Question about Garden
WON'T START BY ROPE UNLESS YOU USE STARTING FLUID
  • 21 Answers
Use the choke if it have one. first put it full way. then half way. its supposed to start
Posted on Apr 10, 2014
2 Suggested Answers
  • 3600 Answers
SOURCE: will not start unless I use starting fluid
You gas tank filter is plugged remove the tank and replace the filter to get gas and don't use starting fluid on a two stroke you will send the piston out the side of the engine.
Posted on Aug 18, 2009
Compression lockup
Remove spark plug. Pull rope several times to blow out cylinder. Spray WD 40 in spark plug hole. Pull rope several times. ensure compression is present. Replace spark plug with new one. Spray starting fluid in cylinder before replacing spark plug. Ensure plug wires snaps on tight. Check oil level, fill with 30w oil if required. All mowers have a low oil start cutoff. Clean or replace air filter.
Sep 10, 2012 | Toro Power Lawn Mower
Toro Electric Start Problem
Remove spark plug and observe condition. Fouled with oil, bad motor. With plug removed pull rope several times to blow out cylinder. Spray WD40 in spark plug hole, pull rope several times see if oil blows out. Spray a lot of starter fluid in spark plug hole, replace plug. Spray starter fluid in air cleaner area of carb, try to start. Replace spark plug, try to start. Ensure oil is full, all mowers have a low oil sensor now. 30w oil. Always use Stabile in gas.
Jul 04, 2012 | Toro Garden
96 chevy blazer won't start.
your gas pump is maybe your problem
Jun 29, 2012 | Cars & Trucks
I'm following another issue like this on a 1996 Jimmy.
This engine requires 60psi or more fuel pressure to run.
You need to have someone check the fuel pressure at the rail- throttle body with a gauge.
Jun 29, 2012 | 1996 Chevrolet Blazer
Won't start, appears to be getting gas, primer bulb full.
HELLO. DO YOU HAVE THE USER'S MANUL.? IF NOT HERE IS WHAT YOU CAN TRY.(1) FIRST . TAKE OFF THE AIR CLEANER. AND CLEAN THE FILTER.. USE A LITTLE DISH SOAP LIKE DAMW.DISHSOAP AND WATER. ONLY. WASH & RINCE OUT.! THEN DRY IT OUT. (2) THING TO DO IS PULL THE SPARK PLUG OUT. AND REPLACE WITH THE SAME AS WHAT IT IS IN IT. (3) OR U CAN CLEAN IT WITH A TOOTH BRUSH & A LITTLE GAS ON IT. OR STARTING FLUID ON THE BRUSH .CLEAN IT THEN LET IT DRY OUT. AFTER THEY ARE DRY. (4) PULL ON STARTING ROPE WITH OUT THE PLUG IN IT. 3- 4 TIME'S . THEN (5) WITH THE AIR CLEANER OFF & THE CHOKE OPEN. LOOK IN THE CARBURATOR AND PUSH THE PRIMER BLUB. TO SEE IF IT IS GETTING TO THE CARB.? YOU SHOULD SEE IT OR HEAR IT OR SMELL IT.? IF THERE IS TO MUCH.&. IF THERE IS.! THEN PULL THE STARTING ROPE AGAN 3 TIME'S . (6) THEN PUT A VERRY SMALL AMOUNT OF GAS IN THE PLUG HOLE AND PUT THE SPARK PLUG BACK IN. & WITH THE AIR CLEANER OFF PUT THE CHOKE TO THE STARTSPOT.. PRIME IT 2-3 TIME'S WITH YOUR PRIMER BLUB AND TRY TO START. IT. IF NOT (7) PULL THE PLUG OUT AGAIN , AND PULL THE ROPE AGAIN 3 TIME'S . (8) THEN GET STARTING FLUID AND SQUIRT SOME IN THE PLUG HOLE & PUT THE PLUG BACK IN. ..THEN SQUIRT A LITTLE IN THE CARB & TRY TO START IT . IT SHOULD WORK. . IF YOU DO THE SOLUTION'S FOR THE PROBLEM YOU ARE HAVING THANK YOU . REMBER TO VOTE FOR ME THANK U.?
Jun 08, 2011 | Mantis 2-Cycle Tiller
Will not start unless I use starting fluid
Aug 18, 2009 | McCulloch Garden
1997 chev s 10
the intial issue would be that the fuel is not being injected into the cylinders on start up. check injectors and fuel pump for defects
Oct 23, 2008 | 1997 GMC Safari
Wont start without starting fluid
Could it be a plug up injector , have sewiing needle , stick it in the sprayer part of the injector on the carberator part
Aug 22, 2008 | 1990 Ford F150
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
