Question about Kitchen Ranges
Kenmore 790 electric range
My oven door will not close completely. It opens by itself and turns the light on.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 176 Answers
Clean well the bottom or you have broken hinge. Replace.
Posted on Mar 30, 2014
4 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Oven light remains on when door is closed.
This range was probably made by Whirlpool or one of its dozen divisions so it probably has some slop in the hinge mounting to correct for their so-so manufacturing. You may have to somewhat disassemble it to get to the hinge screws though.
Posted on Feb 26, 2009
SOURCE: Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Posted on May 25, 2009
SOURCE: on my Kenmore 790 range
Closed the door (as far as you can close it) and then I press the self clean button. Set the time for two hours and the display will read " lock" and the 'system will think it is locked. Then press "cancel/stop" and wait for three seconds. The cleaner will stop and read "unlocked" After that, the lock hook that is sticking out will pull itself back in and then you can fully close the door
Posted on Oct 19, 2010
Kenmore electric range model 790 door lock light flashing
Hi, When door locks, This is when oven is in self clean mode. After the heat has cooled down the door should release again. If this does not work try turning the power off to the stove (breaker) This should reset the stove to normal. Call a repair man if this continues. Good luck.
Jun 01, 2015 | Kenmore Kitchen Ranges
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Why does my kenmore range beep and show an error code every time I open the oven door?
See if this helps...
http://link.brightcove.com/services/player/bcpid1910171499001?bckey=AQ~~,AAABAWGODxk~,hLHEX2tm6AFlgSDzRIBPGX7yjI__nHLT&bctid=1974107068001
Also
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code.
Also
F3 or F30 means that there may be a problem with the oven sensor.
Your oven sensor may need to be replaced.
Jul 08, 2014 | Kenmore Kitchen Ranges
The F1 code is a problem with the very sensitive electronic panel inside and it probably got taken out when the socket shorted out. Here is the part to order. There is a video on that same parts page to show you how to swap the board out.
Aug 18, 2013 | Kitchen Ranges
Jan 13, 2009 | Kitchen Ranges
Kenmore model# 790 94463700 serial# VF 735 37589
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 23, 2008 | Kenmore 96212 / 96214 / 96219 Electric...
I had the same problem. Open the oven door. Press and hold the light switch. You will hear the door lock move back into the correct position. Hope this fixes your problem. This has happened to me twice and holding the light switch always works.
Jul 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Self Cleaning
unplug the range.
wait 1 minute.
wait 2 minutes.
Mar 03, 2008 | Kenmore 94220 / 94221 / 94222 / 94224 /...
Oven door
dat, If your model starts with 790. there is a service flash regarding the hinges. Oven door not closing all the way. Affected model serial numbers VF-428xxxxx through VF-434xxxxx. There is a hinge kit for it, part number depends upon your full model number. You may want to call Sears and inquire about the service flash, you should be covered. Catriver..post back.
Mar 04, 2007 | Kenmore 96213 Electric Kitchen Range
Kitchen Ranges Logo
71 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
