Question about Danby DKC645BLS Compact Beverage Cooler
Freon leak recharge
Has a hole in coil in freezer, lost Freon how do I recharge and fix it
    Director Badge:
    Uploaded 100 video answers.
  • Danby Master
  • 488 Answers
Video how to replace evaporator 1 door refrigerator.
Posted on Dec 13, 2015
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 58 Answers
Not knowing the nature of the hole..in general it may be soldered to repair? Then the system needs evacuated (special Vacuum pump) to remove air and moisture. Then it would need charged to the proper pressure. Leave this job to a professional with the proper equipment and knowledge. It might be worth exploring the cost of a working used replacement unit, verses the repair?
Posted on Mar 31, 2014
  • Danby Master
  • 4,655 Answers
Repairing a leak on any refrigerator will require additional skills and tools that most people do not have. I am skilled in refrigeration but the first few refrigerators that were repaired and recharged took much longer because of my inexperience. Refrigerators require long vacuums, new filter driers and a precise amount of Freon to recharge them.
APPLIANCE 911
Freezer does not freeze, but stays cold like bottom unit.
How to fix freon leak an refrigerator by replacing the whole evaporator coil and charge back up to proper level R134A Side by side. Not DIY fix. video
Sep 27, 2015 | Refrigerators
Gsh25sgpass fridge freezer
If the bottom rung of the evap coil is the only part frosted, or frozen and no other parts of the evap coil contain frost, you are most likely low or out of freon. An experienced repair company should be called out to verify this. If the freon is actually low, recharging the unit is not a plausible option because there is a leak. A repair or replacement of the fridge is needed. Pleazer Appliance...
Apr 17, 2014 | Refrigerators
Freon leak in housing? Can it be fixed
replacing leaking evaporator coil in this video on GE side by side
Jul 22, 2012 | GE FUF17SVRWW Upright Freezer
We had a freon leak, I wondering do we need to throw all the food away that was in the freezer??
fixing freon leak at evaporator coils by replacing evaporator on this video. GE side by Side.
Dec 05, 2010 | GE Freezers
Freezer will not freeze
replacing leaking evaporator on GE side by side. Watch this video to understand why its so expensive to fix freon leak issues.
Sep 25, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
Small freon leak, food safety
fixing freon leak. Evaporator is leaking freon. Replaced Evaporator on this video
Sep 23, 2009 | GE Freezers
Need freon recharge. punctures freezer coil in
You punctured the aluminum evaporator . In the many years I've been in refrigeration , I have yet to find any way to patch a hole in the evaporator . I've used epoxy , solder , and all different advertised ways to try to patch aluminum . Nothing worked ( for long anyway ) . My suggestion would be to buy another refrig . You will be wasting time and money trying to " fix " this problem . To repair it yourself , you have to have a license to buy R12 , maybe you can buy R134A without a license , you have to look on the " modell , serial number tak to see which it uses and how much to use . Also , the system has to evacuated ( all air removed from the lines ) . Do you have a vacuum pump ? You have to buy a solder on connector ( or saddle valve which WILL leak eventually unless you get a solder on valve ) which will connect to the larger tubing on the compressor or use the access line already on the compressor but is pinched off . Do you have guages for the refrigerant type you need to use ? Once you have these things , reply back and myself or someone else will help you procede .
Aug 19, 2009 | Refrigerators
Refrige is 48 and freezer is 0 model 532
Fixing Freon Leak by replacing evaporator coil on Sub Zero refrigerator
May 19, 2009 | Sub-Zero 642
Kenmore upright frost free freezer compressor will not come on...
mlee62599,
You have a freon leak and the coolant leaked out. Perhaps when you mode it down the stairs one of the coils with the freon in it ruptured a tiny hole.
You need an authorized and certified tech for freon.
Apr 07, 2009 | Kenmore Freezers
Candy fridge freezer
It sounds like a Freon leak. The compressor is running and it gets a little cold. THis is not something you can fix yourself. You have to have certification to buy freon and gauges and know exactly how to use them. Besides in most cases you can't find the leak and will have to keep recharging it.
Jun 28, 2008 | Freezers
Danby DKC645BLS Compact Beverage Cooler Logo
221 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
