Question about Frigidaire FAFS4073NW Affinity Series 3.8 cu. ft. Capacity 27" Wide
Can't put6 dispenser back in
Unable to replace dispenser back in drawer
  • Official Brand Answer
  • 2,267 Answers
Hi Paulette, this is AP
I understand you are having difficulty reentering the dispenser drawer on your Frigidaire front load washer. On this particular model, FAFS4073NW, the dispenser drawer has a lock tab in the left rear corner of the drawer cavity. You must push this lock tab down before sliding in the drawer, reversing the process you used to remove the drawer originally. Make sure you look in the entry way of the drawer so that you are lining up the track with the dispenser drawer tracks. I hope this information proves helpful to you, thank you for the post.
Thanks,
Posted on Apr 01, 2014
The powder will not dispense. Water is getting in because the powder is wet and clumpy but is still left in the dispenser.
I suggest you remove the soap dispenser drawer and thoroughly clean it, ensuring that the outlet at the back of the drawer where the water and soap feed into the machine are completely clear of any soap buildup.
Before you replace the drawer, ensure that the water feed into the drawer (this is a pipe or tube above the drawer slot) is not clogged with soap.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I accidently poured my fabric softener in my bleach dispenser!!. I'm not an idiot--I just took migraine med. & I guess my head was fuzzier than I thought!! What should I do?
Pull the dispenser drawer forward until it stops. Push the tab down at the back side of the drawer to allow you to remove the drawer the rest of the way out of the machine. Dump out the dispenser drawer, re-install dispenser drawer.
Sep 25, 2010 | LG WM-2277HW Front Load Washer
My Frigidaire front load washer will not dispense the fabric softner during cycle.
Clean the dispenser drawer if water is introduced into the fabric softener cavity but does not dispense. Pull the dispenser drawer out until it stops and push down the release tab marked "PUSH" and then pull the dispenser out completely.
Lift the dispenser drawer cover and clean the tubes both in the dispenser drawer and the cover.
Turn the drawer over then release the conveyor from the tabs and lift it off. Clean the conveyor and the drawer thoroughly.
Snap the conveyor into the tabs back into position and then reinstall the dispenser cover making sure the tubes are properly seated.
Slide the dispenser drawer back into the drawer opening while pushing down the part marked "PUSH".
Let us know if the fabric softener dispenser still does not dispense while both the detergent and bleach dispensers dispense.
Mar 10, 2010 | Frigidaire ATF6000ES Front Load Washer
How to clean fabric softner dispenser sear 70 series cc3815443
hi friend,
step 1
Pull the dispenser drawer out until it stops.
  • Step 2 Reach into back right corner of the drawer opening and press the lock tab to release the drawer. Pull the drawer fully out of the washer.
  • Step 3 Lift the fabric softener dispenser cup out of the drawer.
  • Step 4 Run the fabric softener dispenser cup under warm water while rubbing it with a soft cloth or sponge.
  • Step 5 Place the cup back in the drawer and slide it back into the washer.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • You can also remove and clean the prewash, detergent and bleach detergent cups by following Steps 1 through 5.
    hope this helps u
    please rate me.....................
    thank u for using fixya
    regards
    sivaranjini
    Nov 30, 2009 | Washing Machines
    Fabric softener not draining
    Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
    May 23, 2009 | LG WM1814CW Front Load Washer
    Tablet drawer,dispenser wont open at all
    Hi, well you we need to check the ribbon cable in the door lining to make sure that none of the cables have been broken with the movement of the door. If they are fine then you should replace the dispenser unit if you are getting 240v to the dispenser solinoid.
    Get back if you have further problems...................?
    Mar 07, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
    Unable to open the dispenser tray
    Do you mean pull out the dispenser drawer so that you can remove it from the machine?
    Nov 19, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
    Cleaning dispenceser drawer can't open
    Unfortunately the screws which hold the dispenser to the machine are located behind the drawer which at present you are unable to open. As you say you have the top cover off, you might try shining a light into the top side to see if you can see where the hang up is, and then drilling a small hole in the plastic and poking something through to move or dislodge the blockage. A small hole could be resealed with foil tape or silicone, or the dispenser housing replaced once you are able to remove the drawer and access the mounting screws.
    Nov 14, 2008 | LG WM-2277HW Front Load Washer
    Detergent dispenser drawer stuck
    You may have to remove the washer top (three phillips screws at the back, then push top back about two inches and lift it off) then drill a hole in the top of the plastic dispenser to allow you to use an object like a screwdriver to maneuver the offending part around so it will drop down and allow you to open the dispenser drawer. Use foil tape to seal hole if you don't want to buy a new dispenser. Clean out blue plastic dispenser parts so detergent will siphon out completely. Pushing down on the center tab at the back of the dispenser should allow you to take the dispenser drawer the remainder of the way out. In the future, make sure you do not use over 1 tablespoon of HE soap (and 1 teaspoon of fabric softner) max per load. Even less if you have 2x or more detergent.
    Oct 11, 2008 | LG WM-2277HW Front Load Washer
    My detergent/softener pull out drawer is stuck!!! need help please!
    This problem has just started popping up for me as well.  I believe that the problem is in the dispenser assembly where the drawer slides into.  You will have to pull hard and possibly may break a part of the plastic drawer to open it.  The dispenser assembly looks like it is bowing in the middle and jamming up against the dispenser drawer.  If it jams up like that, you may need to replace both the drawer and dispenser assembly togther.
    Jan 06, 2008 | LG WM-3677HW Front Load Washer / Dryer
    Frigidaire FAFS4073NW Affinity Series 3.8 cu. ft. Capacity 27" Wide Logo
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
