Question about Car Audio & Video
Where is the fuse box located on 2013 TaoTao 49cc My lights aren't working and my gas gage....
My 2013 TaoTao lights and gas gage isn't working looking to find out if there is a fuse box
  • 193 Answers
SOURCE: fuse box location
The fuse box or panel, is located under the dash on the far left, next to the parking brake release handle. Looking in this area, you will notic a small black plastic panel. Remove this panel and you will see the fuses.
There is a second fuse panel under the hood, up against the firewall. Remove the large black plastic panel and you will find a row of relays, and a number of large type fuses.
Bill
Posted on Nov 18, 2008
  • 51 Answers
SOURCE: looking for diagram for fuse box for Ford F250 Flex fuel Gas/Prop
ok go to this link they have every fuse panel diagram in your truck
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152801e56ea
they also have the wiring diagrams for most things if you need them too you can go to
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c152801e56fa
Posted on Dec 26, 2008
SOURCE: fuse box locator for dash board lights?
look up TIPM or IPM which connects to your left SCM that had an electrical overload due to your aftermarket tow wiring harness
Posted on Jan 27, 2010
  • 138 Answers
SOURCE: My dashboard has no lights, the odometer,
The fault is unlikely a fuse problem as different fuses control different components in the dash cluster. the fault is more likely with the cluster itself. It will have to be removed and sent to an instrument repair specialist.
Posted on Jun 03, 2010
  • 5 Answers
SOURCE: Where is the fuse box
The fuse panel is found on the passenger side of the vehicle. Open the passenger side door and you should see a "fuse access door" on the side of the instrument panel/dash just under the vent.
Posted on May 02, 2011
Ignition switch for a 49cc Tao Tao scooter and an ignition switch wiring diagram
Hi, Michael for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your TaoTao, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Tao Tao 49cc scooter wiring diagram Google Search
My Wiring Diagrams 49ccScoot com Scooter Forums
http://www.49ccscoot.com/manuals/Symply50_Service_manual.pdf
Eagle Atv Parts
TaoTao ATM50 A1 Owner Manual
Apr 06, 2017 | Tao New Scooter 50cc Street Legal New Look
I have a taotao moped /scooter 49cc that passes gas through into the crank case it only has 100 miles on it and its a 2017 modil ican't take it back to the place i bought it .its to far
You should bring it to ANY lawn mower repair shop. Sounds like the float in the carburetor is stuck open, and the fuel is going right past it and into the oil.
Mar 21, 2017 | GAS Motorcycles
Which service repair manual do i need ?
Hi, Anonymous for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
TAOTAO under 50cc Scooter Fully Automatic VIP 50 10 Tires CY50
Two hoses that run from the carburetor Is the upper hose cut and zip tied...
Scooters TAOTAO USA INC
TaoTao 50cc Scooter Owners Manual
TaoTao Scooters Mopeds Parts
Feb 07, 2017 | Motorcycles
Manual for a Taotao50;49cc model CY50-B 2012
Hi, Darla if your headlight is not working the first thing to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply to headlight bulb socket.
2. Faulty hi/lo beam switch.
3. Faulty ignition switch.
4. Fuse is good but no continuity on both sides.
5. Faulty wiring between battery positive and headlight bulb socket.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
http://www.seattleseoservice.org/result/taotao-49cc-scooter-manual.html
Sep 12, 2015 | Motorcycles
50cc taotao scooter the carb is runs then fills with gas untill it stalls out dont get much off the searchs i have made dont no if it is the carb our choke broke down carb and looks clean no clogs or
My 2012 Taotao 49cc scooter was spitting and sputtering then just died one day. I brought to a small engine repair person and come to find out, the hoses that came off the carb had cracks in them. Changed the hoses and the problem went away. Hope this helps.. I have since replaced the cheap hoses with new ones from the auto parts store and never had the problem again.
Oct 21, 2012 | Star 50cc scooter for kid
My dashboards lights and gages aren't working
You may want to check to see if you have a "gauges" fuse on the fuse panel. Another possibility is the cigarette lighter fuse. Sometimes they're wired on the same circuit.
Hope this helps! :)
Dec 15, 2011 | 2003 Chevrolet TrailBlazer
Dash board lights not working
Locate the knob or dial that controls the brightness of the dashboard lights. If the control is not immediately evident, check your owner's manual.
  • 2 Make sure the brightness control is turned on. If it is and the lights aren't working, the problem may be a bad fuse.
  • 3 Check the fuse that controls the dashboard lights (see How to Fix a Faulty Car Fuse). Replace the fuse if necessary.
    Find the fuse box (see A). It is usually located under the dashboard to the left of the steering wheel, at about knee level. Many cars have additional fuse boxes in the engine compartment. Check your owner's manual or call the dealer for the exact location(s)
  • Open the fuse box cover and locate the blown fuse. There are two ways to find the bad fuse: Look for a fuse with a melted center strip (see B, which shows two types of broken fuses). Or, if you know which device isn't working--for example, the radio--look for the fuse that handles that device. The fuse panel may have labels for each device, or the information may be in your owner's manual.
  • 3 Remove the bad fuse with a fuse puller (a small pair of plastic tweezers that should come with the fuse box). Or use a pair of needle-nose pliers.
  • 4 Check the number on the bottom or side of the bad fuse. This indicates the amperage.
  • 5 Buy a new fuse with the same amperage and push it into the slot in the fuse box with your fingers.
  • Oct 09, 2011 | 1999 GMC Yukon
    I have a 2010 49cc Tao Tao moped. I have only had it for six months. I bought carburator and jet cleaner for it called "Sea Foam" for small engines. I put the amount the bottle told me to add to...
    HI,,empty your gas tank,,and drain the carb put some new fuel in the tank and dont use additives again,,some do more harm than good (especialy in 2-strokes)
    Apr 20, 2011 | Husqvarna CR 250 Motorcycles
    Car Audio & Video Logo
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
