Question about Chevrolet Silverado 1500 38940-91 Tonneau Cover Full Tilt Snapl
Will not run
My 1991 silverado will not run
  • Serge Joncas Feb 06, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
1991 Chevrolet Silverado C1500 hard to start when cold. Rebuilt TBI, replaced fuel filter, good fuel pressure pressure. After several crankings 20-25 times it will finally start, and run and drives ok....
I have seen this problem before ck the coil and coil wire and also condition of distributer cap and rotor,ck the coil and coil wire for white corrosion or black burned ends,hope this helps
Sep 30, 2010 | 1991 Chevrolet Silverado 2500
What is the purpose, and what is the proper location of the orifice tube in the air conditioning system on my 1991 chevy silverado?
The orifice tube restricts the flow of refrigerant to the evaporator. This restriction allows high pressure liquid freon to change into low pressure freon before entering the evaporator. The orifice tube is located inside the hose running between the condenser and the evaporator. You'll need an orifice tube removal kit if you are looking to remove it.
Aug 23, 2010 | 1991 Chevrolet Silverado 2500
Need to locate a picture of a fuse box on a 1991 silverado pick up truck
use google image search. search in google as usual for "1991 silverado pick up truck fuse box" and then click images at the top of the results page
Nov 06, 2009 | Computers & Internet
Where are fuel filters on 1991 chev silverado
One filter only and it is located on the drivers side, inside frame rail near the gas tank.
Regards,
Aug 03, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Lost radio reception in 1991 Chevy Silverado
IT IS THE ANTENNA WIRE THAT RUNS FROM THE ACTUAL ANTENNA MOUNTED ON YOUR TRUCK TO THE BACK OF YOUR RADIO.THIS WIRE IS POSSIBLY BROKEN OR CORRODED.REPLACE THIS WIRE OR RUN A COMPLETELY NEW ONE.
Aug 01, 2009 | Car Audio & Video
1991 2500 series Chevrolet pickup
just tell them you want the low pressure switch on the accumulator dryer.
Jul 02, 2009 | 1991 Chevrolet Silverado 2500
Change water pump on the 91 silverado
is that the screw on clutch fan?
if it is call me and ill tell you how!!!!
574 370 1415
Apr 08, 2009 | 1991 Chevrolet Silverado 2500
Chevrolet Silverado 1500 38940-91 Tonneau Cover Full Tilt Snapl Logo
Top Extang Vehicle Parts & Accessories Experts
Frank Magliocca
David Ellis Rhea
Are you an Extang Vehicle Part and Accessory Expert? Answer questions, earn points and help others
