Question about Tunturi T60 Folding Treadmill
System check failure
I get the above error upon hitting start
    New Friend:
You can completely switch off the power for a few minutes and there is also a 'reboot' button at the front/bottom of the treadmill that needs to be pushed for about 5 sec (check manual). In my case that did not work and I had to replace the complete control panel/dashboard. My problem was different, I got funny messages about errors and flashing numbers on the dashboard. Tunturi was helpful in getting me the necessary spare parts. Good luck.
Posted on Mar 31, 2014
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
I have a gateway nv79u and it wont stay on for more than 30 mins. It keeps shutting off with error code 41 kernal-power.
Hi Michael,
Kernel Power - Error Code 41 often times caused by conflicting drivers. If you are trying to play a game or watching videos then the computer suddenly turns off, you must first check the following:
1. Open Device Manager (click Start > type Device Manager) and go to Sound, Video, and Game Controllers and see you have two audio drivers installed and disable one at a time and see if it fixes the issue.
2. Boot into Safe mode (press F8 continuously upon boot up) and see if the computer still shuts down there. (If it doesn't try disabling start-up items using this guide
3. If you're pop-up error messages like "System services cannot be started" upon boot-up, you're operating system is corrupted and must be restored to default settings. (you need to press F11 upon boot up - remember to backup your important files)
3. If Step 2 above is true, check if the computer is overheating. If it does, the computer needs to be serviced. Contact gateway support at 1-800-846-2000.
Cheers.
Sep 01, 2011 | Gateway NV7915u Notebook
I receive an error of CPU Fan Failure upon start up and then it shuts off. I will start it again and it is fine. I have found on the initial start up, if I'm really quick and hit F2, it will start up ok....
It seems like your pc is overheatting. Open the case on your pc and check wheather the fan that is in top of your cpu is running. If it is not take it out and take it to the close computer shop and buy a new one. It is simple to replace a fan.
May 17, 2010 | Compaq Presario Fan
Dell precision m4400 blue screening"system has recovered from a serious error"
"BSOD" also known as "Blue Screen of Death" occurs when system is not stable due to misconfiguration or driver incompatabilty or Virus or worm infection.
Method 1 :  Start your system by pressing F8 upon startup. Select "last know good configuration that works".check this one solve your  porblem.
Method  2 : Start your system by pressing F8 upon startup. Select "safe boot "and check if it work or able to log you into your Desktop.
Uninstalled any software or hardware you have recently added or installed.Click "Start", Select "Run", type "msconfig"
Again click "Startup" tab.Untick all the program thats loads during your system Boot up.
Method 3: Start your system by pressing F8 upon startup. Select "safe boot "and check if it works or able to log you into your Desktop.
Click "Start", and then select "All programs", then "Accessories".Select "system tools" and then "System Restore".Try to restore your PC to a point or date which you know it was working fine.
Method 4 : If none of the above workor you are able to boot it. Then download "Hiren's Boot CD"
Here is the link
http://hirens.longcomputerservices.com/Hirens.BootCD.10.1.zip
Download the file and burn the ISO image in a CD.Boot your system using that CD. It has lots of tools for repairing Windows, system restore, Data recovery etc.Check if it can fix your problem.
If Hiren's Boot CD can't fix it then Backup all your important datas and go for a new install.
Don't forget to create system restore point whenever you are going to make changes to your system.It will help you in recovering during the time of failure.
HAPPY NEW YEAR.
Dec 31, 2009 | Dell Mobile Precision M4400 Notebook
PXEE61:media test failure, check cable PXEM0F:exiting PXE ROM operating system not found
You didn't ask a question. I assume this is an error on boot-up? If so, then the system is reporting that no pxe server was found to boot your system over the network. To correct this you should enter the BIOS setup upon power-up (via hitting the delete, f1, f2 or f10 key - depending upon your computer) and disable the boot from network setting. Save configuration and restart. You should probably set BIOS boot order to 1st device = cdrom, 2nd device = harddrive.
Jun 19, 2009 | Computers & Internet
Still starting, but barely.
use a scan tool to check the efi system first!!! then tell me what the trouble codes are! on josephaddyson@yahoo.com
Jun 17, 2009 | 1998 Nissan Maxima
Ink system failure 0xc05d1281
When this error occurs, please remember it concerns the ink carriage assembly not initializing properly. You can look inside the printer while it is OFF and move the carriage assembly to the left of the printer and see if there is any debris between the carriage assembly and the HOMING sensor. If any debris clear it out and turn and test. I hope this solution helps you. Thank you JaBu.....
Mar 27, 2009 | HP Photosmart 3110 All-In-One InkJet...
What is error 0xc05d1281
Apparently its a Ink System Failure. Here's an email thread for comment for HP C6180 with error 0xc05d1281 => http://www.fixyourownprinter.com/forums/printer/50063
It's posted somewhere in the middle of the thread.
Here's a solution to reset your printer to factory defaults without using your ink for recalibration.
1. Unplug the printer and wait 30 seconds for power to discharge.
2. Plug in the printer.
3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
4. When the printer turns on, if you still get the error message, it's OK. Then perform the steps listed above, starting with pressing the * and # key.
5. After you perform the steps listed above, when you are at the step at the end where you are pressing the cancel button until you get to the WELCOME screen, if at some point you see a message, “Inproper shutdown, hit OK”, go ahead and hit OK and the Welcome screen should appear.
One thing that is nice about this method is that it doesn't use up all your ink doing a recalibration.
Dec 31, 2008 | HP Photosmart C5180 All-In-One InkJet...
Installing error code -106
I suggest go to Start/Settings/Control Panel/Add remove programs.
Check and see if the program is in list and remove it. While in control panel go to system/Device Drivers check non have a yellow mark on them if so reinstall drivers or upgrade Reboot and try again.
Jul 22, 2008 | Computers & Internet
Tunturi T60 Folding Treadmill Logo
253 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
