Question about Cooling System for Nissan Altima
Cooling diagram pipe damage
  • 42 Answers
What year, model, engine size?
Posted on Apr 29, 2014
Chigo airconditioner is appear E4errior
E4
1. Check whether the winding resistance and operation current of the compressor are normal.
2. Check weather the high and low pressure is normal when the unit is running after 20 min of run time.
3 Check ( whether the coil pipe sensor is normal ) Whether the contact of the inserter on the circuit board is well, the coil pipe temperature sensor is fixed ( Whether there is water in the fixed clap ) the evaporator of the indoor unit is well, the key is to check the evaporator temperature detected by the coil pipe temperature sensor has reached the cooling or heating temperature ( Weather the temperature is higher or equal to 77 Deg F in cooling mode.
4. Check whether the surface of the condenser is to dirty,it should be cleaned when it is too dirty.
5. Check weather the capacitance of the outdoor motor and fan is not damaged, it should be replaced when it is damaged.
6. If the above items are normal, the electric control board should be replaced.
Jun 19, 2014 | Heating & Cooling
Engine stalls
The probable reason for engine stalling can be overheating.
The engine can be overheated due to many reasons and their remedies are listed below:
1. Insufficient coolant and water in radiator - Refill the coolant and water in reservoir
2. Radiator fan not working as needed - Loose connections, faulty fan
3. Damaged hoses and pipes - Replace hoses and pipes
4. Clogged pipes - Clean them
Jun 09, 2013 | Oldsmobile Cars & Trucks
1998 plymouth grand voyager coolant system diagram
IT WORKS LIKE A LOOP YOUR HEATER CORE ACTS LIKE A U-TURN SO IF GET A U-SHAPE PIPE AND CUT THE HOSE TO FIT IT WILL SOLVE YOUR PROBLEM
Sep 25, 2012 | 1998 Plymouth Grand Voyager
Need to change engine thermostat on 2002 saturn vue. would like diagrams on how to and what to look for.
2.2L Engine To Remove:
  1. Drain the cooling system.
  2. Remove the exhaust manifold heat shield.
  3. Remove or disconnect the following:
  5. Remove the thermostat cover bolts from the thermostat housing.
  6. Remove and discard the thermostat housing O-ring.
  8. Twist the water feed pipe while pulling to remove it from the water pump. Remove the water pipe from the water pump assembly.
  9. Remove and discard the seals from the water pipe.
  10. Remove the inner thermostat sleeve.
  11. Remove the thermostat assembly.
To Install:
  1. Install the thermostat cartridge into the thermostat housing while aligning the cartridge tangs up with the thermostat housing bolt holes. This will assure the inner sleeve can be completely installed.
  2. Align and insert the inner sleeve notch into the thermostat housing. If the inner sleeve notch is not properly positioned, the sleeve will not completely seat into the housing.
  3. The water feed pipe seals can be slightly lubricated with silicone gel to aid during installation. Install a new O-ring on the water pipe.
  4. Position the water pipe into the water pump assembly.
  5. Seat the water feed O-ring by pushing and twisting toward the water pump. Take care not to tear or damage the O-ring.
  6. Install the thermostat housing cover to the water pipe. The water feed pipe has a locating tab to assure proper alignment.
  7. Install a new thermostat housing cover seal into the recess groove.
  8. Position the thermostat housing cover into position.
  9. Install the thermostat housing cover bolts and tighten bolts to (89 in-lb 10 Nm).
  10. Install the exhaust manifold heat shield.
  11. Fill the cooling system.
Dec 24, 2010 | 2002 Saturn VUE
Is there a diagram online that shows the hoses going into the heater coil? I want to bypass the heater coil because it is leaking. I want to cap off the hoses.
if you cap off the hoses then you will over heat the truck and cause severe damage to it,if you want to bypass the heater core the look for the two hoses that enter the truck on the passenger side of the fire wall,loosen the clamps and remove the hoses then insert a small pipe to go into one hose **** it down and then install the other hose on the exposed end of the pipe and clamp it down this will let water circulate through the cooling system,but you will not have any heat in the cab
Sep 01, 2010 | Chevrolet Venture Cars & Trucks
Wirering diagram for pump down system refrigeration
close liquid line small pipe you need gages to do it properly but run the unit on cooling untill you hear the commpressor struggling generaly couple of min depending on pipe length and type of unit cycles then close gas valve bigger pipe switch off power and it shoul be pumped back into outdoor condensing unit
Mar 10, 2010 | Heating & Cooling
03 A4 Audi - Gas fill up takes a long slow time
sounds like the filler pipe is damaged or a piece of rag or something stuck down the pipe .
Jul 02, 2009 | 2004 Audi A4
Fridge freezer not cooling
buy a new freezer and never go near it with a screwdriver try unplugging it to remove ice
Mar 12, 2009 | Freezers
Dryer's vent hose Problem
Wait for the dryer to cool. Unplug the vent hose and inspect its entire length for snags in the pipe. Make sure the vent is not obstructed on the outside wall, and fit a flap or screen to keep out small animals. If your vent pipe is punctured or damaged, you should replace it.
Aug 27, 2008 | Elements of Design DS492 1/2" Inlet Copper...
Cooling System for Nissan Altima Logo
70 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Jim Y
Jim Y
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
