Question about Nikon COOLPIX Cameras
The s6100 lens erorr! pops up when i go turn it on
I go to turn on my camera and it boots on lens opens you can see a pic. on the screen then lens closes and says lens error!
  • 374 Answers
SOURCE: camera shuts off lens error
"lens error" will only be fixed by sending into repairs. 800-706-2534 and keep choosing option 2. Tell them you have a lens error and they will tell you where to send it.
Posted on Mar 30, 2008
PAPA-RAZI
  • 37 Answers
SOURCE: coolpix lens opens retracts opens then closes again and lens error appears
Hello
When you turn the camera on the lens comes out and has parameters when extending to focus, if the lens does not open fully it sees a problem and then closes.
there are tiny plastic gears inside and may have chipped or a piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Posted on Sep 02, 2008
SOURCE: Sanyo VPC-E760 Lens not closing
THis is really easy to fix. just pull the lense out so it is alligned. it might seem like your breaking the lens but its just jammed.
Posted on Jul 05, 2009
SOURCE: lens stays open, won't retract when camera turned off
If your camera is still under warranty, the best thing you can do is to take it to the nearest official Canon repair shop and Canon should fix it for free.
If your camera is out of warranty, or if Canon refuses to repair it for free (happens sometimes if for example they suspect the camera has not been treated properly) you can try some of the methods listed here to repair it yourself. These simple methods have helped a lot of people fix their cameras.
Before trying any of the suggestions, make sure your Canon has fresh batteries and it is in recording mode.
1) Remove the batteries from the camera, wait for a couple of minutes, then put them back in and turn the camera on.
2) Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
3) Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
4) Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
5) If that doesn't work, there is an online guide for dismantling Canon cameras and fixing the E18 error. (NOTE: Try this only if your camera is no longer under warranty!) It is a great guide with pictures and it can be found here.
regards iversh
a very helpful rating is apreciated for answering ur query.....
Posted on Aug 19, 2009
  • 11967 Answers
SOURCE: camera's lens is stuck
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 23, 2010
How do i fix my lense error on my nikon L26
hi,
if the lens is not broken, it's position is wrong, please open the camera and takeout the lens unscrew it, re-assemble the lens barrel perfectly.
Mar 06, 2015 | Nikon Cameras
How do I clean Lense on a Nikon Coolpix S6100 7X Zoom 16MP
you can not clean at your self. Use dry cotton or ear buds for cleaning the lens front side. After that if its still there then use compressed ai in surrounding the lens. After that if the spot still there then you need to visit service center for cleaning the lens internal side.
Aug 10, 2012 | Nikon Coolpix S6100 Digital Camera
I turned on my f410 camera but the lens does not extend out at all
The gear linkage in the lens has more than likely seized, you will need a specialist to handle the repair, but before you proceed ask for a estimate.
Jun 09, 2012 | Fuji FinePix F410 Digital Camera
Nikon Coolpix Lens Error
Hi!
It could be focus system problem - most likely stuck. Could be sand or some dirt inside focus gears. They're very small for these lens which are used in many Nikon, Olympus, Casio and other cameras so even one small piece of sand can block the focus system. The only way to fix it to take the camera and lens apart and clean it.
Sorry for the bad news. I repair cameras every day and you can trust me - I know what I'm talking about.
Tom
Sep 26, 2009 | Nikon Coolpix S210 Digital Camera
Nikon CoolPix S5. Red flashing hand. Camera/Lens on/open.
If the shutter is stucked there is no external way to release it Have to show it at camera shop
Mar 15, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Coolpix S210 Lens Error
Mine did this. I assume the lens won't pop up as it normally did?
To fix mine, I wedged a small screwdriver into the lens and then turned it on, gently nudging the lens out. It worked great and I haven't had the issue again yet.
Just a little help is all it likely needs to pop that lens out.
Dec 06, 2008 | Nikon COOLPIX S200 Digital Camera
Lens Errors 17 & 27 on Sanyo VPC-E760
My camera was showing lens error 12&25 and then shutting off. I tried gently trying to twist and pull the furthest out part of the lens and it popped back into place easily. It made a noise when it did this, and then i turned the camera off, and the lens went back in!! Completely fixed now!!
Aug 03, 2008 | Sanyo VPC-E760 Digital Camera
Lens Cover Won't Open
NO Super glue this can be fixed pretty easily to get fixed. most local shops will not charge you to much to fix it maybe 15 to 20 at the most i figure. or you can remove the lens cover by putting a very small flat head screw driver on the side of the lens and with the camera off pull away from the camera and it should just pop off. Superglue if you get it on the lens will rune the whole thing. Just tiring to help out . I repair lens shutters all the time they are just mechanical parts nothing really special about them.
Apr 16, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Lumix / Panasonic fixed lens Digital SLR problem.
try to help the lens come out by pulling it very very lightly...you should here a pop.
Mar 25, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Cameras Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
