Question about Honeywell RTH230B 5-2 Day Programmable Thermostat Large
Heat not coming on. battery died.
I have a honeywell rth230b tstat. while on a 6 day trip, i came home ot find the heat running nonstop and a temp of over 99 degrees. The display was blank. I took off and changed the batteries (there was never a low batt warning), and the heater finally shut off. (Packaged Furnace/Air Conditioner, Gas/Electric). Now the heater won't come on even though temp is under setting programmed. Itook off and tried the red/white wire trick, and heat did not come on. What kind of problem does that indicate?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
Please go to the link and check graph "2.5 Installing the Batteries". Its really easy so it should be a piece of cake.https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1800.pdf
Posted on Mar 30, 2014
Testimonial: "i already stated in my initial post that I changed the batteries. The heat is not coming on though, and the temp is below the setting temp. when i turn on the fan, it blows cold air. when it's set to AUTO, it doesnt even turn on."
  • 2 more comments
  • JT Features
    JT Features Mar 31, 2014
    Well the fan only moves air, it does not cool or heat it. In auto the air should stay off until the unit requests it. If you set the tstat to "70" and its "76" inside and system is set to cold you need to call a service to rewire the tstat because its wired wrong.
  • john c
    john c Mar 31, 2014
    Not sure where in my original post i said that i have no idea what I am talking about. I tried to be as detailed as possible. The unit kept running when the batteries dies in my tstat. I changd the batts and got it to stop running. It was over 99 degrees in my house. Ater the batts were changed, the temp is set to 66 degrees and it went down to under 60 because of a cold smnap in the area. The heat didnt come on. its set to HEAT and AUTO. When i switch from AUTO to ON, the fan blows, but its cold air. I will just call a guy today since it was assumed that I know absolutely nothing. Was told to CHANGE BATTERIES after my post had already said that I did. Then told that if the TEMP IS SET TO &) and ITS & AND THE AC DOESNT COME ON
  • john c
    john c Mar 31, 2014
    its early morning and i am typing in the dark. what i meant to say was"Was told to CHANGE BATTERIES after my post had already said that I did. Then told that if the TEMP IS SET TO 76 and ITS 70 AND THE AC DOESNT COME ON, ITS WIRED WRONG.".
  • john c
    john c Mar 31, 2014
    Add a Commenti guess it's true-"you get what you pay for". free advice.
4 Suggested Answers
  • 4 Answers
SOURCE: Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
Posted on Jul 26, 2009
  • 104 Answers
SOURCE: Replace battery
Yes, the battery must be replaced. Gently lift or pull of cover, the battery compartment is there. Best of wishes.
Posted on Jun 15, 2009
buffalonyman
  • 1865 Answers
SOURCE: My Honeywell RTH230B temp control problems
Yes, some thermostats rely on batteries for power to run and maintain programming
Posted on Jul 02, 2009
I have a Honeywell VisionPRO TH8000 series thermostat which is about 2 years old and what I find is happening is when I arrive home and I find that that the thermostat has gone into revovery mode which...
Check your drain line for a float switch. It's possible it is tripping the tstat (as it should) if the drain is backing up. Another scenario, depending on the type of unit you have is that the air is being forced into the float switch therefore tripping the tstat. If you don't have batteries in it, try putting batteries in it for a week and see if the problem goes away. If so this would mean the tstat is losing power somehow. Either float switch or faulty wiring. Good Luck!!
May 07, 2017 | Honeywell Programmable Thermostat Heater
My Honeywell Thermostat won't stay at the temp that I set it at!
You are likely running a schedule. When you go to tstat and change the temp it is a temporary setting that will expire in a given amount of time. 1, 2 3 hours etc. "HOLD" can sometimes bypass the schedule, "RUN" returns to the schedule. Not sure what model tstat you have but you have to exit your schedule.
Apr 18, 2017 | Honeywell Heating & Cooling
My 9 year old Honeywell T8001C has no display. My FAU AC power breaker is not tripped. I tried a new Honeywell RTH2510B and a RTH7500D but the Fan does not come on with either of the new units after...
This is why battery powered tstats are misleading. The battery provides the power to the tstat but your unit is not providing low voltage in order to run. Air conditioners are controlled by relays and contactors. This means your unit constantly has high voltage going to it but each component runs through a relay in order to turn on. These relays are energized by the low voltage that runs through your tstat. Your tstat is not getting this low voltage. Either your float switch on your drain line is tripped, your blade style fuse is blown on the secondary side of the transformer or your transformer is bad.
Aug 08, 2017 | Honeywell Heating & Cooling
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
Jul 02, 2009 | Honeywell Heating & Cooling
Message: "in recovery"
the "in recovery mode" is refering to a thing called energy recovery management its one of the features on your tstat what it does- when you are using the program on your tstat the "in recovery" starts your unit early so if the tstat is set to be 70 degrees at 8 in the morning when 8 o clock hits it will already be 70 degrees in your house you can turn this feature off if you want in the installation setup codes
Jun 24, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B 5-2 Day Programmable Thermostat Large Logo
197 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
