Question about Conair Simple Cut 12-Piece Haircut Kit
How to reassemble conair trimer
I took in apart to clean it now can't get it back together
4 Suggested Answers
triloberto
SOURCE: Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
Posted on Jun 07, 2009
SOURCE: I can't find the manual
their is 2 long wires with a l shaped hook on the the smalles blade that goes on the bottom the points of those wires go in the holes in the bottom of it which is a white thing with 2 groves in it make sure the blade is facing away from where the screws go the take the plastic pad and put it in the 2 holes of the top blad the set it on their facing the same direction the push down till its flush the put the 2 screws back in
Posted on Feb 28, 2011
  • 1739 Answers
SOURCE: took apart my Conair HC500
The Instruction Manual for your product can be found here:
http://www.conaircanada.ca/pdf/en/ibs/en_HC500C.pdf
Posted on Apr 25, 2011
How do I reassemble electrolux EL855 Unirapido vacuum?
try utube for a video on putting together or try Electroilux website for the manual.
Sep 18, 2016 | Electrolux Vacuums
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a Poulan 5020AV. The thing cuts wood like a woodchuck on crack! The problem I'm having is regarding the reassembly of the handle/trigger mechanism. I took it apart in order to remove/clean the carb....
Anytime I get into an unfamiliar saw I always take a number of pictures with the I-phone to help with reassembly. Not too much help is it?
It will only go together correctly ONE way. Do not force any of the parts as if you bend the carb linkage, you will forever have a problem with it. A hint: sometimes the parts have to be inverted and slowly twisted or turned back upright to install.
Jan 17, 2015 | Poulan Garden
How can i conair deluxe beard rechargeable beard & mustache trimmer
It sounds like it was taken apart by someone else???. Conair has a web-site which should give you diagram for putting it back together. Hopefully, all parts are there and undamaged.
Dec 07, 2014 | Conair Deluxe Rechargeable Beard &...
I can't find the manual of my Conair GMT 170X. I took the blades apart to clean and lube and now I don't know how to put the spring assembly back together with the blade. Please help
Dec 17, 2010 | Conair GMT 170 CS Beard Trimmer
How do reassemble after i took it apart to wash
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Sep 22, 2009 | Eddie Bauer 22-859
May 20, 2009 | Conair GMT200TD
Conair Simple Cut 12-Piece Haircut Kit Logo
80 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
