Question about Silva Tech 4o Accelerator Pro Trainer Womens Fitness Watch
Changing battery on Accelerator Pro watch by Tech40 and small spring came out
While trying to get old battery out an itty ***** spring came out. Where does this go back to?
  • Silva Master
  • 15,557 Answers
The spring might be under that battery, look for a spring well. (little indentation)
Posted on Mar 30, 2014
Small silver spring in a casio Pathfinder
the spring is for the sound for the alarm ,it goes in small hole in back of watch ,this video will show you were it goes,,,this watch is only a example of were it goes.
Nov 12, 2012 | Watches
Found small spring when changing battery
This happened because the COIL SPRING was lost during the battery change. This happens quite often to DIYers, as they do not know how the watch is built and the coil spring itself is very small, so, it's easy to loose it without even noticing it. Coil spring transmits electrical signals/vibrations from watch's movement to the quartz membrane attached inside case back. Now you have to find yours or need to visit your nearest watch repair shop and ask for the new one to be fitted..
Oct 18, 2012 | Casio Watches
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    How to change battery
  • Spread the towel out on a flat surface.
  • Remove the watchband if necessary in order to access the back of the watch.
  • Unscrew the back protector from the watch using the correct size miniature screw driver. Place the screws in a small pile on the towel. Be careful not to drop them as they are difficult to find.
  • Remove the back plate by unscrewing the small screws. There is a tiny spring on the underneath of the back plate. It may be visible, or not. Make sure not to turn the watch upside down or the spring will dislodge.
  • Remove the rubber protector to find the battery.
  • Use sharp point tweezers to remove the clasp covering the battery. There is a small hole at one end of the clasp. Insert one end of the tweezers into the hole to spring the clasp loose.
  • Remove the old battery with tweezers.
  • Insert New Battery and Reassemble Watch
  • Pick up the new battery using regular tweezers and put it into place. Do not touch the battery with your fingers.
  • Replace the clasp over the top of the new battery.
  • Perform a reset by touching the AC contact with one part of the tweezers and the back of the battery with the other part. Hold for a few seconds. Lift the watch carefully and look up at the front to make sure the watch is working. Do not turn the watch over.
  • Replace the rubber cover.
  • Replace the back plate by screwing the small screws back into place.
  • Replace the back protector by screwing the small screws back into place.
  • Reattach the watch band to the watch face.
  • Feel a bit unnerved by this? Find a local jeweler. Best regards.
    Jewel
    Sep 01, 2010 | Casio MTP3036A-2AV Wrist Watch
    How to change the battery in a CASIO CA53W-1 Watch with Calculator
    open up the watch. there is a small spring that could fall out. dont lose it. use a small pin to pull battery clip off. put new battery in, replace strap and pink plastic. short the tiny contact labeled AC with the + on the battery. check that the clock now operates. lastly, reassemble
    there is a spring inside that goes betweeen one of the contact holes. dont know which.
    Jun 03, 2010 | Casio Watches
    No alarm, chime, or beep battery is hew, all displays are working, just no sound.
    http://www.timex.com/info/Product_Instruction_Guides_Downloads
    Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
    Hope this tip helps
    R/
    David
    Feb 22, 2010 | Timex T5E231 Ironman Triathlon 100 Lap...
    Alarm Malfunction.
    remove the band and the back of the watch, rotate the back 180 degrees and replace. The alarm should sound again.
    Dec 10, 2008 | Timex Sports Ironman Triathlon 100-Lap...
    Casio SPF 40 beeper not working after battery change
    There is this little spring which fits in one of the small holes in the watch. When I tested my watch without the spring, there was no beep. With the spring in place the sound worked nice again. So (IMO) apparently the little spring is used as contact between the watch en the "speaker" placed at the back of the watch.
    regards,
    Pieter
    Oct 04, 2008 | Casio PRG-40T-7 Pathfinder
    NO ALT,WEATHER DISPLAY
    Dreco,
    I was changing my battery and ran into a small problem, too. I know where one spring goes, but I have another similar spring that may have fallen out of the watch (I was working on another different watch before, so I'm not sure if the 2nd spring belongs in the watch). One spring contacts the small speaker on the metal cover and will not affect the LCD display.
    How many springs do you see in yours, if any?
    Dec 07, 2007 | Nike ACG Ascent WA0008 wristwatch
    Silva Tech 4o Accelerator Pro Trainer Womens Fitness Watch Logo
    61 people viewed this question
    Top Silva Watches Experts
    Jimmy Accardi
    Are you a Silva Watch Expert? Answer questions, earn points and help others
