Question about Dell Latitude E6500 Laptop
No hard drive detected!
Error code 2000-0150 How can I get data from this harddisk? Thank you
    Habit-Forming:
  • 68 Answers
Hi Didier,
You can try a free data recovery program: Free Download Data Recovery Wizard EaseUS
Note: In case the hard drive hardware is broken , so you will need professional data recovery service: The World Best Data Recovery Services by datarecovery com
G'Luck !
Posted on Mar 30, 2014
4 Suggested Answers
sweetyanne
  • 68 Answers
SOURCE: Hard Disk Crash
Actually if the hd is corrupted, you can try to go to safe mode or do a chkdsk and then fix boot otherwise you need to contact drivesavers for that.
Posted on Nov 04, 2008
  • 3 Answers
SOURCE: My dell inspiron 1525 notebook comes up with error
WHEN COMPUTR STARTS PRES THE F2 BUTTON , IT WILL TAKE U TO THE SYSTEM SETUP , GO TO ONBOARD DEVICES , OPEN AND GO TO FLASH CACHE MODULE AND DISABLE ( OFF ) THEN GO TO SATA OPERATION ALSO IN ONBOARD DEVICES , SET IT TO BE ON ATA NOT AHCI , THAN AND SAVE !!!! DONE ,NOW U CAN DO WHAT THATS IN UR MIND FUTHER QUESTION OR WANT TO EXCHANGE IDEAS EMAIL ME ON JAYSPRUNG@GMAIL.COM HALLA AT ME
Posted on Jun 16, 2009
SOURCE: error 0141 msg:error code 2000-0141
The hard drive has failed. If you're in warranty, contact Dell for a warranty replacement of the drive - it's a customer-replaceable part.
If you're out of warranty, look on ebay for a good deal on a brand new hard drive for your Dell Inspiron 1525
Posted on Nov 09, 2009
My hardisk showed 2000-0146 error and it got replaced with new harddisk.. can i recover data from my old harddisk?
Try connecting the hard drive to an USB hard drive adapter and connect it to a computer's USB port. The computer should see it as an external storage device and you can open the various folders and files to backup your data.
If the computer cannot detect the hard drive as an external device then the hard drive is faulty.
If the hard drive makes a clicking noisy then it is definitely faulty and replacing the circuit board cannot fix this problem.
There are companies that can retrieve data from a faulty hard disk BUT it will cost you an arm and a leg for their services.
Jan 24, 2011 | Dell Latitude D630n Notebook
Hard drive not detected what can i do
If your hard drive is not being detected the moment you startup the computer, then try to turn it off and open the computer's casing. Pull the two cables connecting to your hard disk and wait for like 5 minutes before plugging the cables back to it. Then power it back and see if it gets detected. If not, then your harddisk might have failed. You might want to check it though thru the CMOS setup if the Seagate disk drive is still on the list of the Boot devices. If not, then you can do a data recovery by unmounting the harddisk from your computer and put it as a slave drive to another computer or to an external harddisk usb enclosure.
Should you need further assitance, please let me know. Thank you for using FixYa.
Dec 16, 2010 | Seagate Computers & Internet
Hi my Transcend 320 GB harddisk is not getting detected. Storejet 320Gb
hello
connect the USB external hard disk to usb port by the way disconnect other working harddisks
available on the system, boot the system with bootable cd/floppy go to command prompt and run
chkdsk on this drive
Also download "mbrfix" connect all working harddisks along with the nondetecting harddisk and run mbrfix for the USB defective harddisk
Try using different USB data transfer cable, if power source adapter is used check for rated power output in multimeter for this adapter, if found defective replace it with new/good adapter with same
specifications
Bad luck if harddisk controller has failed you have to go in for new harddisk
GOOD LUCK ooo
Nov 10, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
HDD Maxtor 80Gb IDE: Harddisk error! At boot it say's Primary harddisk error. Press F1 to continue. *When I press F1 nothing happens. *When I go to the bios at IDE Configuration and hit refresh at Primary...
OK the only shot you got is to geta USB to SATA/IDE converter dongle, connect to another PC's USB port. Hopefully, you will be able to read it. Otherwise still plugged in you may be able to use recovery software and get you DATA back. Recover my files is one,
http://www.recovermyfiles.com/
Other freeware data recovery software GL.
http://www.freebyte.com/filediskutils/
Feb 15, 2010 | Maxtor Hard Drive
Is it possible to get the data of a hard drive that pc & laptop cannot detect
its possible to get data from harddisk of the pc, make sure you have connected power to harddisk and its data cable to your laptop so that it will be detected
Oct 19, 2009 | Dell Inspiron 1525 Notebook
Hard disk not detected but Cd Rom drive detected
reconnect data cable or sat cablew to harddisk
Aslo reattch power cable to it.
Then check in bios that if u have sata then sata must enabled in bios.
May 22, 2009 | Seagate Barracuda 40 GB Hard Drive
HDD unable to detect at My Computer
Well first I would pull the hard drive out of the case. I would then get a USB to IDE/SATA drive cable. I would connect the drive not being able to be detected to another computer via USB.
If it works the drive is still good but the data might be corrupt. If the data is corrupt I would be sure to get any stuff you can off of it and basically reformat and reload.
Mar 13, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
Computer doesnt detect chrashed harddisk so that to recover data
Your going to need a technician that specializes in hard drive data recovery.
Nov 19, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Problem with recovery of the system (Windows XP)
check the status of harddisk on bios, whether detecting it or not if detecting then also check the hdd status, change its native status
Oct 24, 2008 | Toshiba Satellite A135-S4527 Notebook
"Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Apr 10, 2008 | Compaq Evo N610C Notebook
Dell Latitude E6500 Laptop Logo
224 people viewed this question
Alun Cox
