Question about ASK Proxima Office Equipment & Supplies
Zte mobile c150 repairing
I recently changed my projector lamp but every now and again it switches itself off and illuminates the lamp sign,what could be the problem??
HDTV GURU
  • 261 Answers
SOURCE: lp335 in focus projector lamp not turning on; spark switch gap is sparking
It could be the lamp. I have seen this many times on DLP'S. If the ballast is firing it which is usually around 600 volts or so, then i would say it is fine, and only needs a lamp. Let me know if that helped you. Later Jay
Posted on Jan 31, 2008
Marrie
  • 563 Answers
SOURCE: BENQ PB2140 PROJECTOR - RESET LAMP AFTER REPLACEMENT
Hi Terence
Yes you have to reset the lamp timer.
How to do this :
1.) Hold in the up arrow key on the Projector for 5 seconds , a on-screen display will appear in the top left hand corner.
2.) It will read : Press left or right and then Menu or Auto.
Just follow the steps and the lamp timer will be reset.
Thanks for using Fixya !
Posted on May 19, 2008
Marrie
  • 563 Answers
SOURCE: Toshiba projector switching itself off
Hi 123d
Have you tried resetting the lamp timer ?
If you have and it didn't solve the problem , take out the lamp and check for any discolouration or markings on the lamp.
If you do find anything out of order then the lamp would need replacement.
Posted on May 21, 2008
SOURCE: Shutting down after 2 min
call panasonic-- they have extended the warranty on this issue up to 18 months, as it is a known problem with the sealant for the iris. If the sealant is not moving, the iris sticks and the projector goes into lockdown. Call this number and they will take care of your problem: 1-800-211-PANA (7262)
Posted on Oct 24, 2008
rulds2008
  • 3866 Answers
SOURCE: Infocus X10 projector overheating.
okay most people think well its not hot up there but truely it is hot toward the cealing. If its overheating on the roof mount try to use a wall mount instead.. If they have it running for 5 days streight then is something your not oding right here and that might be the mount.
Posted on Nov 10, 2009
Projector not turning on
seems that the lamp is defective, pls test it
Have a good day! any question ,contact me,Please
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Feb 25, 2014 | Optoma EP739 Multimedia Projector
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Feb 22, 2011 | Sony VPL-EX1 Multimedia Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
I have an occasional problem with my Hasselblad PCP80 projector. Shortly after switching on the lamp will go out for no apparent reason, but all other controls on the projector work okay. The high...
From my PCP80 Service Manual:
FAULT: The projection lamp is lit for a short moment and then goes out. POSSIBLE CAUSE: 1.The rectifier and lamp change board are out of order. AND/OR: 2.Both triacs turn on. Both lamps are lighted until the automatic circuit breaker is released. MEASURES: 1. Change both boards. 2. Change the triac board.
See Also:
FAULT: The projection lamp does not light. POSSIBLE CAUSE: The automatic circuit breaker has released. MEASURE: Reset the circuit breaker. AND/OR: Fuse F102 has blown. MEASURE: Change the fuse. AND/OR: The rectifier and lamp change board are out of order. MEASURE: Change both boards. AND/OR: The triac board is out of order. MEASURE: Change the board.
Dec 21, 2010 | Hasselblad PCP 80 Slide Projector
HD20 switches on by itself
the projector will shut off when the lamp hour count reaches expected lamp life. It will restart only long enough to read the hour meter again then shut it's self off again. You can manually reset the hour meter to continue using the same lamp. Good luck.......
Aug 02, 2010 | Optoma HD20 DLP Projector
Hitachi ED-X8250 - Turns off after 15 mins LAMP and POWER = RED
reset the lamp and filter timers. turn the projector off then back on.
Mar 29, 2010 | Hitachi ED-X8250 Multimedia Projector
What is wrong with my Panasonic PT-L711XU projector?
try to clean the air filter of your projector... in case the problem occur check the lamp ballast board and replace it.
jahting
Oct 10, 2009 | Panasonic PT L711XU Multimedia Projector
Replacement lamp won't work
On all projectors, there is a lamp timer that must be reset when the lamp is changed, if not, when they get to a certain amount of hours the projector will NOT operate. Fortunately, if this is the case I can help you solve the issue.
Best regards,
Steve
Dec 11, 2008 | Philips Office Equipment & Supplies
Toshiba TDP-S20 lamp problem
The lamp ballast which ignites the lamp has failed it sounds like. The red flashing lamp is the tell tale sign with a good lamp installed. Make sure the lamp door is closed too, there is a door switch that can also trigger the red lamp and no startup. There is a company in San Diego CA that can repair the unit called PROJECTOR DOCTOR
Nov 29, 2007 | Toshiba TDP-S20U Multimedia Projector
54 people viewed this question
Top ASK Proxima Office Equipment & Supplies Experts
jasbo
jasbo
240cpa
Lyle Siemens
Lyle Siemens
Are you an ASK Proxima Office Equipment and Supply Expert? Answer questions, earn points and help others
