Question about Motorola Mobility Elite Flip HZ720 Bluetooth Headset - Silver Original OEM 8950
My Motorola elite flip used to pair with my iPhone and I had no problems. Now it disconnects from my iPhone on its own in both the talk mode and standby mode... HELP
Will not pair with my iPhone upon turning it on, and when it does it will disconnect after a short time. It used to work fine. Now it does not.
  • Official Brand Answer
  • 1,623 Answers
Louis
I would contact Apple if you continue to have issues.
Mark
Motorola Support
Posted on Jan 22, 2015
  • 3,100 Answers
Louis
Have you unpaired and repaired it with your iPhone?
Mark
Motorola Support
Posted on Jan 17, 2015
SOURCE: Motorola H700 pairing
It's important to note that the pin has to be entered while the light is still violet. On the phone, begin searching for bluetooth devices. With the boom closed, hold the center button until the light turns violet, then immediately flip the boom open. The phone should immediately find your H700. However, to pair successfully, you must enter the pin (0000) while the light is still violet. If the light goes off, close the boom, enter 0000, and while the phone says processing, hold the center button until the light turns violet and flip the boom open. The light on your H700 will turn blue, then flash rapidly, and your phone should say that it has paired successfully.
Posted on Sep 14, 2008
ziraffa
  • 827 Answers
SOURCE: HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Posted on Dec 22, 2008
SOURCE: Motorola Bluetooth HS850 Pairing Mode
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
Posted on Jun 04, 2009
Badchariot
  • 3 Answers
SOURCE: How to pair Motorola H12 with iphone?
I just figured it out myself!!
here is how:
1.) press your home screen button at the bottom of your iphone
2.) open settings
3.) go into your general settings (same gear picture as home page)
4.) touch to open bluetooth
5.) turn on your H12 headset and place close to your iphone
6.) turn on bluethooth on iphone and it will automatically find the headset
7.) touch the motorola H12 button and it will enable the connection
Posted on Jul 08, 2009
  • 23 Answers
SOURCE: H710 won't go into pairing mode
sounds like its already connected to the iphone but it won't establish them. Delete the pairing from the phone then repeat the process.
Posted on Aug 19, 2009
Why does my Elite Flip keep switching back and forth between paired and unpaired?
Hi Corinna...
You can try a reset. Here are the instructions:
ELITE FLIP Reset to factory default
Best Regards,
Katy
Motorola Support
Apr 12, 2015 | Motorola Mobility Elite Flip HZ720...
What causes an echo problem with Motorla elite flip paired with a Samsung
You should not have an echo. Can you try pairing with another phone to see if you have the same experience?
You may try resetting the headset ( ELITE FLIP Reset to factory default )
Mark
Motorola Support
May 31, 2014 | Motorola Mobility Elite Flip Bluetooth...
My bluetooth isnt synced to my phone and it isnt. how do i restart the process so that it syncs to my phone??
I have the H715 but my iPhone only showed the H721 instead of the H715. I selected the H721, entered the passcode and connected. Called my home phone with the earpiece in and it works.
From user guide and other user comments...
Make sure the H7xx is fully charged up (not necessary but you'll probably begin to immediately use it and it would be bad to have it discon because the battery is dead). Turn off the H7xx (the ring around the talk button should not be flashing blue every few seconds), push the talk button, thats the oval button on the face of the headset, for about five seconds, until the ring around it displays a purple color. Immediately let go of the button and flip open the tiny microphone extension. Now it's in pairing mode and you can leave it while you fiddle with the iPhone.
From the iPhone main menu, select the "Settings" button, then in the Settings menu, select the "General" option.
Touch the "Bluetooth" menu item on the General menu. when the next screen appears, if your Bluetooth is already turned on it will start looking for (discovering) your H7xx. If Bluetooth is not turned on, slide the gray button so it displays "on" instead of "off". Your iPhone should now start discovering your H7xx. It should automatically find your H7xx, then display another screen that prompts you for a code. According to the manufacturer's guidelines, the H7xx requires you put in "0000" that is 4 (four) Zeros as the code.
If everything went well, the "Bluetooth" screen should be displayed again and the Motorola H7xx should show up under the word "Devices" showing that it is Paired.
Your H7xx should now also blink Blue around the talk button.
If things didn't go well. I suggest navigating back to the bluetooth menu. Turning bluetooth off on the iPhone. Flipping closed the microphone boom on the H7xx and starting over again. I had to do it twice because I fumble fingered the 4 zeros.
NOTE: it is not necessary to have the H7xx right on top of the iPhone, but I'd have it within an arms reach, just to be sure you get a good signal and you actually pair to your Bluetooth headset.
Once the iPhone has discovered the H7xx if it continues to state "Not Paired" simply tap the Motorola H7xx box and it will take you to the next screen. Enter "0000" as the security code. The iPhone should now successfully pair with the H7xx.
Apr 01, 2011 | Motorola Mobility H700 Wireless Headset
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Instructions
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
Feb 23, 2011 | Motorola Mobility HS850 Consumer Headset
For some reason, My Motorola H700 quit going into pairing mode? No matter what I do I can't get it to go into pairing mode. I have a Motorola Droid, and have had it connected to it before, but now it...
I have had this problem as well. Just to recap the problem. When you push the talk button and it turns purple, then you flip the speaker boom the unit starts flashing blue and will not pair. If this is the case then you should try unclipping the ear piece on the unit. Then repeat the pairing feature on the unit only this time hold the unit open with additional force. Not so much that you break the speaker boom, but enough to help the unit make a connection when it is flipped open. The problem with these units is that sensor inside does not always make a good connection especially after time and use. This should resolve your problem.
Curtis
Jun 04, 2010 | Motorola Mobility H700 Wireless Headset
Discovering a Motorola H721 headset on my Iphone
open the boom flip. Press and hold both volume buttons and the call button for more than 10 seconds. The indicator light flashes 3 times and then becomes steady lit. The headset is now in pairing mode.
Nov 26, 2008 | Motorola Cell Phones
Is H700 compatible with the iPhone?
Here is a straightforward procedure to "pair" the Motorola H700 bluetooth headset with an iphone
1. Turn off the headset by folding the microphone.
2. On your iphone, go to settings-->General-->Bluetooth-->tap tp turn ON
3. To activate your headset, hold down the center button and keep it pressed while you fold out the microphone.
The iphone will immediately detect the device and state "not paiired"
Ignore this message and go ahead and tap on the headset menu displayed on th eipjone screen. You will e prompted fot a security code. Please enter 0000. The iphone will confirm that the devices have een paired successfully.
You arer done! To verify, try placing a call from the iphone and you will see a new menu on iphone asking you to choose the headset H700 or speaker phone.
Step 3 is the most important step in getting the two devices to talk.
Apr 23, 2008 | Motorola Mobility H700 Wireless Headset
Motorola Mobility Elite Flip HZ720 Bluetooth Headset - Silver Original OEM 8950 Logo
100 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
