Question about Radio. 12/20-Volt MAX Charger and Radio DCR015
How do i charge my phone
I am trying to figure out how can I get my phone to charge while hooking my phone up to the usb located on the radio. thanks
    Master:
  • 435 Answers
I would be sure the DeWalt is plugged in and, turn my phone off or put it into standby mode and plug it into the unit. It should do it all on it's own if everything is working and your nothing is damaged, like the cord you're using. Mine doesn't have a switch or anything, but since I don't know what model you have, you might look to see if you need to flip a switch, which I doubt.
Posted on Mar 30, 2014
I cannot seem to charge my JVC Everio camcorder. When I use the USB and hook it to my computer, the light flashes as if its charging, but the camera won't turn on. Any ideas?
Measure the voltage on the battery. If you don't have a volt-meter have a guy in Radio Shack do it. Probably have a dead cell that is drawing down the charging voltage. Try taking the battery out and use the camcorder with the AC connected.
Dec 30, 2014 | JVC Video Cameras
How can I get our 2011 Suzuki Kizashi to accept a USB cable to enable our portable XM radio unit to work? It currently states: "Not Supported" each time a usb is hooked up to the portable XM unit. (On
I believe the USB socket your Subaru is only a charging port and does not really hook to the radio. This would require more than I know how to do, unless you can enable bluetooth on the car and your XM will work that way.
Dec 12, 2014 | 2011 Suzuki Kizashi
Sony xperia x10 went dead wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 12, 2012 | Sony Ericsson XPERIA X10 Cell Phone
Just purchased lg cell phone ,can't figure out how to charge . it-- thanks patricia
hi.
there should be a charger in the package, and possibly a usb cable.
plug the usb cable into the charger and then plug into your phone's usb port.
Jun 30, 2011 | Cell Phones
On a car radio that has a usb port will it charge the phone, and will you be able to play the music on Pandora through the car radio?
Most likely not. Its software needs to be compatible with your phone. If it has an 1/8th inch audio female jack then you can hook your phone up via 1/8th inch audio cable.
May 01, 2011 | Sony Car Audio & Video
TRYING TO HOOK UP HEADPHONES,IS IT CAPABLE.
Hello, IF your tv is capable of using headphones it will have a little jack with a head phone symbol over it or under it most likely. IF not you can buy a home theater system which would hook up to your tv and some of these have an option to hook up headphones or even ipods and usb devices.
the greek
May 31, 2009 | Sanyo DP19648 19 in. LCD TV
Sylvania ipod..batter charging
I called the company tech line..after some discussion it was determined that I must have a defective unit and I will return it to Walgreens.
Thank you
Deb
Jan 08, 2009 | Audio Players & Recorders
Motorola RAZR V3
Install Motorola Phone tools first,it contains all drivers for all Motorola phones,plug the cable and charge
Sep 16, 2008 | Motorola Mobility RAZR V3
Phone off hook but cant locate
here's a little trick you can try to find your phone.take a radio and put it up to the mouth piece of one of your other phones and turn it up loud. but not too loud. this phone should be on talk mode.walk thru each room of your house when it's quiet, and listen for the radio. if the phone is off the hook, you should hear the radio enough to find the phone.
let me know if it works.
wg
Feb 17, 2008 | Uniden Cordless Phone
Radio. 12/20-Volt MAX Charger and Radio DCR015 Logo
48 people viewed this question
Top Dewalt Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Dewalt Vehicle Part and Accessory Expert? Answer questions, earn points and help others
