Question about C3RS915 SST Remote Car Start Vehicle Security System with 2way L
How do I reserve battery life on my autopage alarm key pad model XT-73LCD
My battery run down every 2 days in my alarm key pad
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
If you put remote in your pocket or your purse make sure it doesn't push on any buttons!
Posted on Apr 30, 2014
3 Suggested Answers
  • 7 Answers
SOURCE: i have the normal alarm Autopage AutoPage C3RS603
Nothing is hard to hookup just time consuming andf it all depends on how good you R with wiring how good R you..?
Posted on Jul 16, 2010
  • 139 Answers
SOURCE: i need the manual to
The Autopage XT-42LCD is used to operate two systems, the RF-420LCD and RS-622. Since you state that you need to activate a remote start that narrows it down to the RS-622. You can download the manual for this unit at the following link:
http://www.autopageusa.com/resources/RS622operationManual.pdf
Posted on Jan 22, 2011
My youkon alarm goes off every time i unlock the door with the autopage key fob.
Aftermarket alarms have to be configured to bypass the factory alarm system when using it.
I don't mean you have to permanently delete your factory alarm. What I am saying is, when you use your autopage key fob to unlock your doors, it must also send a signal to the disarm wire of your factory system simultaneously. If not, your alarm will go off just like you are experiencing.
May 16, 2017 | GMC Yukon Cars & Trucks
Xt 33 autopage (crank) but no start
could be your car requires a bypass module... or the safety inputs preventing the alarm from starting car are in place... without knowing your make/model that's the best I can do...
Jul 18, 2016 | Autopage Vehicle Parts & Accessories
Need to reprogram my autopage XT-43LCD REMOTE CAR ALARM
The first link is a discussion page where someone asked for the manual. The second link is the manual. Apparently the manual is for a different system the works the same way. From the first link: "The 43LCD does not have an owner's manual. Instead, the manual to which the remote is compatible with is the 'manual' it is associated with, link below. "
http://www.sonicelectronix.com/item_18302_AutoPage-XT-43-LCD.html
http://contentdocs.installernet.com/documents/product/32268.pdf
Jul 05, 2015 | Autopage Vehicle Parts & Accessories
Autopage XT-1100
Try to search for Autopage XT-1100 Manual. im sure you will be able to find the functions there
Apr 01, 2014 | C3RS730 LCD (C3RS730LCD) 2way 4Channel...
RS855LCD 2-way remote and key fob dreain batteries
I see this is a old post but, I have this unit in a used van that came with no remotes. A local audio shop paired it up with a AUTOPAGE XT-33. I can lock,unlock,start with this remote. Just remember to keep the drivers open while doing these steps.
1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the2ndpush, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
The Valet switch is a little Red Push Button that should be
mounted under the lower left side of you dash or in the lower
left kick panel near the E-brake pedal.
Jan 14, 2012 | RS855LCD AutoPage MultiChannel 2 Way...
I bought a used 2007 Expedition and the door pad remote entry does not work. I have one AUTOPAGE XT-33 remote that came with the car. I turned the key in the driver's side door lock and the alarm...
I'm not sure exactly if this is what you're looking for, but if you're trying to program a new keyfob remote, follow these steps:
  1. Turn the key in the ignition from off to run 8 times within 10 seconds. You'll hear the door locks cycle (lock and unlock) three times to confirm that the car is in learning mode.
  2. Within 20 seconds, press any button on your keyfob. The locks will cycle again to confirm.
  3. Repeat step two with any additional keyfobs you wish to program.
  4. Turn the ignition off. The locks will cycle again to confirm the end of programming mode.
As for the alarm type, you would probably want to contact Ford and ask them. As for the door pad, while you're on the phone with Ford you'll need to get the factory door code. You might be lucky and find it written somewhere in/on the car or inside the book that came with the car, unless the new owner got rid of it.
Jun 28, 2011 | Ford Vehicle Parts & Accessories
I need the manual to tell me how to activate Autopage XT-42 LCD remote starter
Jan 21, 2011 | Viking - VT73 - 4 Button Random Code Mini...
I need to program an autopage xt-33 remote. the remote needs to be programmed im not sure if it has a valet chip or not
Autopage is a pretty trouble free system...but if the battery is near-dead or dead they can do evil things...swap out the battery and try again...If you can't...go to your local car stereo installation shop and ask them NICELY to help...lots of times it's free..if it is, buy the dude lunch...what, $10?
Good Luck
Jun 15, 2009 | Vehicle Parts & Accessories
C3RS915 SST Remote Car Start Vehicle Security System with 2way L Logo
138 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
