Question about Panasonic Televison & Video
How to change refresh rate on my tx l47ft60b
My tv is a 600! Hz and on the screen it says 1080i /50 hz how do I get the 600!hz
  • Panasonic Master
  • 17,099 Answers
The panel drive on that set is 1600 Hz and that is the frequency of the LED backlights. It cannot be changed. The gain from 60 Hz to 120 was dramatic and 120 to 240 was subtle. To go over 240 to 600 is pretty subtle too. If you are in Europe 50Hz is the standard transmission rate of the AC power. The information on the television has no reference to changing the refresh rate.
Posted on Mar 31, 2014
    Top Expert:
  • Panasonic Master
  • 75,311 Answers
Refer its user manual for details. If you want to download it, Try this link. http://www.richersounds.com/static/manuals/FT60.pdf
Gopakumar Gopalan Google
Posted on Mar 30, 2014
  • 17 Answers
SOURCE: I can´t play xbox 360.
is this on hd mode?, if so it needs to be on 1080i as 1080p will not work that high up. Also if you are not using the component lead then you should the picture is fantastic.
Posted on Aug 12, 2009
SOURCE: Refresh rate at 60 Hz?
http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=02010100&model_name=LN52A630M1F
According to the Samsung website, the on-screen information is in relation to the incoming signal, not the TV settings which are being displayed.
As long as you have the 120 Hz turned on, the TV will display the picture at that refresh rate. However, the on-screen information will not reflect that.
Very ood.
Posted on Feb 13, 2010
  • 163 Answers
SOURCE: why when i change the
Because of cable box usually send 1080i or 720p signal. You can get 1080p from a Blue-Ray
Posted on Oct 10, 2010
  • 8909 Answers
SOURCE: How can i change my
It will do it itself. If you were to play a PAL video through it at 50Hz, it will be fine and if you play an NTSC in simple PAL it will be at 60Hz and display a reasonable picture.
Hope that helps.
Posted on Nov 16, 2010
  • 403 Answers
SOURCE: I bought the westighouse 42"
you have to check the output of the blu ray, your only gonna get what thats putting out. electronics have to match to work properly.
Posted on Mar 19, 2011
How do i get my tv to 120 Hz from 60 Hz?
Good day,
The 60/120 hz rating refers to the refresh rate that the panel runs at. I do not believe there is any user control over this rate. The TV runs at 120hz or 60hz as manufactured.
The higher rate (120Hz) is more desireable.
Good luck...
Jul 14, 2014 | RCA LED55C55R120Q 55" LED TV 1920x1080,...
Which tv doesn't exhibit motion blur?
You want high hz(hertz refresh rate). The higher the hz refresh rate, the better motion quality. 120 hz is typical for cheaper tv's, anything above that is good, the higher the better.
Jun 14, 2014 | Televison & Video
Tell me what is samsung syncmaster 794 default setting
The maximum resolution supported is 1280 x 1024 pixels at 65 Hz refresh rate, while the recommended resolution stands at 1024 x 768 pixels at 85 Hz. However, the maximum usable resolution is 1152 x 864 pixels at 75 Hz. Maximum usable resolution signifies the maximum resolution supported by a monitor at a refresh rate of 75 Hz or better. Though 85 Hz is an ideal refresh rate, 75 Hz is the lower limit. Any refresh rate, lower than 75 Hz, will give a flickered output and can cause some serious eye damage after prolonged usage...i hope this helps.
Aug 29, 2011 | Samsung 793DF 17" CRT Monitor
My plasma TV says 60hz refresh rate....why not 600?
60 hz means 60 times per second the screen is refreshed. 120hz is next then 240hz. only the newer ones have 120 and 240. i never heard of 600
Aug 19, 2011 | Insignia Televison & Video
Unable to get 1024 x 768 resolution on philips 105e
Hello, that resolution should be available but only at a refresh rate of 60hz as per the specs pasted below. Can you see this resolution setting on your graphics card? If not then perhaps you need to check you have the latest driver for your graphics card and just make sure that your graphics card does support that setting anyway.
Display
Diagonal Size 15" Viewable Size 14" Dot Pitch / Pixel Pitch 0.28 mm Max Resolution 1024 x 768 / 60 Hz Max Sync Rate (V x H) 120 Hz x 54 kHz Video Bandwidth 65 MHz Factory Preset Resolution Modes 1024 x 768 / 60 Hz
800 x 600 / 85 Hz
640 x 400 / 70 Hz
640 x 480 / 75 Hz
640 x 480 / 60 Hz
800 x 600 / 75 Hz
Regards,
nicam49
Dec 26, 2010 | Philips SoHo 105E 15" CRT Monitor
Trouble setting up VGA cable to watch movies from my computer on my TV?
First, make sure the VGA cable is plugged into the AV6 slot on the back of the TV.
You will have to go into your computer, and click Start --> Control Panel --> Appearances and Themes --> Display --> Settings and change the screen resolution to 800 x 600 first.
Then go into the program for your Graphics Card and change the screen resolution to 800 x 600 with a 60Hz Refresh Rate - sinc ethis will most likely be a change for you, your computer screen will seem to "flash" a bit - your eyes will adjust as you become used to this.
The other resolutions that work will be the following, but the 60 Hz refresh rate is the key:
Supported Display Resolution•Computer formats: 640 x 48060Hz, 800 x 600 60Hz, 1024 x768 60Hz, 1280 x 720 60Hz•
Feb 21, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Very ood.
Dec 19, 2008 | Samsung LN52A630 LCD TV
Format not selectable in AV-4
The AV-4 port on this TV is more problematic than anything I've seen. Set the resolution of the computer to 1024 x 768, 60 Hz refresh rate. If still nothing, set to 800 x 600, 60 hz refresh rate. Make sure the driver for the cable you have running from computer to TV is up to date. There's not much you can do on the TV end - all the changes have to be made from the PC.
Jun 15, 2008 | Philips 60PP9202 60" Rear Projection...
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
TFT Problem
This LCD can work at 75 Hz refresh rate, btw much more healthy for your eyes, you can change it accessing Control Panel -> Display -> settings -> Advanced -> Monitor -> Screen Refresh Rate -> select 75 Hz.
Dec 07, 2007 | Samsung SyncMaster 152N 15" LCD Monitor
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
