Question about M-Audio Computers & Internet
Pinnacle moviebox plus driver
My new laptop has no firewire connection. Are there any adaptors on the market? Would the laptop and soundcard work with a firewire to usb cable? Or would the pinnacle moviebox work as an adaptor?
    New Friend:
  • 87 Answers
Buy a pcmcia firewire card for your laptop, usb for movie capture is not good.
Posted on Apr 04, 2014
3 Suggested Answers
  • 3 Answers
SOURCE: Edirol FA 66 firewire
Download/install the drivers from roland/edirol site for PC. For Mac, its plug and play. Just select the edirol in the audio options.
Posted on Dec 03, 2009
JSPCEXPRESS
  • 178 Answers
SOURCE: M-Audio FireWire 410 External Distorted Playback...
Hello have you disabled all the built on sound cards on your computers? This is a known problem. If you are going to use a great product like M-audio disable any onboard audio card. Then try to use the 410 system. If you still have the problem try changing the latency to 4-5
Posted on Feb 10, 2008
Does Pinnacle Studio plus 12 work in Windows 7?
Yes, I installed Pinnacle Studio 12 Plus and run on the Window 7.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 21, 2011 | Pinnacle Studio MovieBox Plus...
I have a pinnacle moviebox 510-usb. The specification contains, you can streaming from analog secam source, but in importer section i can't see any video after switched secam mode, while the vcr play...
Be sure that your MovieBox capture device is selected under Studio's "Setup/Capture Source" selection (assuming you're capturing analog). If the MovieBox doesn't show up in that selection window, there could be a problem with the device.
Additionally, check in the Diskometer left-hand panel (this is found at the center of the bottom of the screen) and see that the correct input port value (either composite or s-video) is selected.
If you're capturing digital, then you'll have to use a Firewire connection to the MovieBox device.
Hope that's helpful.
Dec 31, 2010 | Pinnacle Studio MovieBox Plus - Video...
I need a MovieBox DV (1394)driver compatible with
Pinnacle Software has a Vista Patch to use with their applications that you have to download and install. I had this same problem when I used Pinnacle for my remote camera system.
Jun 25, 2010 | Pinnacle Studio MovieBox DV 9 (210100349)...
I need power adapter volt/amp
Looks like maybe 3.3 volts, 1.5 amps not sure of the polarity.
The Pinnacle Studio MovieBox DV Includes
  • MovieBox DV external analog to DV converter
  • Full version of Pinnacle Studio 9
  • Hollywood FX transitions
  • TitleDeko for titling
  • 4pin/6pin IEEE-1394 FireWire cable
    6pin/6pin IEEE-1394 FireWire cable
  • Power Cord
  • Power supply: 110V 60HZ 3.3V/1.5A
  • Studio Software 9 manual
  • MovieBox DV hardware manual
Dec 12, 2009 | Pinnacle Studio MovieBox DV 9 (210100349)...
Does moviebox usb work with studio 14 and vista? I can't get my camera to show as an import device when connected to the movie box.
This is the latest hardware device that can used for Studio 14.
Check the list.
USB based
  • 710-USB
  • 510-USB
  • 700-USB
  • 500-USB
  • MovieBox Deluxe
  • DVC-103
  • DVC-107
  • DVC-100
  • DVC-90
  • DVC-130 (There are no 64-bit drivers for this product.)
  • DVC-170 (There are no 64-bit drivers for this product.)
PCI based
  • 700-PCI (a.k.a. Pinnacle Studio Deluxe 2)
  • 500-PCI (a.k.a. Pinnacle AV/DV)
  • Any 1394 cards.
Are you using vista 32 or 64 bit system? If Vista 64 bit there is no driver for your device and the only available is 32 bit only. Aside from that you can check also the video cable you were trying to used. If firewire under import/capture tab of Studio 14 you need to select the name of your camcorder or dv camcorder. Check that out and try.
Dec 07, 2009 | Pinnacle Studio MovieBox USB Video Capture
Pinnacle MovieBox USB Power
You can use a universal one but it has to be 3.3 Volts at 3 AMPS and the tip of the plug must be positive. If you have a radio shack by you they should be able to get you the correct adaptor.
Thanks,
Mark
Nov 01, 2007 | Pinnacle Studio MovieBox USB Video Capture
Saving Dv tape to computer? Getting computer to see camera?
The USB connection is for getting still images (photos) off the camcorder. To get moving images (video) off the camcorder, you must use a FireWire cable (IEEE 1394). The cable only costs about $15. But you need to have a FireWire port on your computer to plug it into -- if you don't have one, you'll have to install a FireWire card. Check someplace like TigerDirect computer parts supplier, they are only $15 to $60 now.
Or, if you don't want to open up your computer to install a FireWire card, you can buy a Pinnacle MovieBox for $120. It just sits next to your computer, not inside. It is very easy to use and comes with great video editing software. You plug the FireWire from your camcorder into the front of the MovieBox, then plug the back of the MovieBox into your computer with USB.
Plus, you can use the MovieBox to record from your VCR or DVD player into your computer! For that, you'll need the standard red/white/yellow cables.
In fact, if your camcorder has those cables, you can use them to go thru the MovieBox, and save yourself the cost of the FireWire cable. But I think FireWire will give better quality than the red/white/yellow cable.
Sep 25, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Computers & Internet Logo
63 people viewed this question
Top M-Audio Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
