Question about Sony Computers & Internet
Mbx 247 new motherboard,new 4gb ram,new processor,good 19.5v adpter, but when i press the power button only the LED lights blinks without anything
  • 4 more comments
  • lamzy
    lamzy Mar 31, 2014
    EVERYTHING COLLECT,BUT NO BEEPS,JUST THE GREEN AND ORANGE BLINKING LED
  • darkstorm357
    darkstorm357 Mar 31, 2014
    this green and orange blinking color are all in the battery light indicator?
  • lamzy
    lamzy Mar 31, 2014
    yes
  • darkstorm357
    this indicates a shortage on your power supply. if you're using a 100a power supply it might tossed your board. check all the voltage that comes from your adapter and dc power jack first.
  • lamzy
    lamzy Mar 31, 2014
    SHOWS 19.0 OR 19.01
  • darkstorm357
    if this voltage come from your dc & charger it's fine. try to take out 1 memory at a time and boot up. please be patience with the procedures as we are diagnosing where is the short of supply coming from. thanks
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
Check all connection if they are properly installed. if you are having the right MOB and compatible processor and RAM it should work.
did you hear any beeps while booting?
thanks
Posted on Mar 30, 2014
  • 9 Answers
SOURCE: Tecra M2 doesn't boot is it a processor problem?
given the symptoms, it points to motherboard.. if it was processor, video or ram. it wouldnt boot at all and you'd just get error beeps from your laptop. i'd first try resetting the bios, by removing the bios battery for 30 min, then putting it back in. if that doesnt work try changing it out, usually costs under 8 bucks. if that doesnt work then I would change out the motherboard, if its cost effective.
Posted on Mar 03, 2009
jmgldsmth
  • 1869 Answers
SOURCE: no power when i press button...led fashes 8 times
remove and, reseat your memory if that doesn't help try disconecting your dvd drive hard drive(s) one at a time and, retest
Posted on May 24, 2009
frankzjm
  • 191 Answers
SOURCE: Will not boot up
this is motherboard hardware issue
1) first all you need take out all devices like HDD DVD, wireless card then try turn it on if noting yet
2) change RAM stick that you have done
3) check DC PWM standby status, like 3V/5V/1.8V which should be appear before power on.
if no 3V/5V DC output, check this PWM circuite like MOSFET or PWM chip.
if you find 3V/5V, so need check 1.8V DC output and 1.2V that chip fail also cause nothing turn on.
all steps need diagram check where the chips and componenets on your board.
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
Posted on May 27, 2009
  • 1019 Answers
SOURCE: red light on the front blinks 4 times
The 4 blinks are telling you that there is a fault. The same as Computer Bios Beeps.
I,d suggest removing the RAM/Memory, and replacing it. Press and hold the power button for more than 4 seconds, to ensure it isn,t in standby mode. failing this remove the cpu and re-seat it as it may be slightly out of position, or out of it,s socket. finally have a look at the back or underside to see if there is a reset switch/hole.
Mike @ Compurepair.
Posted on Jun 12, 2009
SOURCE: what is the fastest processor that a sony MBX-160
Take a look at the T2700 Intel(R) 2.33Ghz or the Intel(R) T7600 2.33Ghz chipset
Posted on Dec 19, 2009
No display & blink power led
This sounds like a power supply issue. Are the fans in the system plugged into the board? If so, are they kicking on and off at the same time at the power light? Make sure you have a good working PSU and tried that in place of the one you are using.
If that doesn't work, start removing parts until you have just the motherboard and the case speaker plugged in (plus your power button of course). Once you have removed the faulty device, you should start getting a beep code from the motherboard. If you put a known good part back in and it does it again, then the slot on the board that the part seats into is bad (IE: RAM slot if RAM replaced, etc) and you need a new motherboard.
Nov 18, 2013 | Foxconn G41MXE Motherboard
My system was working fine suddenly the MB is not booting or posting.and no display. Now I disconnected all the device except CPU ( AMD Processor) got the beep ...next connected RAM no diaplay HDD led no...
Double check cable from the motherboard to your hardisk likeIDE or SATA together with the power cord
just make sure if its fully inserted. boot up the pc press delete to check UPTHE BOIS IF THE HARDISK is connected. RAM( Random Access Memory) maybe defective. replace it to thenew one and boot up your desktop. sometimes if the onboard /vga, (video graphics adpter) are defective its also beepingrapidly. also try to clean up your ram using pencil eraser.
Feb 09, 2011 | ASUS K8V-MX Motherboard
Replaced Gateway 105552 Foxconn C51GU01 Motherboard with another
Are you sure it is a good MB? If so double check all connections and try again. If you still have problems post back and let me know if you are getting any beeps at startup.
Jul 07, 2010 | Gateway GT5058 Desktop PC
Have you guys heard of any problems with the Sony VGN-CR507E
Well this sounds like to me that it has spontaneously failed, (No LED lights no anything" (sic) during that "Updating" If you have NO led's then in all probability, the PSU has faulted. Maybe it suffered a Power Spike? Or Power Outage? In any event, try troubleshooting the power supply.
Apr 13, 2010 | Sony VAIO VGN-CR507E/Q 14.1" Laptop (1.86...
Gigabyte GA-945GCMX-S2 Motherboard having display..
At first I thought your screen went black during the start up process. After seeing the bios screen. In which case I would've said it was a bios setting for the display. Then I realized that I think you mean that their is no display at all. When you push the power button. Only the monitor led light. So, it may be a problem with your RAM stick/s. You should make sure that they are properly seated in the mother board. If they are new, make sure they are compatible with that motherboard. If you can you should swap them out with known good ram sticks. You could also try installing a video card and see if you can get display to work through that one. Make sure your main power supply wire connector is pushed in all the way. Swap the power supply with a known good one if you can. If still can't get it to work you may want to take the motherboard out and inspect it for burns, cracks, and anything that doesn't look right. Maybe contact the manufacturer of the motherboard and ask them what you can check. hope this helps.
Sep 17, 2009 | Gigabyte GA-945GCMX-S2 Motherboard
Memory Problems
you may have a compatible issue with the ram, your board bois may not support that manufavtures brand or coding of the chip set you are running. have some else try some other ram from another manufacture.
rod
Feb 11, 2009 | Sony MBX-49 ASSY Motherboard
Intel DG31PR Motherboard not booting
You could try reseting the Bios settings using the jumper of the motherboard after installing the new Rams. Anyways ,its working, so don't do that now :P .
"If some thing is working, don't try to fix it" :) .
Jan 28, 2009 | Intel DG31PR Motherboard
No Startup and Run
Probably the power supply, take it to a reliable laptop lab
May 03, 2008 | Sony MBX-49 ASSY Motherboard
Computers & Internet Logo
93 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
