Question about General Electric GE GSS25GFXWW (25.0 cu. ft.) Side by Side Refrigerator
Ice cube ejector bar keeps freezing preventing ice from ejecting to tray
I just replaced my ice maker. The water fills the tray but the arm with the wings that rotates to eject the cubes keeps getting frozen in place. I have defrosted with hair dryer but it keeps happening
  • General Elec... Master
  • 842 Answers
Replace your water valve part # WR57x10032, from what you have listed above you have a bleeding water valve allow water to enter the ice maker mold. The valve is not closing completely. This part show fix this issue for you.
Good Luck
Posted on Mar 31, 2014
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: ice maker has made only
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 07, 2011
Freezer wont make ice cubes
This is not difficult to troubleshoot.
  • When the arm is up the ice maker is off
  • When the bucket is full the arm is up the maker is off.
  • If the ice maker has a on/off button in off the ice maker is off
  • If the ice maker internal heater fails the cubes will not release and the white plastic ejector arms will be rotated CCW and pressing against the ice in the tray, Normal position for ejector arms is vertical.
  • If water solenoid has failed or water supply not available the ice maker will cycle. The ice tray will be empty,(hard to see if ice tray is empty). Check and replace water fill solenoid.
  • If ice in tray and ejector arms vertical several possibilities.
    • Freezer not cold enough to trip thermostat in ice maker to initiate release cycle.
    • Check freezer temperature <10 Fahrenheit thermostat in ice maker failure
    • Ice maker motor failure,
    • Internal ice maker electrical connections rotary switch failure,
    The best way to check the operation is to manually lock the arm up into the off retention position. Wait a minimum of one hour. Open door and release arm down. Observe the operation of the ice maker. Is after a minute or so the ejector arm does not rotate then it is likely the ice maker has failed internally. If the ejector turns and no ice than you can assume either the water supply is off external from the refrigerator or more likely the water solenoid located behind the bottom back cover has failed. It is also possible that the hose that connects the solenoid to the ice maker has frozen right where it enters the freezer just above the ice maker. You should see ice built up at the entrance where the water fills the tray if this has occurred.
Ice Maker Repair
Dec 22, 2015 | GE Monogram Side by Side Refrigerator
My ice maker was making noises and I looked at it and a piece of ice was obstructing the ice ejector. I removed it and it worked fine for a week. Now it fills with water, freezes, but they are not...
there are plastic arms on the ice maker,sometimes they bend and get jammed or when the ice got stuck it did damage to the motor and it finally died,if it's filling,a heater on the ice maker comes on,loosens up the cubes,the motor turns and dumps out the cubes,it sounds like you have a bad ice maker
Mar 29, 2011 | Jenn-Air JCD2295HES Side by Side...
Ice maker does not run. Tray fills with water and ice freezes but the cubes are not ejected into the tray. Wire loop is down.
You will probably need to replace your ice maker. There is a heater on the bottom that seperates the ice cube from the tray. More than likely this heater is defective, but it is all internal to the ice maker so you will need to replace the whole unit.
Oct 25, 2009 | Refrigerators
My Kenmore S106 626636 Ice Maker is not producding ice.
You probably have the back side of the I/M hitting the fill tube and pushing the white cup at the end of the I/M in some, which would put pressure on the arm and not let the arm fall down free during a cycle.
Sep 05, 2009 | Kenmore Refrigerators
Roper Ice maker wont kick ice cubes out of tray.
Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
Apr 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
JCD2389GES
I removed the entire unit again, looked at it, removed the front cover, and decided I wasn't going to take anything else apart. When I reinstalled it in the refrigerator, it started working again. Possibly the wire connectors just needed plugging in the clean them again.
Tomas
Jun 29, 2008 | Jenn-Air JCD2389G Side by Side...
Ice maker will not push out ice cubes once frozer
That means that the evaporator fan system that releases the the ice cubes is not working as it should.
The heater, or evaporator fan and heating system must be checked, and fan, or solenoid, or element must be replaced.
Use the number listed on the owner manual if you want to call a technician.
Enter model number on this website to find schematics and replacement parts.
May 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Frozen ejector arm
sounds more like the heater in the ice maker is bad. The cycles of the ice maker are: 1. water comes in to fill ice maker. 2. water freezes in ice maker making. 3. heater comes on to help ice release. 4. motor comes on to eject the ice and start all over again. if the heater doesn't come on the ice will not eject. replacing the icemaker is typically what needs to be done in this case.
May 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
General Electric GE GSS25GFXWW (25.0 cu. ft.) Side by Side Refrigerator Logo
88 people viewed this question
Top General Electric Refrigerators Experts
Dan Webster
Dan Webster
Darrell
oldsquare1
Level 1 Expert
Are you a General Electric Refrigerator Expert? Answer questions, earn points and help others
