Question about Bosch HBL 455 Stainless Steel Electric Double Oven
F31 My Bosch double oven fan is continuously running -- even when the oven is off. The F31 code appears also. Help!
  • 20 Answers
If the cooling fan is constantly running then means thermal overload probably faulty, it has failed in closed position.
Best to get an engineer to help
warmest regards
Richard the Repairman
Posted on Mar 31, 2014
  • 116 Answers
SOURCE: Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Posted on Mar 11, 2007
dutchman05
  • 487 Answers
SOURCE: timer clock on bosch double oven
Please follow this link and download the instructions.
Manual
Please rate me as FIXYA
Posted on Apr 29, 2008
  • 1462 Answers
SOURCE: Programming Bosch Double oven
not separately programmable
Posted on Oct 05, 2008
barkencoa
  • 3463 Answers
SOURCE: bosch convection double oven,ovens won't heat,only broilers work
If it is fan assisted then check the fan element, it is located behind a panel at the rear of the oven compartment.
Plz rate my\solution.
Thanks.
Posted on Dec 17, 2008
  • 27 Answers
SOURCE: fan oven not heating
its the element not the stat
Posted on Mar 10, 2009
Bosch HBN 91 Sticky Fan
Yes you can oil the shaft...but the problem is within the bearing itself. You might be lucky and only have to oil it once...but chances are your bearing will sieze again...I suggest you remove and replace the fan.
Dec 02, 2013 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
I have a Bosch double oven and it continues to heat even when I turn it off. I then flip the breaker to turn it off. When I flip the breaker back on a code pops up (VO515 HOO47 ...
Hello there again
I know you rejected the chat and that is all right
Here is the part and what it looks like it may be a different color
Oct 16, 2010 | Ovens
ONLY BROIL WORKS, NEED BAKE TO WORK BEFORE THANKSGIVING
I'll presume you have no "fault code" appear in the display, i.e. F30, F31 correct ? Is it both top and lower oven ? What happens when you select a bake cycle, anything ? Does it appear to be on, but no heat ?
Just need some clarification and details and I'll try to help.
Oct 30, 2009 | Thermador SMW272 Electric Double Oven
Fan oven not heating
Mar 10, 2009 | Bosch Ovens
Bosch convection double oven,ovens won't heat,only broilers work
Thanks.
Dec 17, 2008 | Bosch Ovens
Oven
oven has two fans. the second fan is out of sight and cools the casing. it is operated by a seperate stat. not unusual for it to run for up tohalf hour after switching off. if it runs for an excessive time may be a fault nwith fan stat
Mar 20, 2007 | Bosch HBL 5056 Electric Double Oven
Bosch HBL 455 Stainless Steel Electric Double Oven Logo
163 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
