Question about Boating
Attaching shift linkage
Need help getting shift rod and water tell tale re-attached to lower unit
    Top Expert:
  • 45,228 Answers
Shame on you for not noting how it came apart . but with such little information I can't begin to know what you even have .make, model ,size of motor, etc.etc.
Posted on Apr 01, 2014
Model 15754M 15 hp evinruide .shift rod housing is holding water. I cleane the drain hole om side of lower case but still holds there a drain hole in shift rod housing that I cant find
There is a rubber seal on the top side of the shift linkage and a gasket under the case. You have to drop the lower unit to repair.
Nov 04, 2016 | Cars & Trucks
2001 325 Xpedition 4 x 4 Five speed manual trans. How can I replace Shift linkage rod?
Joy, Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Feb 18, 2016 | Polaris ATV
How do i change a neutral safety switch on a 1999 ford expedition eddie bauer 5.4 liter 2 wheel drive
neutral safety switch is attached on the outside of trans. remove the electrical connections. remove the shift cable/linkage arm that is attached to the trans shift rod. remove any other screws or bolt that hold the neutral safety switch. the switch should now slips off the shift rod. attach new part and reinstall.
Aug 28, 2014 | 1999 Ford Expedition
I need to disconnect the shift linkage of a 1983 Johnson outboard motor. I already disconnect at the water inlet. The lower unit still will not come all the way down.
some shift rods unhook midway thru the leg ,others you unhook at the top and the entire rod comes out . caution getting the shift rod lenght the same as when removed is critical or you will have shifting problems.
May 16, 2014 | Boating
Where do I disconnect the shift linkage to take the lower unit off of a 1983 Johnson 35 hp. I disconnected it behind the water inlet but lower unit will not come completely off/
there are about 5 bolts that need removed .one is kinda hidden under the little circular steering skag , and there will either be a link on the shifting rod midway down or the entire rod will need unhooked at the top. neither place being easy to get to . good luck
Re-attaching shift rod and tell tale pipe for nissan jas3
Sometimes on these small motors it is easier to do it with power head off,then you can see where pipe is going
Mar 30, 2014 | Light Outboard Motor Boat Bass Fishing...
Gear shifter adjustment
The VZ 800 ,has a linkage system ,it can be adjsted to suit your needs .Firstly , your linkage attaches to the front foot lever.on the other end the linkage attaches to the actual gear box.Its this part that you need to adjust ,Undo the bolt that holds the linkage bracket to the gearbox spline. slide the bracket of the spline .undo all the adjusting screws on the linkage rod ,position the gearbox linkage unit to the required angle you need to position the foot lever to the popsition you want and the adjust the linkage rod to suit the distance between the garebox liinkage unit and foot change.
Mar 25, 2010 | 2002 Suzuki VZ 800 Marauder
Governor and Carb spring linkage
the solid wire link goes from the top hole in the governor rod to the carb and the spring goes from the lower hole on the rod to the throttle plate where the cable attaches
Nov 01, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Need to change impellor on 1988 70 hp johnson how to please
first go to www.crowleymarine.com to get a picture breakdown of your water pump. website instruction, click on part catalog tab, click on omc Johnson and evinrude tab. choose product line, year tab, engine size, choose model. click on gearcase. the picture showes all parts you have and the correct order they go. ok now we are ready to disasemble the lower gearcase from the motor.(1) trim the outboard down using the tim and tilt system (2) shift remote control into forward gear, this lines up the shift rod so you can reach it. a picture of the linkage is refernce number 50 on the picture from crowleymarine.(3) Remove engine coul, under the carburators you will be able to see the shift rod. if you can't see it follow the shift cable to the shift linkage to the shift rod(4) the shift rod has a hole in the top, that a long screw goes through, connecting shift rod to shift linkage. remove this screw(refer to picture downloaded)(5) again refer to the downloaded picture remove these bolts that i list. number 66 there is 4. #77 there is 1. pull off #76 trim tab.#68 there is 1. #70 there is 1. lower unit will drop after you remove all bolts. remove the impeller housing. look at impeller you will see the fins are bent in one direction. put new impeller in with fins bent in the same direction. reinstall housing and gear case following my dirction in reverse order.
Oct 05, 2009 | Boating
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
