vacuum cuts out
Perhaps the motor is overheating. Open the casing and inspect the motor for excessive dust around the air vents. Clean it out. Also inspect around the shaft to make sure it is spinning freely and it hasn't become entwined with debris.
Sep 06, 2008 | Vacuums
Rs2556sh side by side samsung - fridge side door will not stay shut
i have the exact same problem. Let me know if you find a solution.
Jul 26, 2008 | Samsung RS2556 Side by Side Refrigerator
Dryers Logo
132 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
