Question about Frigidaire Dishwashers
Reset / lock release
I "locked the lock" while the dishwasher door is open, need to either reset or release the lock. how do i do that?
  • 85 Answers
Might try turning power off then on...
Posted on Mar 31, 2014
SOURCE: Kenmore dishwasher Lock-On light flashing, will not start
Push the heated/dry button on the dishwasher for 4 seconds and that will unlock the dishwasher. This is just a safety feature that allows you to lock the dishwasher to stop kids from pushing buttons.
If that doesn’t’ work they will send out a tech to fix it.
Posted on Nov 09, 2007
  • 9 Answers
SOURCE: Dishwasher door not catching
that is the spring thats gone and will not lock the jaws you need to replace the lock on the door normaly about£5.00
Posted on Dec 06, 2007
SOURCE: KitchenAid Dishwasher KUDSO2FRSS
I recently had the same problem. One of the cords that attaches the door to a spring had snapped. I purchased cord replacments at the following URL and completed the repair myself. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1059756&PPStack=1
Good Luck, Tim K.
Posted on Jul 07, 2008
  • 3 Answers
SOURCE: Dishwasher door won't open, latch seems broken
Hello, I read your comment. If the latch is broken, then I suggest first of all disconect the electricity from the dishwasher. You may want to try using a small screwdriver and insert it where the latch is to activate the opening mechanism. If it doesnt open, then there are two options, I suggest to call the technical service to replace the door with a new latch.
Hope I have been of help.
Regards Nevd ´ll fixya.
Posted on Feb 15, 2009
amgm
  • 32 Answers
SOURCE: door lock assembly Hotpoint dishwasher
Hello.
First switch off the power.
Get the cabinet door off, start by removing the side screws that hold the door (please have someone to help you, holding the door, because this doors are heavy.)
After you removed the door, remove the screws holding the fascia (about 2 on each side + 2 holding the door lock).
Remove the fascia and you wil get acess to the door lock, disconnect the wiring from the micro switch, connect the new par and reverse the process.
Cheers
Posted on Feb 19, 2009
Door is open but the lock is still locked how do I get it to unlock or reset
The door of the machine being open allows you to open the inner panel of the door by removing the screws around the periphery, in order to access the door lock mechanism. Replace if damaged.
Sep 21, 2014 | LG LDF6810ST Stainless Steel Built-in...
My dishwasher WQP12-9240A door will not open and my dishes are inside can you please help. Peta
Sounds like the door lock Mechanism is not shutting off , if still connected to power supply take out plug or turn off power for 10 minutes this may release door lock, this can sometimes reset a jammed programmer not always the solution but worth a try
Jun 25, 2014 | Dishwashers
I need manual for Bompani Dishwasher BIDI60FSS Please as I cannot open my brand new dishwasher as I cannot release the door lock?
some dishwashers require the door release to be held for a period of time. This is a child safety feature
May 04, 2014 | Dishwashers
Door lock
Pull the door latch towards the front of the dishwasher until it clicks in the open position.
Mar 30, 2014 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Machine started with door not shut
to release the door lock you have to pull the outer door and inner door away from each other at the top. if you have a wood panel, pull the handle of the wood panel away from the stainless steel inner door panel. you will notice the outer door panel will move out about a quarter inch. you will then hear the latch pop open. once you do that, close the door and select your cycle as usual.
Jun 22, 2012 | Miele Incognito G818SCVi Built-in...
Cannot unlock door lock
Can't help on the lock release, but will say that OFTEN the detergent will not dump if it is filled too much. Leave a little space.
Dec 26, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher door locked shut
Apply firm pressure to the door while you press or pull the release latch. The screws holding the latch assembly could have loosened. Tighten screws after you get it open.
Jul 07, 2009 | Dishwashers
Kenmore dishwasher lock light
you tried holding hte "control lock " buttonn for 3-5 secs and it still didnt unlock??? if thats the case your problably gonna need to replace te console/ touchpad
Nov 30, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
I WHANT TO RESET MY MASTER LOCK , WHAT STEPS I HAVE TO FOLLOW?
Instructions:
Opening the key storage
compartment door
1. Open shutter door to reveal the dials
and the release button
2. Rotate dials to the current combination
(if the lock is new, the combination is set
at the factory to 0-0-0-0)
3. Press down on the release button
to open the door
4. Pull the door fully open
5. Add or remove keys
6. Close compartment door
7. Scramble the combination dials to lock
the door and conceal your combination (A)
8. Close the shutter door (B)
To set a new combination:
The initial combination is set at the
factory to 0-0-0-0
1. Open the compartment door
(see instructions above)
2. Push the reset lever left and down.
The lever remains in this position
3. Rotate dials to your desired combination
4. Push the reset lever, up and right, back
to the original position
5. Close the key storage compartment door
6. Scramble the combination dials to lock
7. Close the shutter door (B)
To hang shackle model
2. Push the shackle release lever to the left
to open shackle
3. Pull the shackle up and out of the lock
4. Place shackle around door knob or other object
5. Close shackle to lock
6. Close the compartment door
Reminder:
(A) The release button will open the lock
until you scramble the dials
(B) Keep the shutter door closed to increase
weather resistance and to conceal the
dials from view
Mar 05, 2008 | Master Lock 5400d: Portable Select Access...
Dishwashers Logo
59 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
