Question about Dirt Devil CE7150 Easy Steamer Deluxe Bagged Upright Vacuum
Dirt devil easy steamer deluxe won't **** up water
Can spray water but won't **** it up again
KOakaKO
  • 135 Answers
SOURCE: Ok, perhaps I am an idiot!
If you go to this URL: http://www.dirtdevil.com/CustomerService/Manuals/default.aspx ...and enter the model number for your machine, then you can download a users manual. I would just give you the exact URL for the user manual, but I don't know your model number. If this helpful to you, please leave a good rating. Thank you! ;)
Posted on Aug 13, 2007
SOURCE: Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
Posted on Jan 24, 2008
reddevil6
  • 1673 Answers
SOURCE: wet vacuum not sucking up water
Usually when these units don't pick up the water, there is a seal or gasket missing or out of place. But you have a years warranty on this, maybe you should take it to a warrenty shop and have it checked.
Posted on Jan 29, 2008
SOURCE: dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
Posted on Mar 28, 2008
blueextc3221
  • 15935 Answers
SOURCE: I need a new manual for dirt devil easy steamer deluxe
CLICK HERE for the owners manual in PDF format.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 19, 2009
I have a Dirt Devil easy Steamer delux,but lost the owners Manual,forgot how to use it ,can you help ?
I believe the following manual is for your machine. It's model # MCE6600. It's what comes up when a search is done for Easy Steamer Deluxe.
http://www.dirtdevil.com/manuals/?id=c6f182b2-b418-447d-951f-ca9456153b3d
Jan 10, 2011 | Vacuums
Lost the manual. Need carpet/solution water
Below is a link to dirt devil. just put in your model# for the manual.
However most cleaners you buy give you the cleaner to water ratio on the bottle. Also you do not need to use Dirt Devil cleaner. All carpet cleaning solution are pretty much the same aside from the fragrance. The best ratio that I have found is approximately 5oz of cleaner for every gallon of water. Make sure you use hot water. Using cold water or waiting to long to use the mixture can reduce the efficiency of the cleaner.
Hope this helps.
http://www.dirtdevil.com/CustomerService/Manuals/default.aspx?id=32173
Sep 04, 2009 | Dirt Devil Featherlite Easy Steamer Vacuum
Jul 19, 2009 | Dirt Devil Easy Steamer Upright Wet/Dry...
I have a dirt devil steam cleaner. do I put the water in both containers or the one that is long, on the handle
okay if your have one that looks like that picture for it the water goes in the white tank on the handle piece, if the water is not spraying i'm guessing your hoses are clogged, as this sometimes happens if that is the case, run some lime away through it but don't spray the limeaway on your carpet it will eat it just use it to rinse it out and clear it
Dec 13, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt devil easy steamer need directions to use
Mar 27, 2008 | Dirt Devil Easy Steamer Upright Wet/Dry...
Aug 13, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Jul 15, 2007 | Dirt Devil Easy Steamer Upright Wet/Dry...
Dirt Devil CE7150 Easy Steamer Deluxe Bagged Upright Vacuum Logo
21 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
