Question about HP Compaq FS7600 17" CRT Monitor
What is the best resolution for the compaq fs7600 monitor
I would have to say 1024 x 768.
Posted on Jul 23, 2009
How do I fix the resolution it is was to big
if you are in Xp right click on the desk top. go to Proporties, goto Settings, use the slide to adjust the screen size of the pixel resolution you want. click apply.
the smaller the number the bigger the font. so an 800 x 600 is huge where as a 1920 x 1080 is small. (you can have different resolutions it doesnt matter your screen size physically)
Dec 22, 2011 | HP Compaq FS7600 17" CRT Monitor
MONTOR RESOLUTION IS WAY TO BIG . HOW DO I FIX
you can go to control panel / apperence and personalization in vista under this in the list is adjust resolution , you can also go thru the video drivers ( if you have a video card installed ) also some monitors have this setting you can change in the menu options . this should be almost if not the same as in windows7 .
My Brother is trying to connect to HP Pavillion XT914. A friend connected her flat screen to his pavillion to help him delete unwanted files and he can't get the monitor to work any more. How do we get his...
It might be that the screen resolution set on the pc is too high for the monitor to display.
try hooking up the flat panel monitor again. (CRTs can have a flat screen as well)
lower the screen resolution to 1024 X 768 pixels click save.
hook up the other monitor to see if that was the problem.
If you can get the monitors menu to come up on the monitor try setting it to factory defaults.
If no luck, does the monitor work on another PC?
Let me know if this helps you or not.
Thank you
Feb 05, 2011 | HP Compaq FS7600 17" CRT Monitor
Why does my monitor keeps adjusting to the 4bit color only and I can not adjust the resolution
Color bit depthe is not the monitor problem, it is the video card problem, make sure you have correct video card driver installed.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 28, 2010 | HP Compaq FS7600 17" CRT Monitor
What is the corect resolution for this moniter
It's native resolution is 1280 x 1024 / 60.0 Hz.
Jan 31, 2010 | HP Compaq FS7600 17" CRT Monitor
Monitor resolution is poor
check your video display drivers. this will cause issues with video display on monitors, look on your computer manufacturers site for the most up to date ones. then right click select properties while in the desktop, go to graphics options or graphics and check your resolution to make sure you have the highest possible settings for that monitor....
Good Luck!
Ruben
Jul 19, 2009 | HP Compaq FS7600 17" CRT Monitor
Hp Compaq FS7600 17" monitor screen adjustment needed
Um, lets see. Does any of the buttons work? Try and find a button that will switch settings back to factory default. If not go to control panel and change the screen resolution to see if that helps in the mean time.
Jun 26, 2009 | HP Compaq FS7600 17" CRT Monitor
Somehow, I've enlarged the image size on my Compaq 7600 monitor. How do I reverse it?
Right-click the desktop and go to properties.
Under the settings tab you can change the screen resolution size. the bigger the number the smaller the icons will be on the screen
Dec 08, 2008 | HP Compaq FS7600 17" CRT Monitor
My computer says out of range change screen resolution
boot into safe mode (f8 after you restart)
it will use vga mode for display
reset your resolution to somethig lower (1280 x 1024?) then reboot
Nov 22, 2008 | HP Compaq FS7600 17" CRT Monitor
HP Compaq FS7600 17" CRT Monitor Logo
142 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
