Question about Kirby Ultimate G Bagged Upright Vacuum
No suction Let my son borrow it and came back broken. No suction. Belt is on. BAG DOES NOT INFLATE WHEN TURNED ON. Checked tube for clog and don't see one. Not sure how to take apart and/or how to fix if I do get it apart. Suggestions?
    Scholar:
  • 116 Answers
I presume the motor is running, take the front brush roller off and check the fan is still intact. Possibly broken fan.
Posted on Mar 30, 2014
    Problem Solver:
  • 11 Answers
There's two possible reasons for no suction on an upright if the motor is running. Either your fan is broken or your air passage is blocked inside the machine, not the hose. A vacuum will still have suction if the belt to the roller is broken, the belt runs the rollers, not the fan. The shaft that the belt is connected is also the shaft for the fan. Look inside and see if there are fan blades or are they broken off. If they are broken off then you will have to replace the fan unit. If the fan is in tact and is spinning, then you probably have a blockage. Check inside where you attach your bag. You may have to disconnect the hose that actually connects to the bag, or in some cases, that tube is clear so you can see blockage. If you cannot see through it, then simply take it off and look in both that tube AND the airway that feeds that tube. Either way, a broken or worn BRUSH belt will not stop the suction, that comes from the fan inside the vacuum housing. I hope this helps.
4 Suggested Answers
  • 134 Answers
SOURCE: kirby g5 suction problem
If its not picking up as an upright but does with the hose, youve either not connected the belt or the belt is broken
Posted on Feb 21, 2009
  • 57 Answers
SOURCE: Fix for broken tubing leading into filter bag?
You can replace the black tubing. There is no need to get a new vacuum. You can find the parts you need by following the link below.
http://www.usavacuum.com/Kirby-Generation-3-s/145.htm
Make sure to leave positive feedback.
Thanks USAVACUUM.COM
Posted on Mar 07, 2010
mmcdaniel106
  • 6 Answers
SOURCE: Need Kirby Generation 3 Vacuum cleaner manual.
If your brush roll is turning and your bag is not overly full, then the only other thing it can be is a clog where the bag connects to the vacuum. Turn the plastic part out away from vacuum and lift off to see if you have something clogging it. It would have to be something big, but not so big that it could not get past the fan. As a rule of thumb, KIRBY never clogs. I suspect that your belt is stretched out and your brush roll is not turning while on the carpet so the brush roll is just in the way rather than brushing your carpet to pick up dirt.
Posted on Oct 15, 2010
No suction/ bag doesnt inflate
Check for a clog in the base or in the handle tube.
Apr 05, 2014 | Oreck XL Ultra Bagged Upright Vacuum
My vacum will not pick up, it is spitting the dirt out?
Check for blockage.
Most likely place is in the tube leading up from behind the beater bar. While unplugged, remove beater bar & belt & check.
If you have a strong shop vac, remove beater bar, belt, and bag, applying suction to the tube in back of the beater bar will many times dislodge the clog with little effort, sometimes though it will take some fishing around with a stiff piece of coathanger wire or similar.
Normally when you can apply suction with the shop vac to the tube in back of the beater bar & feel suction at the tube were the bag connects, you know you've got it all and you should be unclogged. Put it back together and you should be ready to roll.
Feb 11, 2011 | Hoover Tempo Widepath Upright Vacuum -...
My Kirby seems to be putting more dirt on the floor than what it is picking up? The brush roller is turning but it leaves dust streaks . It also shoots particles out the side instead of vacuuming it up....
Hi there. It sounds like you belt may be stretched. Simple turn vac upside down, start it up and carefully press your hand on the brush. If the belt is stretched the rollewr will stop turning. If this does not help, you probably have a clog in the power head area. Hope this helps, Chris
Feb 09, 2011 | Kirby Ultimate G Bagged Upright Vacuum
Need Kirby Generation 3 Vacuum cleaner manual. Vacuum is not picking up dirt from floor. Seems to have enough suction to inflate the bag, but when you check the suction under the vacuum, there seems to...
Jun 08, 2010 | Kirby Generation 3 Bagged Upright Vacuum
The performance indicator light will not go out. I have cleaned the bag, filter and hose. there does not seem to be enough suction.
you are clogged somewhere ...
no suction?
performance indicator says no suction?
find and remove the clog.
id be looking in the hose about 4 inches from where the dirt enters the brush but dont limit your looking. The entire system should be checked for a clog. Remove it and you willbe back in business.
I have 'trash picked' more than 100 vacuums this summer, off the curb. 90 were clogged. I cleaned then and turned them into $.
Oct 13, 2009 | Vacuums
Kirby G4 will not suction the dirt up.
your fan area clogged or that area of the bag that you decribed.
Jul 05, 2009 | Kirby G4 Bagged Upright Vacuum
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Kirby g5 suction problem
Feb 17, 2009 | Kirby G5 Bagged Upright Vacuum
No suction
check the belt or the inside tube between the bag and the brush
Aug 11, 2008 | Dirt Devil M086700 Vision Bagless Upright...
Oreck Vacuum troubleshooting
Hi. If the motor is on its way out the motor noise will be eratic eg slowing down speeding up popping noise & a smell of electrical burning. If you have none of these symptoms then chances are its not the motor. Does the bag inflate or is it easy to collapse when you push the bag ? If bag inflates ok check belt. If bag not fully inflating check for blockages along length of the handle pipe its designed to pull apart by lifting up rubber sleeve at machine end of pipe, push ball latch in & pull pipe out remove any debris stuck in the pipe. Remove bbottom of machine as if replacing belt check to see if there is any debris stuck in the oppening that goes to motor fan, then check the fan blades you can see them through the port is there any missing or snapped off. If blades are missing or have big chunks missing you will need to replace. If fan only has minor bits missing then reassemble it should now worl well.
Sep 07, 2007 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
112 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
