Is there a reset button on the kitchen aide
The filter elements are mostly likely not correctly in place so the latch is not tripping the micro-switch. Using a flash light this was clear by looking down into the front edge of the vent unit. I could see the element edge and the latch of the filter element. It wasn't latched tight. I used a paint scraper (two). Gently i nserted it while also using a flash light to see. I was able to lever and jiggle the filter element back into place and latch it. This activates the control. Then the unit would raise. I double checked the filter latches to be sure they were tightly closed.
The hood won't come up at all no matter what I try. Is there anything I can check before spending 300 bucks on a repair man....
The only way to reset is to switch off at the power point and switch it back on.
hood kird801xss-3 does not come up when switch is pressed.
I think the filters were not back correctly after cleaning.
how can i bring it up manualy?
