Question about Simplicity Vacuums
CompatIble brush roll strips for Simplicity 5500, Sentry III vacuum
I need new brush roll strips for my Simplicity 5500, Sentry III. Does anyone know of any strips that are compatible?
galati2k
  • 281 Answers
SOURCE: Eureka boss 5893A brush roll does not work
you have to prss the pedal and lean it back the brush roll wil enguage
Posted on Apr 23, 2009
VacuumRepair
  • 438 Answers
SOURCE: Riccar 8700 Brush Roll
Greetings,
I will attempt to walk you through the belt change on your Riccar 8955 upright vacuum cleaner. I have taken pictures for you for each step to ensure that it's done properly. What you'll need to have handy for this repair;
- Phillips Head Screw Driver
- Riccar 4000 / 8000 Series Belt
- Riccar 8000 Series Roller Brush With Clutch Assembly (only if the brushes have worn down, not necessary if brushes are still long)
Step 1: Make sure the vacuum cleaner is unpluged, and turn the vacuum cleaner upside down so the bottom plate is upwards. It's easiest to do on a work bench or counter top.
Step 2: Unsrew the two metal screws on the metal bottom plate with your Phillips head screw driver, and remove the bottom plate from the vacuum cleaner so the belt is completely exposed with the roller brush.
Step 3: Remove the belt guard that sits to the left of the roller brush, and is a metal part that protects any dirt & debris from going over to the belt. Here's a picture of that part being removed;
Step 4: Remove the Rug / Floor actuator arm from the clutch on the right hand side of the roller brush. Simply pull the metal actuator arm to the left of the brush and out of the circle that it sits in. Here's a picture of that;
Step 5: Once you have removed the actuator arm for the clutch, as well as the belt guard, lift staight up on the roller brush and remove the roller brush from the vacuum cleaner:
Step 6: Once you have removed the roller brush, and the old belt from the vacuum cleaner, take one new belt and wrap it around the metal pin in the back of vacuum cleaners agitator housing. Here's a picture of where that pin is located with the belt wrapped around it;
Step 7: Once you have the belt wrapped around the metal pin (this is the shaft to the motor that actually spins the belt), but the other end of the belt through your new roller brush;
Step 8: There is a specific way that the roller brush has to be inserted. If the roller brush is not put in properly, this can cause all sorts of problems including the brush not spinning, and continously having to replace belts. You can see on the end cap of the roller brush (the right side where the belt rides) that there is two little teeth that protrude out of the end cap as well as an indentation on the opposite side;
Step 9: With the roller brush inserted through the belt, posistion the two teeth facing downwards. You can see in the vacuum cleaner where the roller brush sits, a little groove down inside of the housing. These two teeth need to straddle that groove. Also make sure that the little ring, or circle that the clutch actuator arm sits into, is facing upwards completely. It should be directly on top of the two teeth. Stretch the belt using the roller brush as leverage down into the agitator housing of the vacuum cleaner, making sure that the two teeth are facing downwards straddling the little groove. After the brush is back into the vacuum cleaner, take the metal actuator arm from the rug / floor switch, and insert it back into the metal ring (or hole) on the roller brush;
Step 10: Replace the metal belt guard that rests to the left of the belt. You'll notice on the belt guard that there are two little 90 degree notches on both sides. These notches need to face towards the belt or to the right. Here's a picture of the belt guard being put back into place;
Step 11: After inserting the belt guard back into the vacuum, turn the vacuum cleaner over so the top of the agitator housing is facing you. Change the the rug / floor switch from bare floors to the carpet setting, and the turn the vacuum upside again so the brush and belt are exposed:
Step 12: With the vacuum set to the carpet setting, pull the belt forwards to ensure that the brush is spinning freely. If the belts do not spin freely, repeat steps 2-10.
Step 12: There is a flap that can be opened after the metal bottom plate has been removed, that will give you more access to the motor shaft. Make sure that this flap is closed;
Step 13: The last tricky part can be reinstalling the metal bottom plate. There is a little lip on the front of the vacuum cleaner that the edge of the bottom plate has to slide under for it to be installed properly. A lot of people just install the bottom plate over top of this lip, and this prevents the brushes from hitting the carpet as low as if the bottom plate is correctly installed. Here's a picture of the lip with the bottom plate in the backgroud;
Step 14: Slide the metal bottom plate into the lip on the vacuum cleaner, and fasten the screws back into the bottom plate to secure it. The lip is a little tricky, but after doing it just once, you'll have no problems in the future changing your belt.
Here's a picture of the bottom plate installed INCORRECTLY with the bottom plate over top of the lip;
Here's a picture of the CORRECT way to install the bottom plate:
I hope that this repair solution is helpful to you in installing the belt properly. If you found this helpful, please be sure to click the Thumbs Up Icons in the lower right hand corner of the solution. Feel free to request a clarification of the repair if you have any questions about this repair, or other repairs. I'm always happy to answer any questions.
Thank you very much,
Chris Jones
Posted on Mar 21, 2010
VacuumRepair
  • 438 Answers
SOURCE: brush roll belt stops turning when in position to
I think I know what the problem is with your machine. It's a rather lengthy repair, and I'll be happy to photograph it for you (like I do on most of my Fixya answers), but I'd like to know before doing all of that if you still need help, or if you've already fixed it.
Thanks,
CJ
Posted on Apr 10, 2010
SOURCE: Dirt devil Model # 084590
i have a dirt devil upright bagless model no ro88100.it blows out dust through the front vent that i have already vacuumed up please help carol
Posted on Feb 01, 2011
macofusa
SOURCE: brush roll won't turn on
Atthe bottom of the vacuuam are screws to take off...two of them are near the rear wheel assembly....two of them are behind the front mini wheels (just pry the front mini wheels so that they pop out...they pop back in)
Remove all of the screws. Remove the bottom from the top..they come apart in two pieces. Ceck the belt on the bottom piece. Slide the roller out starting from the end opposite from the motor end. With the roller off, slacken the the belt so that it misses the gear on the motor (you will have to hold it with your hand). Plug in the vacuum. Turn the power on to the roller on position. The motor should work and the green light should be on. If the motor doesn't work, then it is defective. If it does work, turn off, unplug and shoot the gear and the two ends of the roller with WD-40. reassemble. good luck.
Posted on Jun 24, 2012
How do I Pull apart a Simplicity Synchrony?
The noise is likely the brush roll or the lower motor fan if you only hear it when you turn on the brush roll. Remove the bottom plate to examine the brush roll, there are screws on the bottom of the vacuum that must be removed so that the top nozzle housing cover can be removed. Remove the screws to take the cover off the nozzle housing from the brushroll to the lower motor so you will be able to inspect the fan in the lower motor. You have a high quality precision vacuum that is not easy to repair without proper training. It may save money and provide better results to have it repaired by a qualified Simplicity or Riccar repair shop.
Jan 23, 2017 | Simplicity Vacuums
Why is my carpeting getting fuzzy tips?
You might be vacuuming too much or you may have the wrong brush strips for your style of carpeting. I recommend you take a sample of your carpet to your Riccar dealer and ask them if you have the correct vacuum and brush strips for your type of carpet.
Aug 02, 2014 | Riccar 12 8000 Simplicity 7000 Type B...
Why does my riccar supralite vacuum makes a loud rattling noise like the roller is banging around?
You have something wrong with your brush roll or you have damaged the fan. Remove the brush roll and belt and turn the vacuum back on, if the noise is gone it is likely something wrong with your brush roll, if the noise persists you probably have a broken fan. You have to remove the motor and fan housing after removing the top cover, unscrew the bolt holding the fan on and install a new fan (you can get one from any Riccar or Simplicity vacuum dealer)
May 15, 2014 | Riccar Vacuums
My simplicity 7200 does not have vacuum. Air comes out the front post filter area
If air is coming out of the filter air has to be going in through the suction hose but it may be restricted with a clog. Replace the bag and both filters. If it's been over six months since the belt has been changed start by changing the belt. Most of the vacuums brought to my store with the customer stating "it has no suction" actually have great suction but no agitation from the brush roll. If the belt is not turning the brush roll fast enough when vacuuming the carpets it will not even pickup lint and hair.
Oct 28, 2013 | Simplicity 7850 Premier Bagged Canister...
Where is the clutch assembly on simplicity 7350 upright vacumn
The clutch is part of the brush roll. Remove the bottom plate to see the brush roll and clutch. The rod that attaches to the brush roll activates the clutch
Nov 18, 2012 | Riccar 8900 Simplicity 7822, 7300, 7350,...
A cloth belt got wrapped around the roll and after taking the roll off and getting the belt off of it, now the roll won't turn when I turn the vacuum on.
Install new belt. You'll have to remove the botton cover and the remove the brush cylinder and install new bell. What happen when the brush cylinder stop because of the colth belt, it stripped the rubber kogs off the belt. The only thing that turns on your Dyson is the motor. GB...stewbison
Aug 22, 2011 | Dyson DC25 Vacuum
I have a Simplicity 7 Series Commercial vacuum that does not pick up well when pushing the vacuum foreward. Picks up just fine when pulling it backwards. Have installed new belt, roller brushes, and brush...
Make sure the bottom plate is installed properly. If it is not seated well the brush roll may not be engaging fully with the carpet. Make sure the wheels on the bottom plate work properly.
Feb 10, 2011 | Simplicity Vacuums
How to replace Simplicity vac brush roll strips?
The caps will come out of the end of the metal roller. They can be difficult if it's been a long time as dirt and grime can build up. Try sticking a flat head screwdriver in and gently twisting to get the caps to slide out.
Jul 16, 2009 | Riccar Vacuums
Kirby g4 vaccum
please clarify what you mean?
Do you mean motor bearings or brush roll bearings?
brush roll bearings can be adjusted to lower the brush closer to the carpet when worn.
to do this remove the front brush assembly, there is usually a sticker below the belt hole showing RED = POSITION 1 HIGHEST (ie a new brush roll)
GREEN = POSITION 2 MIDDLE (brush part worn)
BLACK = POSITION 3 LOWEST (brush fully worn)
At each side of this there are 2 clips unlock these and remove the bottom cover.
Release the belt tension by rotating the belt release at the front.
Before removing the brush roll, at each end of the brush roll there is a grey plastic bearing carrier (Square at the ends) MARK this with a pen or marker just so you know the original position, also look closely for the coloured markings as indicated above or numbering 1,2 or 3.
If RED or "1" is showing you need to remove the brush roll by pulling it out and rotate the endcaps to Green or "2" and re-insert the brush roll, If Green or "2" is showing then rotate the endcaps to Black or "3" and re-insert.
If Black or "3" is showing then the brush roll is worn and cannot be adjusted any more, fit a new brush roll and insert with RED or "1" showing.
To re-attach the belt, move the belt to the middle of the roll and rotate the belt knob at the front ensuring the belt engages with the hook on the inside.
May 09, 2009 | Kirby G4 Bagged Upright Vacuum
Vacuums Logo
48 people viewed this question
Top Simplicity Vacuums Experts
Tally Girl
Tally Girl
Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
