Question about Lexmark P350 InkJet Photo Printer
P 350 photo printer not reading sd card
No green light flashing
2 Suggested Answers
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: printer does not read memory cards or card reader
    Here's the list of compatible digital media memory cards:
    • CompactFlash I & II
    • SmartMedia Card
    • Sony Memory Stick, Memory Stick PRO
    • Secure Digital (SD) Card
    • MultiMediaCard (MMC)
    • Microdrive
    • 4 Built-in Card Readers
    • xD Card
    • Sony Memory Stick Duo (with adapter)
    Posted on Aug 11, 2011
    Green light on back of camera is flashing and I cannot view my photos
    Green light flashing means that the camera is reading the memory card. If it keeps on flashing and flashing means that the camera is trying to read the card and not able to. This means that there is something wrong with the card. You should stick your card into the computer and transfer all your data from the card on to the computer. after all your photos are safe on your computer, put your card back in to the camera. turn the camera on, press the menu button, navigate to the menu that looks like a wrench and in that menu select "Format Memory Card" this will erase and format the card to how it should be. after that, you should be able to view your photos normally. If that doesn't work your card may be faulty and you may have to purchase another memory card.
    Note: the camera might not display photos that you downloaded from you computer on to the card, cameras often only display photos that you took with the camera.
    Feb 28, 2011 | Nikon D60 Digital Camera
    I have successfully downloaded photos from my Polaroid PDC 3077 from the memory card (Fuji 128mb SD)to "my pictures" on my computer. I have bought a new camera Canon PowerShot A480 and cannot download my...
    Have you tried connecting the camera (with the memory card still inside it) to your PC? You should have a data cable that came with the camera, so instead of removing the card use your camera to download to the PC.
    Mar 08, 2010 | Epson Stylus Photo R300 InkJet Printer
    SD memory card error
    Please check if it is not an SDHC (larger than 2Gb) card. Some printers can only read SD (2Gb and smaller) while some can also read SDHC (SD High Capacity) cards.
    the C4180 can only read 2Gb and smaller (Standard SD)
    Feb 28, 2010 | HP PhotoSmart C4180 All-in-One Color...
    Printer wont read SD cards does read sony memory
    If it does not seat (fit) properly, why say the printer will not read SD cards? It certainly will read SD cards that are supported. You can still upload to computer and print from there as you suggested.
    Dec 27, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
    Sd slot used to read cards, now "memory card error"
    i am trying to copy my photos from my 4 GB SD memory card on to my computer through my printer HP PSC 2355 all in one printer. But as soon as i put the card into the slot it turns green and the a couple of minutes later turn Red and flashes and i cannot read it on my computer
    Dec 04, 2009 | HP Office Equipment & Supplies
    My smaller memory cards work, but my 4gb card says media error in my brother printer/scanner when I put it into the usb port (photo capture). Tried it dozens of time, doesn't work, but I was able to read...
    Many older system will only support standard SD cards up to 2GB and HD SD cards will go above 2GB. It is a limitation of the printer and not an error with the card.
    Nov 21, 2009 | SanDisk 2GB microSD Memory Card
    Printer will read memory card, but i cannot access from pc
    Files on a flash drive can be corrupted if it is not removed from the USB port properly.
    Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
    To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
    If you need the data on the flash drive these WEB sites may help: -
    Digital Photo Recovery
    www.artplus.hr/adapps/eng/dpr.htm
    www.CardRecovery.com
    Nov 19, 2009 | Canon PIXMA MP830 All-In-One InkJet...
    R300 will not read 2gb sd card
    Hi
    R300 doesn't support 2gb SD cards and there are no software updates that will make it read a 2gb sd card.
    Hope this help
    Dec 22, 2008 | Epson Stylus Photo R300 InkJet Printer
    I have an EOS Canon 400D digital SLR and my husband has bought me a Sony photo printer DDP-FP75 . I had wanted to be able to insert the memory card but it doesn't seem compatible. Can I print using the...
    The two are not immediately compatible. The Canon EOS 400D uses a Compact Flash card. The Sony Photo Printer you have accepts SD and Memory Stick cards. Unfortunately, the CF card and SD card are very different.
    The easiest solution I can think of would be for you to get an inexpensive card reader (make sure it accepts Compact Flash cards), attach it to your PC and then use it to read the CF card from your Canon EOS -- and print to your Sony printer.
    I hope this helps. If it does, please rate the solution offered. My goal is always FixYa or Helpful, never TFT or IA. Regards,
    Char1ieJ
    Nov 24, 2008 | Canon Cameras
    Memory card issue with Epson r300
    Hi , reinstall the printer driver with sd inserted.
    Jan 25, 2008 | Epson Stylus Photo R300 InkJet Printer
    Lexmark P350 InkJet Photo Printer Logo
    16 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
