What type if batteries are needed for Honeywell's thermostat model RTH2310?
  • 2,509 Answers
Two AA or LR6 batteries alkaline type (Duracell for example)
Posted on Apr 05, 2014
What type of batteries are needed for the Honeywell thermostat model RTH2310?
Two AA or LR6 batteries alkaline type (Duracell for example).
Mar 30, 2014 | Heating & Cooling
Operating manual honeywell rth2310
Honeywell has the manual for the RTH2310 programmable thermostat on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH2310B.htm . The direct link to the English/French version of the operating manual is http://customer.honeywell.com/techlit/pdf/PackedLit/69-2229EF.pdf .
I hope this helps.
Dec 13, 2011 | Honeywell Programmable Thermostat Heater
The backlight is not working on my newly installed Honeywell RTH2310 thermostat.
Hello.The thermostat needs a COMMON wire.The letter C on the back of the thermostat.In the unit it runs there is a COMMON connection for that reason.I hope there is a spare wire strand to use because a lot of thermostats don't need a common to work (uses battery)but honeywell does.
Oct 31, 2010 | Honeywell Focus 6300B 5-2 Days...
Honeywell RTH2310 thermostat temp variance
Yes you can change that by change the number of cycles per hour that your t-stat looks from for youe furnace. Lower the cycles per hour number and it will increase the range.
You can see how to do it here
http://dl.owneriq.net/3/39359643-dfda-451d-bb81-828eecddd9fc.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Wiring problem?
Yes to everything!!
You have it figured out!!
Just make SURE that the blue unused wire cannot touch any of the other wires, it will wreck your transformer in a split second.!
Heatman101
Nov 25, 2009 | Honeywell Programmable Thermostat Heater
I have a new honeywell thermosat rth2310 and the heat will not go on
Did you just install it????? If not check the batteries and replace them first....check for corroding also....if you just replaced the thermostat did you wire it correctly????/Wire for Wire???? If so if you have 4 wires in your thermostat you require a jumper wire between RH & RC....if you have 5 wires...no jumper is required....is the Furnace power on???
Nov 01, 2009 | Honeywell Programmable Thermostat Heater
Wiring new RTH2310 DIY Honeywell
sounds like you've got bear wires touching at the new tstat
Sep 18, 2009 | Honeywell Focus 6300B 5-2 Days...
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
