Question about Insignia Digital-to-Analog Converter for Analog TVs
I have a 13 inch TV with a small table top antenna with rabbit ears on it and a dial. I plugged the antenna cable into the converter for antenna in. I plugged a cable from converter box to my TV. I was getting 3 local channels. Now I am getting nothing.
  • 30 Answers
You may need an antenna that gets VHF and UHF bands. The "rabbit ear" antenna is designed for VHF band. Many of the DTV channels are located in the UHF band. You may want to call the FCC's DTV hotline for help. They will know the TV stations in your area and can tell you if you need a different antenna. The can also arrange for someone to come help set up your DTV converter at no charge to you. 1-888-CALL-FCC is the number.
Posted on Jun 16, 2009
HOW TO HOOK UP A ANTENNAE
Well you can follow the below steps -
1. Inspect the antenna for any signs of damage. Identify and examine the power adapter cord and the coaxial antenna cable for any rips tears or other defects.
2. Plug the adapter into the antenna's power adapter socket. It will be labeled "12V DC/Adapter". If you are using an antenna that does not require power, such as rabbit ears, you may skip this step.
3. Next connect the antenna cable to the television using the TV's "Antenna In/75 Ohm" input jack. Make sure the antenna connector is twisted tightly into place. Place the antenna on a sturdy surface such as the top of an entertainment center. If you have an older analog TV that is a non high definition ready/capable display and are using a digital to analog converter box, generally, the antenna will plug into the input of the converter and the output of the converter will plug into the antenna input of your TV.
4. Plug the antenna's power supply into a 120V AC wall outlet. This will turn the antenna on. If you are using the "rabbit ears" style antenna, make sure that the each section of the antenna is fully extended. This will give you the best reception.
5. Turn on the TV and check for digital reception. You will know that you are receiving digital signals because the picture will be clear and free of any analog "snow" or other artifacts. Digital TV channels have DVD quality picture and sound.
Follow the below link for more help -
http://www.wonderhowto.com/how-to-hook-tv-antenna-094240/
Good Luck!!
Mar 26, 2010 | Akai PDP4273M Television
Finds no channels
It is meant for Rabbit Ears or Outside Antenna Only.....
Jul 24, 2009 | Insignia Digital-to-Analog Converter for...
Philips Model ID 20pf5120/28
Recently, cable has gone digital. You might not be able to get a signal anymore with rabbit ears. They suggest buying a converter box. You can always try restoring factory settings...
Jun 15, 2009 | Televison & Video
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
May 27, 2009 | Philips Televison & Video
Can't get any channels on Coby tv
Yes, you need an antenna -- rabbit ears or some other type of digital antenna.
Jan 28, 2009 | Coby TVDVD1350 13 in. TV/DVD Combo
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
Converter Box?
Only if your using rabbit ears or have a outside antenna, if you are on cable your ok. If you do have cable or sattelite you just need to run a new connection to it.
Jan 09, 2009 | Televison & Video
Rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
Oct 31, 2008 | GE 35GT740 35" TV
Do I need a dtv digital converter box for my Symphonic SC313D 13 inch tv?
Pretty much a hoax on those diverter boxes. People ran out and bought them thinking that won't have reception. I have many years in maintenance and several years in nursing homes with different tv's in every room. Not once have I needed a box to pick up channels with or without cable. I myself get 16 channels with rabbit ears and thats enough for me. And I do own a combo as well and it has simple antenna and does me just fine. Depending on your location, the old tv antennas we use to put on our houses...they work amazing! Might be able to snag one on a freecycle or craigslist site. Good luck! :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/shannon_b38635e8878032de
Jun 05, 2008 | Symphonic SC313D 13 in. TV/VCR Combo
Insignia Digital-to-Analog Converter for Analog TVs Logo
168 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
