Question about Sanyo Split System Air Conditioner
Error c5 C5 apearing on indoor unit what will i do?
  • Sanyo Master
  • 1,249 Answers
C05 error indicates no communication between indoor and outdoor units and remote control. Replace the remote batteries with fresh duracells first. If that doesn't fix the problem, verify the indoor and outdoor unit are wired together properly. If still no love, a tech will need to come visit. CALL SANYO TO SCHEDULE A TECH IF NEEDED. Mini-split units are new to the industry, and not all HVAC techs are good at fixing them.
Posted on Mar 30, 2014
Turn on LG aircon inside house. Goes for a short time them c5 comes up on screen and the aircon stops. Compressor has been noted to start and stop
C5- Indoor to put door communication problem.
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Dec 31, 2010 | LG LSC121PMA Split System Air Conditioner
We recently had a flood go through the house and now when we turn the air conditioner on it displays c5 what does this mean?
C5 Indoor malfunction of gas pipe thermistor. Check amps of your unit .If very less than specified, it's gas leak. If only little difference and having freezing blow, it's coil and blower wheel dust blocked. Service the unit completely and run the unit.
If gas leak call repairman to find leak and arrest and then recharge gas.
Hope it's helpful. Thanks,.
Dec 25, 2010 | LG Heating & Cooling
Our Evaporative A/C stops and we get Error C5 can any body help
Hello
Error c5 is a communication error,between the inside and outside unit.
Check your condensate pump operation,float should move freely and unit should not be full of water.
Another possibility is faulty wiring from your outside unit to the inside.
Try taking all power away from unit for 5 min and then turn on to see if it will reset.
If this doesnt work call for service.
Jan 31, 2010 | Heating & Cooling
On our Ep3170 we get a C5 error code and the wrench symbol
Hello sir;You must remove the left side panel to access the service switch(s1) on PWB A you press this switch to chose the "C" then enter 0 press "#" ,then press "CLEAR" to terminated.
Jan 17, 2010 | Minolta Office Equipment & Supplies
I have a art col air conditioner and it has come up c5 can you tell me what this means thanks
C5 = COMMUNICATION BETWEEN THE INDOOR P.C. AND THE OUTDOOR P.C. MISSED. In other words, there is a bad connection in the indoor outdoor cable, possible cause - rats.
Nov 14, 2009 | Heating & Cooling
Green light beeps 5 times,c5 error, any quick answer to fix this ?LG multi type room, 4 mths out of warranty!!
this is a communiction error between the indoor and outdoor units, may be as simple as a loose connection or could be a board failure. these units can be quite complicated. may want to call service company
Nov 09, 2009 | Heating & Cooling
Air conditioner shuts off
C5
Communication Error
• Wrong or missing wiring between indoor and outdoor unit cable
• Defect of communication components in indoor pcb assembly
• Defect of communication components in outdoor pcb assembly
• Defect of power supply components in outdoor pcb assembly
• No ground connection in air conditioner unit
(affected by noise in power source)
Jun 30, 2009 | LG Heating & Cooling
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
C5 error on GE Profile dishwasher
C5 - Low Water Fill - This error usually indicates bad water inlet valve. Check for low water pressure to unit.
Dec 21, 2008 | GE Profile PDW8400J Built-in Dishwasher
GE profile Dishwasher gives an error: C5
Dec 21, 2008 | GE Dishwashers
Sanyo  Split System Air Conditioner Logo
518 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
