I made wrong addres emal
Kathy.eugene@hot mail.com is wrong shuld be Eugene.kathy@hotmail.com
  • 28 Answers
Ok its ur correct email is
Posted on Mar 31, 2014
SOURCE: my kodak 5100 will not print. Sent an e-mail on 12-25 -08
try try again..........check that the print spoller is on in device setup
I had this problem;
Printhead replacement instructions are in the users guide.
THIS WORKED FOR ME --AND IF YOU CALL THE TECH SUPPORT # KODAK WILL SEND YOU A REPLACEMENT HEAD........
Power on printer, the printhead rides on a carriage that is connected to the ribbon cable. When the printhead is in the center position and movement is stopped REMOVE THE INK CARRIAGES. DO NOT TOUCH THE INK-PADS OR THE CONNECTION POINTS. You can just place the ink carriages on their side on a clean piece of paper.
......... To separate the printhead from the carriage press the release botton(above the bulls-eye sticker) in the top center of the printhead. You will hear a click and the top of the prinhead will pop forward about 1/4 of an inch. GENTLY lift from back (where you pressed the botton) to front and lift the printhead up and out of the printer.
---------U will see where the printhead and the carriage connect-------
It is best (very important) to not touch the shiny contact area
Now you are ready to install your new printhead.
BE CAREFUL BE GENTLE............Place the new printhead into the carriage and again at the center top back bulls-eye press back until you hear the click and the printhesd is secured in the carriage.......... replace the ink carriages.......
I would power off the printer and wait about 60 seconds then power on and run self test.
TO RUN SELF TEST
power on the printer and wait until the printhead is in the center position THEN press photo and copy buttons at the same time, you will hear the printhead carriage start to move and a test print page will print.
CHECK for print quailty; run all diag. from the help tab as needed.
REMEMBER; IF YOU THINK THE PLASTIC WILL CRACK U ARE PRESSING TOO HARD....... KEEP IT CLEAN, BE SAFE
Posted on Jan 01, 2009
eagle338
  • 4889 Answers
SOURCE: HP G85xi printer - No color output
> First thing to try is a cleaning and maintenance cycle. There are also
> rare instances of cartridges being defective, it may have one of those.
An uninstall and reinstall of the printer may also help
Posted on Oct 21, 2007
pagebor
  • 2785 Answers
SOURCE: I need to reinstall my
plz check the manufacture website
Posted on Aug 13, 2008
leroyal
  • 2120 Answers
SOURCE: connector cable
I get many from Rite-Aid.
Best Buy and Staples are expensive. You need a USB A/B cable.
Posted on Jan 12, 2009
  • 857 Answers
SOURCE: MY HP C5180 HAS A
Without turning off the product, disconnect the USB cable from the rear of the product.Hold down "OK" button and "Help" button. While holding both down, plug in power. Continue to hold both buttons down until unit powers off. After it powers off, release both buttons and power unit on.
try this 2-3 times thi should help.
what else you can try is:
Remove the cartridges from the product.
Wait for the 'Insert Cartridges ' message to display on the control panel.
Disconnect the power cord from the back of the product.
Wait 60 seconds.
Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Reinsert the cartridges, and then close any open doors on the product.
If you receive a prompt to print a calibration page, do so.
Reconnect the USB cable to the rear of the product, and then try printing again.
Posted on Aug 17, 2010
Have just bought a secondhand Ruby and replaced the blades and basket - still having problems with the basket collecting pulp (apples) and becoming noisy - unbalanced I assume. When I clean out the basket...
Hi Kathy, we had the same problem. You need to soak you basket overnight (every day) in a chlorinated solution/detergent. This will keep your filter basket clean. Also, make sure you rinse out your juicer if you know you are not going to use it much for a few hours as the pulp will dry up and clog your filter. Since adopting we started doing this we haven't had any more problems.
Feb 13, 2011 | Nutrifaster Ruby 2000 Juicer
I have a designer 1. recently when i go to embroider, it starts fine then just goes hay wire and put teh embroider all over the place- not like the pattern. Sound to me like the emb. unit? thanks kathy
Hi Kathy, I'm sorry your Designer 1 is not feeling well.8*( It sounds like to me you need to get your embroidery unit re-calibrated by your local technician. When was the last time you had your machine serviced? Are the designs you are trying to embroider stock designs or your own designs? Have you tried resetting your machine by turning it off and back on again and let the machine calibrate again? (Take the hoop off before you do this and put it back on after you have selected your design) and try it again. Also how old is your machine? They had a recall on Des 1 purchased between 1999-2004 for a power supply problem. The serial # and recall info is on the Viking website at- www.husqvarnaviking.com. Also do you have enough clearance around your machine where the hoop is not hitting anything while it's embroidering that will throw it of big time! Hope something here helps you! If I can help you further you can also email me at- kats2sew@hotmail.com Happy Sewing!! Kathy ( from 1 Kathy to another)
Nov 02, 2010 | Husqvarna Designer I
MY DELONGHI DFS 090 SO OVEN DOES NOT GET HOT FAN COMES ON AND INTERIOR LIGHT
Hi wendy I am having the same problem with mine did you find out what the problem was please thanks kathy, if you could e.mail me kathywhitfield365@msn.com if you did have any luck I would really appreciate it
Aug 09, 2010 | DeLonghi DEFSGG36 Gas Kitchen Range
Residential Electrical Wiring Current NEC
On a 120/240Volt single phase system is:
Black = 1st phase
Red = 2nd phase
White = neutral
Green or Bare = ground
3 phase is the same with the third phase being blue.
Jul 28, 2008 | Motorola 3-Wire Surveillance Headset...
Hardware
problem driver xp driver web page driver noooooooo i whant driver olympus c-3030 xp driver
my e-mail adres
john007silver@hotmail.com
pls send
Oct 19, 2007 | Olympus Camedia C-3030 Zoom Digital Camera
50 people viewed this question
jasbo
jasbo
