Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Re-attaching shift rod and tell tale pipe for nissan jas3
Nissan 2 hp
    Sergeant:
  • 456 Answers
Sometimes on these small motors it is easier to do it with power head off,then you can see where pipe is going
Posted on Apr 03, 2014
2001 325 Xpedition 4 x 4 Five speed manual trans. How can I replace Shift linkage rod?
Joy, Check the attached links,Manuals and guides, Good luck with your Bike
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
ATV TROUBLESHOOTING AND MAINTENANCE
ATV Service and Repair Manuals
http://www.carlsalter.com/motorcycle-manuals.asp
Feb 18, 2016 | Polaris ATV
How do i change a neutral safety switch on a 1999 ford expedition eddie bauer 5.4 liter 2 wheel drive
neutral safety switch is attached on the outside of trans. remove the electrical connections. remove the shift cable/linkage arm that is attached to the trans shift rod. remove any other screws or bolt that hold the neutral safety switch. the switch should now slips off the shift rod. attach new part and reinstall.
Aug 28, 2014 | 1999 Ford Expedition
35 hp mercury
Pices of impeller could be stuck in block,put hand on top of block and feel if it is running hot,blow compressed air into tell tale and see if that helps
May 12, 2014 | Boating
Attaching shift linkage
shame on you for not noting how it came apart . but with such little information I can't begin to know what you even have .make, model ,size of motor, etc.etc.
Mar 30, 2014 | Boating
1994 Toyota Camry outer door mechanism jammed
Just cut a square hole in said plastic sheet and look to see what you want to see. Then just tale the plastic sheet back up when your done.
Jun 25, 2017 | 1994 Toyota Camry
How do you remove the manual shift lever from a 1994 acura legend
YOU HAVE TO UNSCREW THE SHIFT LEVER KNOB. REMOVE THE CENTER CONSOLE.REMOVE THE RUBBER SHIFT LEVER BOOT AND THE DUST SEAL.YOU NEED TO RAISE SUPPORT VECHICLE ON JACKSTANDS ON LEVEL SOLID GROUND.YOU HAVE TO DISCONNECT THE EXTENSION ROD FROM THE TRANSAXLE.SIMPLY REMOVE THE BOLT THAT ATTACHES IT TO THE EXTENSION BRACKET.TO DISCONNECT THE SHIFT ROD FROM THE TRANSAXLE PUSH THE DUST BOOT FORWARD REMOVE THE CLIP AND DRIVE OUT THE SPRING PIN WITH A PIN PUNCH.DISCARD THE SPRING PIN.DO NOT REUSE IT.TO DISCONNECT THE REAR END OF THE SHIFT ROD FROM THE SHIFT LEVER REMOVE THE NUTS AND BOLTS.THEN REMOVE THE TWO NUTS AND WASHERS THAT RETAIN THE CHANGE BALL HOLDER TO THE UNDERSIDE OF THE EXTENSION ROD AND REMOVE THE CHANGE BALL HOLDER LOWER THE SHIFT LEVER DUST SEAL,SHIFT LEVER BALL SEAT,SHIFT LEVER AND EXTENSION ROD.INSPECT THE BUSHING AT THE FRONT END OF THE EXTENSION ROD AND REPLACE IT IF ITS CRACKED TORN OR WORN. REPLACE THE ORINGS IN THE BASE OF THE LEVER.BESURE TO LUBRICATE NEW O RINGS AND BUSHINGS WITH A SILICONE GREASE.USE A NEW SPRING PIN TO ATTACH THE SHIFT ROD TO THE TRANSAXLE.INSTALL EVERY THING BACK VISA VERSA.
Mar 02, 2011 | 1994 Acura Legend
I installed a muncie m20 tranny in my 72 camaro and thought the shft rods were set ..but turns out 1st gear was in the 2nd gear position i tried flipping rod paddles upside down now gears are locked up...
You are right about the shift pattern. Reverse is hard left and up.If your gears are locked up, you'll probably have to remove the side cover and reset the shift levers to their neutral position and then slide gears around to put it back on. With it back on the shift levers should point up toward the car floor. 3-4 is the shift lever closest to the engine. 1-2 is the middle one and reverse is the one closest to the back of the tranny. Check all your swivel points for looseness. If there is any play then you'll have to bush it out or you'll have trouble getting it to shift into gear and stay in. I used some old copper pipe to make bushings on mine, because it used to jump out of gear.
To properly attach your shift linkage, put the shifter and the trans mounted shift levers in neutral. Loosen the locking clamps so the shift rods slide freely. start with the reverse lever, which is the inner most rod on the shifter and tighten the rod nut against the swivel. Then tighten the lock nut. Do the same with the 1-2 rod on the middle rod on the shifter and then the 3-4 which is the outside rod . This should set you up, according to Chilton.
They note that if the tranny is 68 Camero Muncie the shift rods need to be shortened 3 complete turns of the lock nut.
Hope some of this helps.
Aug 13, 2010 | Chevrolet Camaro Cars & Trucks
Hi I have a KOHLER Fairfax Chrome Double-Handle WaterSense® Bathroom Faucet and the drain stopper keeps popping out. My husband and I have tried numerous times to fix it and can't. I also cannot...
Un screw the nut on the drain tail piece that attaches the rod to drain pipe .Pull the rod out just slightly.Hold the drain plug in the hole with the notch sitting side ways.Push the rod back in angled so that the tip inside drain is angled up.You should feel it go through the notch on the drain plug .If it has you should not be able to pull it out.Tighten the nut hand tight and work the plunger it should be attached .If not loosen the nut again pull back on the rod and shift it around until you feel it go through the notched hole on the plug bottom
Jun 22, 2010 | Home
No tell tale.
water pump-
crack in the housing from sitting over the winter with water in it
Apr 14, 2010 | 2006 Mercury Mariner
Wont shift between forward and reverse.
The shift rod actually connects to the transmission somewhere close to the middle of the bike
May 11, 2009 | Polaris ATV
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
46 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
