Question about Cycling
Shifting timberline bikes
How do you shift gears?
  • 1137 Answers
SOURCE: operator manual for huffy crosswind bike grip shift
Look for the manufacturers name and model number on the gripshift and check at www.parktool.com. Look under derailleurs for repair tips which will give you an idea how they work. A twelve speed has six gears on the rear sprocket and two on the crank giving you a combination of twelve speeds. sheldonbrown.com is another good site with good articles and pictures.
Posted on Jul 17, 2009
dunnbiker
  • 8546 Answers
SOURCE: 18 speed bike 6 gear shift works fine 3 gear
If the cable is rusty or otherwise binding it won't let the derailleur fall toward the smaller sprockets when the control is moved. Likewise, it may not even let you move the control in the direction that pulls the cable (bigger rings).
If you don't know much about the process I suggest you read this:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
and take the bike to a Local Bike Shop for a look-see and maybe a tune-up.
Posted on Mar 16, 2010
  • 130 Answers
SOURCE: Hello there! My mom just
first identify the problen is it front or rear derailuer.secondly bike shop mechanic hate cheap mass produced bikes because they do not sell them
so lets solve your problem,okay sometimes this can be an adjustment issue.now if its bunching on front then first read your owners manual to see which gears are compatible,sometimes it will suggest not using certain gears,secondly if yhe chain has fallen off and got jammed it may be bent and need replaced visually confirm if the chain is straight.okay if it is not the chain then the length and length adjustment can be changed using the adjustment on the rear derailuer look and you will see 3 screws located on it the two with L /H are for adjusting the gear stops l is for low gears,so it does not go too far and wedge between the gear and spokes,H is for the small gear(high)if it goes past and falls off adjust this one.lastly the one located at the very rear adjusts chain tension the loosening of this one will relax the chain and apply more chain on the gears   tightening of this one will tighten the chain,adjusted properly your chain should not bow down over adjustment will cause chain skips.now if there is too much slack in the cable that is adjusted by the adjusters on the ends of the cable where it meets the shifters,learning to adjust your bike will save you a lot of money in the long run.
hope this helps
Posted on Jul 16, 2010
dunnbiker
  • 8546 Answers
SOURCE: talera all gt terra mountain
Look at the derailleur hanger alignment first to make sure its not all bent up, then the adjustments.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
http://sheldonbrown.com/chains.html
Use search engines to answer generic questions.
Posted on Jul 05, 2011
dunnbiker
  • 8546 Answers
SOURCE: how do I shift gears
The technique is online in many places. "how to shift a bicyce". If you have mechanical issues (besides not pedaling while shifting) try to define them better.
Posted on Aug 10, 2011
Wont shift into second gear while not running
Hi, Michael for more information about your question and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have a nice day.
http://pnwriders.com/threads/bike-wont-shift-up-into-2nd-gear.191191
Bike only shifts between first and second gear
Ninja 250R won go into 2nd gear
http://xlforum.net/vbportal/forums/archive/index.php/t-952546.html
Apr 15, 2016 | Motorcycles
Timberline manual
The owner's manual doesn't do a very good job of explaining how to repair your shifters. Here is a link to various shifting problems and how to fix them.
Repair Help and Education
Mar 30, 2014 | Cycling
I need 2,3 & 4 gear for Yamaha 1100 special 1982 model
Instructions
    • 1 The gears on a motorcycle run in this order: first, neutral, second, third, fourth and fifth. When you are moving, shifting up from first gear will skip over neutral and shift you right into second gear. The only time that shifting up from first will get you into neutral is when you are not moving.
    • 2 Pull in the clutch lever and tap the gear lever down until it stops. This will signify first gear. Pressing the gear lever down will shift you down one step and pressing it up will shift up one step.
    • 3 Tap the gear lever up one click while still holding in the clutch. This will put the bike into neutral.
    • 4 Start the bike. The bike needs to be in neutral to start.
    • 5 Hold in the clutch lever and tap the shifting lever down to shift to first gear.
    • 6 Release the clutch slowly and give it just enough gas to get moving.
    • 7 Listen to the motor to know when you need to shift. If the engine is making a low grumbling noise, then it will need to be shifted down. If it is making a high squealing noise, then it needs to be shifted up.
Jan 15, 2013 | Motorcycles
Where can I find 2/3 & 4th gears for Yamaha XJ special 1982 model.
Instructions
5
6
7
1996 Honda CBR 900 won't shift into 3rd gear
Hi, Anonymous and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
http://www.fireblades.org/forums/honda-fireblade/58226-gear-box-issues-hope-its-not-serious-plz-help.html
HELP Bike Won Shift Into 2nd or higher CBR Forum Enthusiast forums for...
Honda CBR900RR Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR900RR FIRE BLADE Owner Manual
Jul 28, 2012 | 1996 Honda CBR 900 RR Fireblade
In shifting though gears, with bike running and stationary, after shifting in to first gear hard to shift into neutral without tuning off power to bike.
The bike has a slightly bent shift fork. The repair is a pretty major operation and I don't recommend the casual mechanic attempt it. Below is a diagram showing how the shift drum moves slider gears for different gear changes. Please rate my answer. Thanks. tombones49_128.gif
May 10, 2011 | 2001 Suzuki SV 650 S
How to operate the gears and shift , I got the bike givin to me no manuel all I know is the it looks to be in good shape
log onto trek.com and go to support. Shifting gear isw simple enough just press the bottom shift to go up nto easier gear and pull on top shift to go to higher(harder) gear
Mar 21, 2010 | Mountain Trek Bontrager 24 Spoke Radial...
Mar 16, 2010 | Huffy Alpine 24 Youth All-Terrain Bicycle
Wont shift into 2nd
First, with the bike not running, rock the bike back and forth and try to shift the gears. You should be able to shift up through all the gears and back down. If you can't, the problem is in the shifting mechanism. They've had some shifter pawl problems on earlier models. You'll have to pull the primary cover to get to the shifting mechanism.
Next, put the bike in first gear with the engine off. Now, pull the clutch in and try to start the engine. If the bike lurches forward, you're problem is the clutch. Check the adjustment of the clutch according to the service manual.
Sep 23, 2009 | 2005 Harley Davidson XL 883L Sportster
Shift Bicycle Gears
To shift gear properly, while riding the bike you be sure you are turning the paddles, and shift the gear.
Try to avoid shifting gears while riding standing up, this stress the gear system.
Oct 29, 2008 | GMC Denali 700C Road Bike
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
