Question about Barbie Potty Training Taffy Nikki Doll and Pet Playset
2 bones stuck in the dog
Have managed to get 2 of the bones out of the dog but there are still 2 bones stuck in the dog. cant get them out. its affecting the mouth mechanism and keeping the jaw open. have tried gently shaking it and nothing. can hear them in there. please help as only had this toy 2 days
  • Jodie
    Jodie Apr 16, 2014
    I got the same problem! Did u get them out after?
Yamaha r1 1999 need a video how to install a dog bone
try posting to Motorcycles..??????????? this is cars... sorry.
is utube search busted>?
btw love the bike, id never get one because id be dead first hour.
zillion miles on bikes mostly offroad, big time.
my street bike was BMW1977R100s. a torque monster. a classic in mint condition, btw.
my guess you are using slang for the front fork braces?
top or bottom, i guess top.
depends on options, is this got air fittings on top?
so its off already so you didnt take it off, this a basket case (done many)
post a photo so others can see where you are, process wise.
on mine, you put it on, and then set up perfect alignment then torque down the clamps and put on top cap.
most bikes. The bike has and FSM book an its in that book.
this dog bone
or rear dog bone
or the damper dog bone on some.
rear
http://i.ebayimg.com/00/s/NDgwWDcyMA==/z/yUcAAOxyf1dTJ4qQ/$_3.JPG
as you can see dog bone means , near nothing.
a stip of metal with 2 holes.....
stock parts, OEM parts.
aftermarket parts?
what?
May 11, 2014 | Cars & Trucks
I want to buy a dog bone charm for my dog but wanted something a bit more colorful. Any ideas?
When I was looking for dog charms I came across this website - doggievogue and found some really cute stuff. Check out this link to a dog bone charm that comes with colored rhinestones. http://www.doggievogue.com/category/collar-charms-dogs/crystal-bone-dog-charm
Aug 26, 2012 | Anima Pets - Others
What type of bones is safe for dogs to play with?
When buying bones for your dogs, you should select large sterile bones from either the pet store or grocery store. Small bones and cow hooves should not be given to your dog because they are dangerous.
Aug 23, 2012 | American Plastic Toys Dogs
Should animal bones and hooves be given to dogs as treats?
No. Animal bones and hooves are dangerous for dogs as they can break their teeth. Two most harmful bones are cooked bones and poultry bones. Make sure your dog never get these.
Aug 13, 2012 | Dogs
Dog bone location
Remove the top dog bone & either pull the motor
toward the front or radiator & block it, or go to amazon
& buy the tool that bolts into the dog bone mount & screws
closed, bringing the motor forward
You could make up something if time isn't an issue
Jul 27, 2012 | Pontiac Grand Am Cars & Trucks
Is it dangerous for my dog to eat bones?
Yes, in mostcases it is advised that dogs do not eat bones, especially cooked bones! Thoseare a big no no! For more information on health-related risks when eatingbones, take a look at these websites: http://dogs.about.com/od/faqs/f/bones_for_dogs.htmand http://www.fda.gov/ForConsumers/ConsumerUpdates/ucm208365.htm.
Jul 18, 2012 | Dogs
No dog bone or opperating manual
Here is the PDF of the manual cant help you on the bone, sorry
http://www.hasbro.com/common/instruct/67323.pdf
Aug 03, 2011 | Hasbro Oye Mio Pup
Need diagram for 1997 toyota camry 2.2 timing marks
Quick fix timing TDCproblem 0. Jack up car on passenger's side, block up for safety. 1. Remove tire #17 lug bolts
2. Remove skirt #10 2 bolts
3. Set crank to TDC "0" #17 bolt on crankshaft. 4. Loosen Power steering pump adjuster bolt #14 remove beltoff pulley. 5. Push PS pump back to fire wall far as possible. 6. Remove both bolts lower dog bone #14 bolts. they are a dog to get off.
6b step one withbraker bar get them loose. 6c Get smaller 1/4" socket wrench to fit on it. #14 1/4 to slip on it in a tight place. 6d Removebolts. Put in lower bone bolts in a cup for i.d.
7. Remove upper dog bolts. Put it upper dog bone cup. 8. Take out dog bone. parts 9. Remove bolts holding in upper timing belt cover. put intiming belt cover cup. 10. Remove upper timing belt cover. Yellow 11. unlock tichner #14 push down on tinchner lock it to makeloose belt. remove thespring with needle nose pliers if it makes it eazy. 12 MOVE CAM TO SEE THE HOLE AND THE ROUND HOLE BEHIND IT,NOT THE OTHER MARK.AS THE BOOK SAYS. THE ROUND HOLE IS ABOUT 5DEG BEFORE THESLIT MARK THAT YOU DON'T WANT TO USE. 13 SLIP THE BELT BACK ON CENTER THE TENCHIN ON THE BELT INBOTH DIRECTIONS FROMTHE CAM SHAFT. ONE TOOTH BACK OF FOWARD RECHECK CAM ANDCRANK MARKS. TIGHTEN IT UP TIME. 14 RELEACE TISHINGNER, TIGHTEN BELT PUSH CAM TO THE LEFT. TO GET TIGHT INBOTH DIRECTIONS TEST FOR PLUCK TONE. 15 START UP CHK TIMING WITH LIGHT. 16 BUT POWER STERING PUMP BACK TIGHT. 17 PUT TIMING COVER BACK ON 18 REINSTALL DOG BONE 19 PUT SKRIT BACK ON 20 PUT TIRE BACK ON. TEST IT ON 3 TRIPS.
Oct 13, 2010 | Toyota Camry Cars & Trucks
A 15 month old baby kisses with her mouth open to everyone in her family even the dog. The dog is a big dog that dwouls.The baby open her mouth and the dog licks her mouth and even puts it's tongue in the...
Hi Rose_Stan,
We, at FixYa, provide technical and repair assistance for products like cars, electronics, cameras, etc.
We would suggest that you consult a qualified Pediatrician for this issue.
Thanks for using FixYa.
Sep 21, 2010 | Health & Beauty
Barbie Potty Training Taffy Nikki Doll and Pet Playset Logo
69 people viewed this question
Top Barbie Toys Experts
ray gallant
Are you a Barbie Toy Expert? Answer questions, earn points and help others
