Question about Masque Solitaire Antics Deluxe for PC and Macintosh
Will Masque solitaire antics deluxe work with windows 7
I just purchased a new PC running Windows 7 and would like to load this software from a disc that I used for Windows XP
Problem loading photo explosion delux version 3 disc 1
You can right-click on the program's setup.exe, select properties, then compatibility and set it to windows XP
then try to install it again
Dec 15, 2007 | Nova Development Photo Explosion Deluxe...
Does ultimate solitaire 1000 games work on windows 7
It should, if its designed for Windows xp you should be fine!
If it does not work/says you have 64bit try right clicking installer click properties, compatibility and set to windows xp.
When you do that install it.
Right click the exe and repeat the compatibility stuff. Tell me if it works.
Apr 22, 2014 | ValuSoft Ultimate Solitaire 1000
I purchased printshop 20 deluxe and installed on my computer which has windows 7 installed on it. The installation shows it was successful however when I try to run the printshop program it tries to start...
The Print Shop version 20 Deluxe for PC is not compatible with Windows 7. The newer Version 23 is compatible. This is due to software compatibility issues with Windows 7.
You can check for Win 7 Compatibility for "software or hardware" @ Windows 7 Compatibility Center
It will not run on Win 7, even when you are using the Compatibility Mode options. Too bad you have to get the newer version 23.
Hope it helps.
Mar 14, 2011 | Broderbund The Print Shop 20 Deluxe for PC
I purchased windows 7 and I have print shop 22 how do I upgrade it to run with windows 7?
Check with Broderbund - either it will work OK - some programmes do or you may have to buy an upgrade - when have you heard that before!!
Feb 26, 2011 | Broderbund The Print Shop 22 Deluxe Full...
Can not load older software on new pc with windows 7
The software Broderbund 3D Home Architect Deluxe 5.0 might works with the earlier version of Windows and does not work with the latest version. Check out the system requirement for the software and its says its for windows 98, 2000 & Xp hence the updated drivers for the suite are not released hence it would not be able to install it on New windows version.
Jan 07, 2011 | Broderbund 3D Home Architect Deluxe 5.0...
I installed printshop 2.0 deluxe on my new computer running windows 7 and I can't get the program to load up. What can I do?
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 24, 2010 | Broderbund The Print Shop Deluxe Version...
My old beloved interplay solitaire deluxe for windows disc will not load on windows 7!!! Help!
Probably your old program is not compatible with your new OS i.e. Win 7.
Go get a newer version which is Win7 compatible.
Jun 28, 2010 | Computers & Internet
Masque Solitaire Antics Deluxe for PC and Macintosh Logo
43 people viewed this question
Top Masque Video Game Consoles & Games Experts
James Wishart
Are you a Masque Video Game Console and Game Expert? Answer questions, earn points and help others
