Question about Emerson Televison & Video
Ten year old emerson 27" flat-screen tv has multiple thin white horizontal lines and has audio
My ten year old 27" Emerson flat-screen TV has multiple white thin horizontal lines across the screen. At times, it is nothing but nearly solid white "fog." The audio is perfectly fine at this point. What kind of repairs does it need? I particularly like the close caption features of it, and I do not have tools to do soldering or things like that. It is very heavy and not really feasible for me to carry, as I have physical disabliliies. COuld you please help me figure out how to fix my TV? Thank you so much!
    Top Expert:
  • Emerson Master
  • 74,136 Answers
Backlight CCFL lamps fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Mar 31, 2014
freetek
  • 5568 Answers
SOURCE: Emerson flat screen tv with red stripe
The pixels on your screen are controlled by a matrix composed of switches that turn off and on to produce light.
They are located vertically and horizontally, row-wise and must function together to produce everything from black (everything turned on so no light, or very little, can escape) to layers that represent the three colors that are used alone or in combination to produce the millions of possible shades of each.
One of the switches that controls one of the vertical columns has failed and has turned on the entire column that allows red to display.
The problem switch (a semiconductor combined with many) is permanently turned on, probably part of the screen assembly itself, and was placed with others by robots.
The pin spacing on these 'chips' is very small and often makes the assembly unrepairable.
While LCD panels have fallen hugely in price, you may be looking at a parts cost (labor is probably not too bad) that may make you decide to replace the set.
Unfortunately, the once-proud Emerson name has sadly been degraded and there is a lot of their electronics available from companies that specialize in 'refurbished' products, an indication that they have a large failure rate.
Posted on Jul 07, 2008
SOURCE: Emerson 20 inch flat screen tv problem
i had the same problem with a 32 inch and i kept "clicking" the channel changer on the remote to force the tv to go to another channel (that had previously been selected during the initial auto scan) --- still trying to figure out why the tv locks onto the scanning for channel
Posted on Sep 09, 2008
SOURCE: emerson remote control with vizio 37" tv
Try 004, it worked for me
Posted on Jan 08, 2009
  • 10 Answers
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Posted on May 23, 2009
dsacco86
  • 1077 Answers
SOURCE: Emerson LC320EM82 S LCD TV I purchased this TV a
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
11e1946.jpg This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
Posted on Jun 18, 2009
Thin white horizontal line in the center of the screen when the tv is on.
Hi Tim,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 22, 2015 | Emerson Televison & Video
Emerson lc260em2 horizontal lines in screen
Sounds like T'Con board fault. A fault to panel too can cause this. Contact any service technician to make it confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Line faults to LCD TVs are given with illustrations.
Jul 19, 2014 | Emerson LC260EM2 26" LCD TV 1366x768, 60...
Picture parts
Flat panels tv's use memory to paint picture on the screen. If the chips are bad, you'll see lines, checkers etc.
Dec 30, 2013 | Emerson Televison & Video
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
My 27 inch emerson flat tube tv only shows the picture in a thin strip how do i fix it back to normal
You will need to replace the Horizontal IC around $80 bucks for the parts and labor. What happen here is when the Horzontal ic gives out the screen basically folds to the middle. Do not shoot the messanger here but have the TV looked at by a professional locally.
I hope this was Very Helpful to you today please leave your feedback and ratings.
Dec 07, 2009 | Emerson EWF2703 27" TV
There is only a 1" horizontal line on my tv screen.
This is a problem with the vertical circuit and is either the vertical IC or a few capacitors that have failed in the same circuit. If you can solder you should be able to fix this yourself. The part cost will be in the $20-$40 range.
Update this if you wish to attempt the repair and I'll supply additional details and instructions.
Dan
Aug 22, 2009 | Emerson EWF2703 27" TV
I have a 37in LCD Emerson tv and there is a division line in the tv. Top is normal bottom is dark. How do i fix it
sounds like a failed backlight or inverter.
larger LCD sets use multiple lamps horizontally across the screen.
Dec 03, 2008 | Emerson EWL3706 37 in. LCD Television
Televison & Video Logo
117 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
