Question about Conair Simple Cut 12-Piece Haircut Kit, Model HC108GB, 1 ea
Replacing blade in conair HC108RGB
Cant figure out how to get the cutting blade back in properly
5 Suggested Answers
triloberto
SOURCE: Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
Posted on Jun 07, 2009
  • 10865 Answers
SOURCE: Need replacement blades for hair trimmer
Hi. Order them from Conair: customer service representatives will be happy to help you. Please call 1-800-326-6247 for a Conair appliance.
Posted on Mar 25, 2010
SOURCE: I purchased the conair trimmer model GMT175W I
Just twist and pull backward on the tip where the seam is. It does kind of feel like you're going to break it, but it won't--it is made to snap off like this.
Posted on Jul 12, 2010
d_duffer
SOURCE: Need the plastic part on the blade, that are
I have a Conair GMT180 Beard trimmer, blades have become dull, and it is pulling hair instead of cutting them... Where can I get blade(s) for it and how mmuch including Shipping..... Please respond by sending email with purchase link to d.duffer@insightbb.com
Posted on Nov 20, 2012
Replacement blades for conair hair clippers hc114wv
I have a Conair HC114WVR and I took the blades off to clean the hair out. It's not that old, but when I put the blades back on they vibrate to a point of grinding. I can't figure out what I need to do to get them back on straight.
Jan 25, 2014 | Health & Beauty
The trimmer is not cutting the way it should, the bottom blade seems out of place and I cannot put it back in place
Conair trimmers are only good for about a year and they are hard to put back once you have messed with them. does your blade pop off or does it have two phillips screws holding it in? If you take the blade off completely you should see two arms that are in there, you have to place the blades back on correctly and hold them together while putting the screws back in. be very careful not to tighten the screws too much. Oil your blades with 3-1 oil and then turn them on. adjust the trimmer and see if everything is level, if it is try cutting withem and see what happens. If the motor sounds good but the blades are pulling your hair rather then cutting it then you need to replace your trimmers because your blades are daul.
Oct 05, 2010 | Conair HC100RCS Hair Trimmer
I purchased the conair trimmer model GMT175W I purchased it second hand and don't have the manual the small blade was attached and I can't figure out how to attach the larger cutting head. Can you help me?
Apr 11, 2010 | Conair Deluxe Rechargeable Beard &...
Mar 23, 2010 | Conair HC117 Hair Trimmer
I bought a 19 piece and i can't cut my hair
It soulds like the blades are too far back. There is an adjustmebt piece to the right or left of the blade that is about 1 1/2-2" long and it slides forward and backwards.
Ths will adjust the blade depth. It sounds like the blades may be set too far back to cut your hair, this has to bring the 2 blades together so you have much less free edge on one side, so what you do is slide ths blade by adjusting the handle and bring the blades to just where one side is slightly shorter than the other less than 1 cm. Then make sure the guard is off and slde the adjustment head is set and then try it agan. Unusually it is the problem if it does not cut or the blades have come loose. Hope that helps.
Apr 05, 2009 | Conair HCT-426 Hair Trimmer
Clipper Blade
the bottom blade has to be put back in place. Unscrew the two top screws and remove the top blade. fit the the bottom blade on the plastic piece. Replace the top blade and screws
Mar 19, 2009 | Conair HC100RCS Hair Trimmer
HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
Feb 01, 2009 | Conair HCT-426 Hair Trimmer
Cleaning Conair Simple Cut haircutter
Go to a Sally Beauty supply and purchase a can of the blade wash. It is relativly inexpensive. You dip your blades into ths special wash and it cleans the blades and keep them sharp and is safe. DO NOT take the heads apart, Let the pros do that but blade cleaner you immerse them in and trust me it is what we pros use.
Jan 20, 2009 | Conair HC91CS 10 Pc. Haircut Kit Hair...
Wahl 9765-301
if you put oil on the blades does it help if you remove the blade you should see the pivot what make the blades moves hair preventthe blades from moving freely after if it still weak motor is weak not mush to do with that pricewise better by andnother one cheers
Jan 30, 2008 | Wahl 9765-301
Conair Simple Cut 12-Piece Haircut Kit, Model HC108GB, 1 ea Logo
383 people viewed this question
Top Conair Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Conair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
