Question about GE Dishwashers
Making a noise when washing
When the washer is running it is making a scrubbing type noise, it is not consistent.
  • 85 Answers
Did this suddenly start or was this gradualy getting worse?
Posted on Mar 31, 2014
I have the Bosch Next 500 series and I hate it. I am trying to clean off the mold growing on the 'roof' of the detergent basket. I am using a dental tool and q tips but I can't reach some of it.
Hello. Welcome to a "nature of the beast" situation with cleaning your washer. These washers are a lot more user intensive than the older ones. I'm a tech and tell all my customers to build a CLEANING KIT consisting of the following:
2-gallon bucket
2 old toothbrushes
1 kitchen or bathroom scrub brush(on the medium/small side)
3 old wash cloths
3 pairs of comfortable rubber(Playtex) gloves
1 gallon of household bleach
Procedure: Put on gloves(always)
MIX 1 cup bleach to 1 gallon of warm/hot water
Clean the dispenser areas with the toothbrushes dipped in the water/bleach solution(be careful to *not* get bleach on any metal surfaces, use the scrub brush also. Try to flush the areas with clean water or wipe/flush with a wash cloth and clean water.
FOR CLEANING THE BELLOW(RUBBER BOOT THAT MAKES THE DOOR SEAL)
Dunk a wash cloth or 2 in the water/bleach solution, squeeze out enough water so that the cloth is very wet but *not* dripping, carefully place the cloths in the fold of the bellow and wipe around and around, repeating the dunking and squeezing as often as needed. DON'T BE ROUGH, DO NOT USE DENTAL TOOLS ANYWHERE NEAR THE BELLOW--if you puncture it, it will leak and have to be replaced. You can use a toothbrush or scrub brush as long as you are gentle with the scrubbing. Take your time and try to remove as much of the mold as possible.
Run a washer cleaner through the unit at least once per month. For heavy mold build-up you will have to use several boxes of cleaner once a week for 3 weeks. After each cleaning cycle(no spin needed), run the washer on HOT WATER, heavy duty, bulky, etc WITH NOTHING IN IT), then, for run #3, only wash whites--this will ensure that anything with cleaner in it has been flushed out the washer. I hope I helped you!
Sep 03, 2015 | Bosch Washing Machines
The last 5 minutes of my washing cycle, my washer makes this loud noise! It sounds like a plane taking off! It's so loud, you can't hear tv. I'm not sure what the problem is.
Does it dry the clothes as fast as always? Or is it taking longer to dry them? That noise could be the blower wheel.
If the noise is more of a scrubbing sound that would be your glides worn thin and rubbing the mount
Something can also be in the blower causing the noise.
9_20_2011_2_48_43_pm.jpgTake the door off first and since the door is reversable remove those 2 screws on the other side. Then the front pops off revealing the clips that hold down the top. Then you can get the glide mount/shroud off there and remove the tub. You probably figured out you cannot access the innards from the rear of the dryer.
http://www.fixya.com/support/r6555743-help_maytag_slopefront_dryer_died
Sep 18, 2011 | Maytag Neptune MAH5500B Front Load Washer
We've scrubbed off the wash info on the front of the machine!
In your main browser bar, type in-----------HOTPOINT.CO.UK
In the drop down menu, click on----------After sales.
Enter the model number of your washer in the box, and download the instructions.
Please rate my solution.
Thanks.
Nov 10, 2009 | Hotpoint WF430 Front Load Washer
THe Dishwasher just keeps Washing And Rinesing
Turned Fridgidaire washer on last night before going to bed; this morning, it's running (at least making sounds) but did not wash; 4000 Series Frigidaire; display says Washing Drying Er Clean S; and two lights are flashing - Ultimate Scrub and Rinse only.
I tried turning off the breaker and restarting the machine but that doesn't work.
Sep 05, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dryer makes loud noise, long time to dry.
This is joyce
Go to maytag.com and put in your model# and dowload your manuel. get some info on your type machine and the scamatics on it. I dont know the age but it sounds like its in the drum. may want to calll a technichian out to look at it. if I can help please let me know
thanks
joyce
Feb 13, 2009 | Maytag LSE7806A Top Load Stacked...
Makes scratching noise
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Nov 19, 2008 | Maytag PAV2300 Top Load Washer
Black mold
You can try a product called Affresh it's supposed to work quite well to maintian a clean washer. If you already have a smelly washer you should run a few cycles using Affresh. You also want to make sure you're using HE soap (it will have an HE oval shaped logo on the detergent bottle). If you're not soap residue will build up in the machine and start to smell.
Oct 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Sep 07, 2007 | Washing Machines
Dishwashers Logo
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
